Author Topic: blue stain yellow pine for board and batton  (Read 1167 times)
Offline Raym
« on: August 08, 2018, 04:48:07 PM »
Is there any reason not to use this for board and batton siding on my shop build? The walls are traditionally framed (stick framed with plywood sheathing and tyvek).
I have plenty sawn (only need to sterilize) and if so, I was going to resaw into 1/2" boards.
My other option is to use white oak but it is not sawn yet
Thanks in advance
'14-LT40 super, nyle l200m kiln, vintage case 480E loader.
It's not the fool that askith, it's the fool that agreeith.
Offline Lawg Dawg
  • True South Sawmill Lumber
Re: blue stain yellow pine for board and batton
« Reply #1 on: August 08, 2018, 06:45:13 PM »
I'd use it, no problem...you could also sho-sugi-bon it
2018  LT 40 Wide 999cc
John Deere 5020, John Deere 4000, 2016 F150, Husky 268, 394xp, Shindiawa 591, 2 Railroad jacks, and a comealong. Woodmaster Planer, and a Skilsaw, bunch of Phillips head screwdrivers, and a pair of pliers!
100,000 bf club member
Pro Sawyer Network
Offline bags
  • Location: Up high in the Colorado Rockies, Westcliffe ,CO.
« Reply #2 on: August 08, 2018, 08:22:35 PM »
The only reason not to use it would be if you don't like the color.lol. Blue stain is a fungus, and sets as soon as the board dries. The boards structure is the same as any other lumber.
Offline firefighter ontheside
  • I like trees.
« Reply #3 on: August 09, 2018, 01:59:00 PM »
Use away.  It will probably all turn grey anyway.
Woodmizer LT15
Kubota Grand L4200
Stihl 025 and MS291
2017 F350 Diesel 4WD
Offline Dave Shepard
  • Geometrically proportional
    • My homepage
« Reply #4 on: August 09, 2018, 04:42:12 PM »
Blue stain means sapwood. Sapwood is not very durable exposed to the weather.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #5 on: August 09, 2018, 05:01:55 PM »
This would be my option.
Offline Raym
« Reply #6 on: August 13, 2018, 05:38:38 PM »
I think this is the route I will take. Since its just siding, I don't see any reason to saw any more than 1/2" thick though. Or do I
Offline ljmathias
  • Been sawing part-time almost 27 years now
    • Polymer Science Learning Center
« Reply #7 on: August 16, 2018, 07:30:30 AM »
I saw my live edge pine lap siding at 3/4" and don't plane. Planing would help a lot- better finish and less uptake of stain/sealant plus make the water run off better. With pine too thin, cupping is a problem for me but then I put mine up without drying- let nature do that for me.
Keep us posted on how the oak works- inquiring minds and all.
LJ
LT40, Long tractor with FEL and backhoe, lots of TF tools, beautiful wife of 50 years plus 4 kids, 5 grandsons AND TWO GRANDDAUGHTERS all healthy plus too many ideas and plans and not enough time and energy
Offline samandothers
« Reply #8 on: August 16, 2018, 11:02:50 AM »
I did not sterilize my pine board siding.  I coat the outside with an oil based protection from weather.
@Lawg Dawg did you burn both/ all 4 sides?
Offline smcclure
« Reply #9 on: August 16, 2018, 12:51:04 PM »
I used blue stain boards as siding on my shop and just spray a little water sealer every few years.  Been up for about 9 years and still hard and not showing any signs or rot.  I also left mine 1" thick.
Scott
Offline Beavertooth
« Reply #10 on: August 16, 2018, 05:18:32 PM »
If you saw your white oak 1/2" you will probably have a bunch of boards that will cup and split all to pieces. The first lumber I sawed up for a guy when I got my first mill in 2005 was a bunch of oak of several different species and he wanted it sawed 1/2" so I told him I would saw it however he wanted it since I did not know any better at the time. So that is what we sawed it and every bit of it split all to pieces when it dried. Good for nothing but a bond fire.  Live and learn.  :-\ :-\
2007 LT70 Remote Station 62hp cat.
Offline Lawg Dawg
« Reply #11 on: August 16, 2018, 06:03:54 PM »
I burned 3 sides on purpose...but all that flame from the 500,000 btu torch head will scorch the back too
Pro Sawyer Network
Offline Stephen1
  • Where there is a will, there is a way!
    • muskoka Sawmill
« Reply #12 on: August 16, 2018, 08:02:21 PM »
Does burning preserve the wood better?
blue stain on pine
Started by gtr on Ask The Forester
Last post April 15, 2006, 08:37:20 PM
by Pullinchips
How to encourage blue stain in pine.
Started by Joe Hillmann on Sawmills and Milling
Last post September 30, 2014, 06:12:45 PM
by Alligator
blue stain in pine - make it stop!
Started by Engineer on Drying and Processing
Last post August 22, 2004, 06:22:56 AM
by Don_Lewis
Will a pond prevent blue stain in pine?
Started by WoodenHead on Sawmills and Milling
Last post June 19, 2015, 10:20:10 PM
by Alligator
