Author Topic: Clark skidder 666B transmission problem  (Read 203 times)
Offline VelmerD
« on: August 07, 2018, 08:04:09 AM »
Looking for info on problem with Clark 666B it wont go into reverse, I'm getting ready to pull it but I noticed when you turn the machine to the left or right it makes a racket at the top of the tranny from the PTO shaft going to the winch. I thought it was the PTO shaft itself making the noise (loose spline on shaft) I put a pry bar on the yolk coming out of tranny and there was a little bit of play. Would this cause the reverse clutch pack from engaging? This shaft runs in the center of the forward revers and HI,LOW clutch packs? Thanks for any insight on this
Clark 666B skidder transmission wont shift into reverse 2420
Started by VelmerD on Forestry and Logging
Last post August 12, 2018, 05:57:37 PM
by celliott
clark 666B skidder tires/Parts
Started by Tombstone on Wanted
Last post May 14, 2008, 10:21:46 PM
by Tombstone
450 timberjack skidder with Clark transmission problems.
Started by delimberboy on Forestry and Logging
Last post August 14, 2017, 07:59:17 PM
by Spartan
Clark 666b, no brakes
Started by CP1991 on Forestry and Logging
Last post December 17, 2015, 09:04:37 PM
by CP1991
