Author Topic: Hey Dodge Guys  (Read 2195 times)
Online barbender
Hey Dodge Guys
« on: August 13, 2018, 09:53:26 PM »
I know there's a lot of other Dodge 3/4 and one ton drivers on here- I have an 03 Dodge 3500 DRW 4x4. I love the truck, but the truck loves front tires. It scrubs the inside edge, like it's toed in badly. I just had it aligned recently, after getting new ball joints and the drive axle u-joints. I'm wondering if any of you have experienced the same or similar. I'm trying to figure out if I have a mechanical problem (I was just under it tonight, watching while my wife worked the wheel back and forth, everything looks tight) or if it is just the nature of the tires I have (Toyo M55, they are a commercial off road tread). Thoughts?
Online armechanic
Re: Hey Dodge Guys
« Reply #1 on: August 13, 2018, 10:04:50 PM »
I have 5 dodges and one ford.  It seems that 4x4 are just hard on front tires, rotate every oil change.  Might check front to rear alinement, make sure the rear is tracking strait with the front.  I only use the correct size tires also, no big mudder tires or lift kits for me.
1989 Lt 40, D6C CAT, Home made wood processer in progress.
Online Corley5
  • Wolverine, Michigan
    • Whittaker Farms
Re: Hey Dodge Guys
« Reply #2 on: August 13, 2018, 10:15:47 PM »
The 02 that we had was hard on aggressive tread tires.  They HAD to be rotated very often.  Like at least every 3,000 miles.  Less aggressive off road tread wasn't nearly as bad.  They'd go twice as long.
Online mike_belben
  • Pulp Friction
Re: Hey Dodge Guys
« Reply #3 on: August 13, 2018, 10:39:19 PM »
Unit bearings are still good?  Track bar bushing at the frame end is still tight? (It looks like a tie rod end.  This is primary cause of death wobble in those trucks.. Or atleast in the 2nd gens it was)
Revelation 3:20
Offline Mooseherder
Re: Hey Dodge Guys
« Reply #4 on: August 14, 2018, 07:16:30 AM »
My 2004 Dodge DRW 3500 4x4 is having similiar issues and I've been chasing it for a couple months.  I went in for an alignment because it was pulling to the right with new tires.  They changed most everthing under there with what they said was heavier duty parts than original along with the passenger drive axle u-joint.  I left there and my truck was pulling to the right even worse than before.  I went to a different place for alignment and they got it better.  I was happy with it for a couple days then it was pulling to the right again.  I went back in and that's when the Mechanic showed me there was no more room for adjustment on the dials. Each one was at the end.  He said it could be remedied by using offset ball joints.  I haven't done that yet.   The first place had my truck for 5 days.  So frustrating I won't even start to tell you about it.
Lane Circle Mill
Offline KirkD
Re: Hey Dodge Guys
« Reply #5 on: August 14, 2018, 12:32:30 PM »
First thing you do is upgrade the drag link to the newer style or at least look and see if you have the new style on it yet.
This is Dodge's solution to the problem that doesn't exist and that they corrected in 2010.  This kit ties the front wheels together eliminating independent toe in and out.  The idea is to cut down on tire wear and death wobble.  This will not make up for other worn front end components such as steering gear box and ball joints. All 03 to I think 09 should have the newer style steering box and power steering pump installed. If you do the steering box at the same time you won't have to buy the upgraded pitman arm the new steering box comes with it from dodge.
There is a lot of talk in the Dodge forums on this topic it is not cheep to do but it will make your truck safe and drive like it should.
Wood-mizer LT40HD-G24 Year 1989
Online mike_belben
  • Pulp Friction
Re: Hey Dodge Guys
« Reply #6 on: August 17, 2018, 10:53:49 AM »
Maintaining a dodge 1ton is a lot of work.  Seems like you gotta go through them every 3 years.
Revelation 3:20
Offline coxy
Re: Hey Dodge Guys
« Reply #7 on: August 17, 2018, 03:37:33 PM »
sell it and run  :D :D
Offline Brad_S.
Re: Hey Dodge Guys
« Reply #8 on: August 17, 2018, 04:33:04 PM »
 I have an 04 and experience inside tire wear, especially on the driver side front.
 Thanks to this thread, I can now put a name to what I have been experiencing more and more ... “Death Wobble”.  I have been trying to describe to my mechanic what I am experiencing. Now I can show him videos of what is happening and links on how to fix it Thank you!
Online mike_belben
  • Pulp Friction
Re: Hey Dodge Guys
« Reply #9 on: August 17, 2018, 06:23:25 PM »
If the steering wheel is thrashing side to side out of control and youre afraid for your life, thats DW.  5 link front suspensions such as dodge and jeep cherokee are very sensitive to loose track bar joints.  My 88ish f350 with leafs had a track bar and that was also the cause of its DW.  A k30 chevy did it over tires, surprisingly.  Jeeps have all been track bar for me.
