Author Topic: stump  (Read 823 times)
Offline hopm
stump
« on: August 06, 2018, 09:50:55 PM »
Had a call today about a walnut stump a guy had dug out. He asked if there was anything he could do with it. He sent pictures. It looks massive. He said the stump itself is close to 36" across. I volunteered to work it up. Any suggestion you could give on how to approach this would be much appreciated!!
Online YellowHammer
  • Take Steps to Save Steps
    • Hobby Hardwood Alabama
Re: stump
« Reply #1 on: August 07, 2018, 12:02:43 AM »
The root ball is murder on bands due to all the hidden dirt and pebbles.
Pressure wash it, then take a chainsaw and trim off all the little roots.  Then pressure wash it again.
HobbyHardwoodAlabama.com
Offline Skipper11A
Re: stump
« Reply #2 on: August 07, 2018, 12:18:22 AM »
Have lots of sharp blades on hand because there is going to be a lot of dirt and rocks embedded in the roots.  I don't like it at all.  It sounds like you have a customer who is very excited to abuse your equipment.  That root ball would never be on my sawmill unless there was some serious compensation.  Discretion is the better part of valor.
Offline bushhog920
Re: stump
« Reply #3 on: August 07, 2018, 12:48:37 AM »
Turn it upside down and bury the trunk. With no dirt on the roots it looks like a interesting bush.
Offline mike_belben
  • Pulp Friction
Re: stump
« Reply #4 on: August 07, 2018, 01:47:43 AM »
Id have told him he could get a leaf blower and some motor oil, then burn it.
Revelation 3:20
Offline Peter Drouin
    • A&P Saw mill LLC
Re: stump
« Reply #5 on: August 07, 2018, 06:17:09 AM »
Go ahead and see what it's all about. ;D
A&P saw Mill LLC.
License NH softwood grader.
Offline tmbrcruiser
Re: stump
« Reply #6 on: August 07, 2018, 07:55:12 AM »
I should have taken pictures. Last month a friend brought me a walnut log with the stump attached. The DBH is approximately 20" and the log is approximately 16'. I washed the root ball and trimmed the roots back until it looks like an almost normal log. At this point I had sharpened the chain saw three times but I believe I've trimmed away all of the soil. Haven't sawn the log yet and I'm not sure it was worth all the trouble.
Once you get sap in your veins, you will always have sawdust in your pockets.
Offline DWyatt
Re: stump
« Reply #7 on: August 07, 2018, 08:00:53 AM »
I did this once with a maple stump for one of my projects, I'm not sure there's too many people with enough money to make me do it again :D
This is what I looked like after 3 hours of pressure washing and hacking with the chainsaw.
And the Stump after that 3 hours.
3 chainsaw chains and 5 bands later the stump gave up 7 pieces around 1 1/2" thick. Here's the first piece I used and the project I made with it. Told my sister if she didn't appreciate her Christmas present that year that I was going to disown her :D It was one of the most exciting, aggravating projects to date but boy she gave up some beautiful slabs.
Make sure you make like Peter and get some suitcases of money and boxes of bands when its all done ;)
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: stump
« Reply #8 on: August 07, 2018, 09:05:51 AM »
I have done it and I don't envy you.  Hourly rate plus blades.
I had a root stub to snap off a hydraulic fitting on my log clamp when I turned a stump.  You will only have trouble loading, turning, clamping, and sawing.   :o
Offline Brad_bb
    • My timberframe blog
Re: stump
« Reply #9 on: August 07, 2018, 11:31:37 AM »
Depends what you want out of it.  Gunstock, knee braces or slabs?  The first two you do with a chainsaw ripping.
Stump Not tree stump remover?
Started by gspren on Ask The Forester
Last post April 29, 2013, 12:56:50 PM
by gspren
stump removal - best way to rot a stump
Started by PB Logging on General Board
Last post October 18, 2018, 09:54:04 AM
by Al_Smith
Stump
Started by Larry on General Board
Last post December 16, 2005, 08:09:07 AM
by Tom
fun with a stump
Started by Ocklawahaboy on General Woodworking
Last post May 16, 2013, 08:43:46 AM
by woodweasel
