AVAILABLE
Author Topic: Stihl 2 in 1 filing guide - interchangable?  (Read 512 times)
Offline samm
  • Beginning Timber-er
« on: August 13, 2018, 11:41:07 AM »
Hey gang.  My brother-in-law gave me an awesome christmas gift - a new Stihl 2-in-1 filing guide chain sharpener.  It's great, easy to use.  It is the 3/8" P (picco) pitch filing guide, with the 4.0mm files; great for my little MS192 and 193.
I also want the same sharpener for my 3/8" standard chains, on my 362 and 661.  I see Stihl sells the 2-in-1 guide with the 5.2mm files in it, but that's another $55 on Amazon.
Question: can I simply swap in Stihl replacement 5.2mm files and begin using my guide on my big boy chains too?  Or are the depths or angles different between guides?
Cheers!
SAM
Keep your stick on the Ice!
Offline tawilson
Re: Stihl 2 in 1 filing guide - interchangable?
« Reply #1 on: August 13, 2018, 11:55:26 AM »
Same thing, different color.
Robot Check
2017 LT40HDG35 WIDE
Offline samm
« Reply #2 on: August 13, 2018, 01:26:27 PM »
Thanks for the link.
But my question remains unanswered - are the files interchangeable?
Offline Pulphook
« Reply #3 on: August 13, 2018, 01:46:14 PM »
No...different size files for different size chains.
Offline tawilson
« Reply #4 on: August 13, 2018, 02:49:45 PM »
Did you try a file to see if it fits? I haven't but I doubt it. I think the holes for the files are sized appropriately. And the depth wouldn't be right either.
2017 LT40HDG35 WIDE
Offline samm
« Reply #5 on: August 13, 2018, 03:27:16 PM »
Yes, different size files, we know this.
But I'd like to know if the files are interchangeable INTO the guide, so I can use the guide with different size files for my different chains.
Are the filing /or depth gauge depths on the 2-in-1 3/8" Picco guides vs the standard 2-in-1 3/8" guides different?  This would make sense, since the Picco chains are "low profile".
As far as, will the files fit in the plastic?  If I had any 5.2mm files, I would try to fit them into the plastic.  But I don't have any, I was hoping to get an answer here before I bought them.
Thanks in advance.
Online hatman-nz
  • back again. used to be JD Kid
« Reply #6 on: August 14, 2018, 05:08:47 AM »
have the older style  pfred  ones and  I'm  sure the. depth is different   and the holding area for the files  is made to suit the size  of file  .... you have got me wondering a bit now   as  I think the 3/8 one  may of been  able to been used on 404. chains   with bigger file      thats the older style. 2 in 1.
Chain Saw Sharperners CHAIN SHARP
ummm  yes can use. different. size files in older one   , not. sure if there is a difference in  the depth  between the 2  models
have not seen or used. the newer ones tho and looking at ordering  some soon  have to buy 4 of them. with having  3/8lp .325 3/8  and .404  chains
mates got 3 of them  for his saws  he loves them   eazy to use etc etc
Offline teakwood
  • Switzerland
« Reply #7 on: August 14, 2018, 08:41:32 AM »
You have to buy another one, they are different for each size file. they are just like 35$ on ebay. Well worth the money as they will serve you lots of years
Offline samm
« Reply #8 on: August 14, 2018, 08:46:53 AM »
Thanks all for the answers.
Looks like I will be scraping eBay yet again :laugh:
Cheers
Offline MSdeer
« Reply #9 on: August 14, 2018, 11:44:32 AM »
Buy the Pferd brand (they make the Stihl ones for Stihl) Same product and you can find it for ~$27 shipped on ebay.
STIHL FG2 Filing Guide
Started by Philbert on Wanted
Last post October 17, 2015, 02:22:26 PM
by JRE
are Stihl and Hsuky bars interchangable?
Started by Alta on Chainsaws
Last post April 04, 2006, 05:10:01 AM
by dozerdan
Please help me with selecting a filing guide
Started by woodworker9 on Chainsaws
Last post May 08, 2017, 11:04:11 PM
by CTYank
Granberg Filing Guide
Started by bendjoseph on Chainsaws
Last post July 03, 2011, 08:10:25 PM
by Ron Scott
