Author Topic: Hydraulic oil  (Read 524 times)
Offline loggerman1959
Hydraulic oil
« on: August 09, 2018, 06:26:09 PM »
I just purchased a 1987 Hood loader , model 20000 , was wondering what weight hydraulic oil is recommended for it . I've been searching other sites , but can't seem to find out what's recommended . Any help would be appreciated .
Offline kiko
Re: Hydraulic oil
« Reply #1 on: August 09, 2018, 08:15:28 PM »
Around here with blistering heat and mild winters Aw68 would be my choice on a gear pump knuckle boom. Aw46 or 32 would be considered related to ambient temperature.
Offline Grandpa
Re: Hydraulic oil
« Reply #2 on: August 10, 2018, 05:54:06 AM »
I'll second what Kiko said.
Also, if you call Hood, you should get a real live person. In my experience said person will be friendly and helpful. Good folks up there. The number is on their website.
Offline Gearbox
Re: Hydraulic oil
« Reply #3 on: August 10, 2018, 08:46:10 PM »
If you are going to use it year around . You will need to thin it for winter . DO NOT LET THE TEMP GET OVER 150 . ISO oil degrades fast over 150 . 46 in summer drain and fill with 32 for winter . you will only get rid of about half when you drain the tank .
Re: Hydraulic oil
« Reply #4 on: August 11, 2018, 11:54:40 AM »
Thanks everyone
LT40 Super hydraulic/LT50/LT70 DC Hydraulic pumps specs question....
Started by Percy on Sawmills and Milling
Last post August 06, 2017, 12:56:15 PM
by JB Griffin
Output of the hydraulic pump and engine HP to drive a full hydraulic Bandmill?
Started by R. Smith on Sawmills and Milling
Last post September 04, 2009, 08:31:01 AM
by Chico
LT40 hydraulic system Vs LT40 Super hydraulic system
Started by Dan_Shade on Sawmills and Milling
Last post June 24, 2010, 09:54:38 AM
by Bandmill Bandit
sad
In need of hydraulic help
Started by chet on General Board
Last post April 19, 2008, 11:14:41 AM
by Timburr
