Author Topic: Transfer table  (Read 496 times)
Offline redbeard
    • whidbeysawmill.comwww.whidbeysawmill.com
Transfer table
« on: August 07, 2018, 04:51:31 PM »
Found what I thought was a old log deck , Of course it was buried in tall vines and small trees at a non operating sawmill and made a deal with the owner and dug it out and hauled it home. One of those future projects that get in the way of other future projects.
 It was tricky loading it on 14' boom truck bed, needed a little help from his Case Backhoe,  we only had 7' hanging off the bed .
 originally I thought it was home made and then found a plate when pressure washing.
 This end is where the edger operator would control slabs coming off the mill by raising the chain strands to move boards sideways then lower them and use rollers to feed boards to edger station.
I was able too actually get a sketch and a invoice from shurman and the table was fabricated in 1956 for
Spalding & sons inc. in Grants Pass Oregon.
Probably will work on it this winter I did get the roller freed up and the other chain is pretty froze up. There's a few other issues one of drive shafts is bent. And the pedal controls are toast.
Whidbey Woodworks and Custom Milling  2019 Cooks AC 3662T High production band mill and a Hud-son 60 Diesel wide cut bandmill  JD 2240 50hp Tractor with 145 loader IR 1044 all terrain fork lift  Cooks sharp
Offline Crossroads
  • lets make some sawdust
    • Kevin Bales faith family farm and portable sawmill
Re: Transfer table
« Reply #1 on: August 07, 2018, 04:58:59 PM »
Thats cool, it seems to have done a bit of traveling over the last 75 years.
2017 LT40 wide, Kubota l185dt, 2-036 stihl, 2001 Dodge 3500 5.9 Cummins
Offline moodnacreek
  • Sawin by the notches
Re: Transfer table
« Reply #2 on: August 07, 2018, 07:21:07 PM »
You made a good move. The more powered decks you can get in your yard the better. I took a 11x20' , 4 strand log deck and made it a green chain. It is single phase, 3 h.p. , forward and reverse. I sort, stack and sticker on this deck and un load with the fork lift.  Iwouldn't work without it.
Offline Peter Drouin
    • A&P Saw mill LLC
Re: Transfer table
« Reply #3 on: August 07, 2018, 08:43:36 PM »
Looks to be cleaning up nicely. 8)
A&P saw Mill LLC.
License NH softwood grader.
new to the ff. transfer table question
Started by PAmizerman on Sawmills and Milling
Last post October 13, 2017, 07:42:40 PM
by PAmizerman
Wood-mizer transfer table - like new
Started by mjl_2007 on For Sale
Last post September 16, 2017, 07:06:23 PM
by 1crowfarm
Thinking of getting conveyor and transfer table for LT70
Started by Cypress Man on Sawmills and Milling
Last post March 01, 2014, 08:31:20 AM
by stavebuyer
Wood-mizer transfer table slab kicker
Started by DGK on Sawmills and Milling
Last post February 16, 2017, 06:00:56 AM
by Kbeitz