A 2nd gen dodge basically needs a track bar every year.  Buy the parts store one with warranty and just keep changing it out.  I finally cut the balljoint end off and built a double shear captured bushing end welded over the stock bar with tabs welded at the frame, and a good poly bushing at the axle end of it.  That cured the DW.
Steering column lower bushings also go bad on those, and someone makes a tap in insert for like $60 to fix it.. New part is unobtainium.  Then theres the steering box brace and f350 outer knuckle conversion to delete the unit bearings, crummy brakes and full time hubs.  It kinda never ends.
Revelation 3:20
Offline JB Griffin
Re: Hey Dodge Guys
« Reply #10 on: August 17, 2018, 10:42:09 PM »
Buy a Ford and be done with it. (I say this as I am in the process of puttin ball joints and nearly every steering component on mine :D)
2000 LT40hyd remote 33hp Kubota, 160 Prentice, Frick 2 saw gang edger, Wright W-37 ABG, Suffolk dual tooth setter, Cat claw single tooth setter,'96 F-250 7.3 PSD 4x4, CS-590 Echo, MF 20c, M681 Memo.
Over 2.5 million bdft sawn with a Baker Dominator and counting.
Online barbender
Re: Hey Dodge Guys
« Reply #11 on: August 18, 2018, 12:26:31 AM »
Brad, my inside wear is more pronounced on the driver's side as well. I think the Y link front steering linkage is partly to blame, from what I can understand. It changes the toe as you steer side to side. I've had death wobble on both my 97 and 03. The 97 needed the front end rebuilt, the 03 was as simple as replacing the steering stabilizer shock.
Offline OH logger
  • livin the dream
Re: Hey Dodge Guys
« Reply #12 on: August 19, 2018, 12:33:23 PM »
I have a 2016 Ram 3500 and have never had this. am I lucky or have they fixed this issue? mine has 70,000 miles on it. and not too many of those aren't pullin a  log trailer :)
john
Online mike_belben
  • Pulp Friction
Re: Hey Dodge Guys
« Reply #13 on: August 19, 2018, 06:09:57 PM »
I dunno but ill throw in some more fun dodge guy trivia.
Q: Youve been catching an occasional odd wiff of something hot, kinda like coolant, kinda like plastic but all seens well.  You may even correlate the occurance to pulling a trailer at night.  Musta drove by a burn barrel or something. Hmm.   Then the headlights flicker or quit and you smell it again.  Whats that smell?
A. The headlight switch and related wiring about to light on fire.  The same switch that dodge just kept on using even though it was a chronic cause of melted wiring and plugs.  If the dash is hot around the switch shut the lights off quick!
Round 2.
Q.  Lately the starter hesitates to begin cranking when you turn the key.  Itll click then take a second or third hit before engaging. What is it?
A.  Your starter solenoid plunger contacts have worn, corroded and now begun to arc.  Soon they'll weld, go full load amps on both batteries and ignite the main cable insulation, burning the truck down.
Round 3.
Q.  Your trusty old 12v is getting hard to start in the mornings and runs rumbly for a while until it purges the air it seems to be getting in the fuel system over night lately.  What is it?
A.  Among a plethora of other things, theres a good chance the temp sensor on the fuel heater bowl has quit and thus the heater is staying on way too long and has begun melting the plastic inside the plug connector.  Fuel doesnt leak onto the ground because of the connector seal holding it back, but air is sucked in through the melted hole and fuel is swimming around that hot copper electrode, threatening to burn the truck down.
Round 4
Q.  Youve survived death wobble, rebuilt the front end and lived to tell about it.  Then your trans starts hunting for gears and dropping out of lockup.  Whats that smell?
A.  No, its not the governor pressure sensor or transducer, and its not a bad passenger side ground connection.  Its the smell of your hair smoldering as you contemplate burning this stupid frigging dang truck down.
If you got all 4, my condolences.  Youre a dodge guy and its terminal.  Check your fire extinguisher to make sure its charged and keep loppers handy to cut the battery cables in an emergency.
Revelation 3:20
Online Corley5
    • Whittaker Farms
Re: Hey Dodge Guys
« Reply #14 on: August 19, 2018, 06:15:24 PM »
Never had any of those issues with my Dodge.
Offline gspren
Re: Hey Dodge Guys
« Reply #15 on: August 19, 2018, 07:49:40 PM »
Has Dodge/Ram made a comfortable seat yet? Every time I ever went shopping for a full size truck I drove them all and Dodge seats sucked, I really wanted a Cummins but my butt said no. I haven't looked since 2013.
Offline Mooseherder
Re: Hey Dodge Guys
« Reply #16 on: August 19, 2018, 09:35:48 PM »
Never had the death wobble problem.  I dunno but the 2019 Dodge Trucks appear to be the best ever built truck.  Can't really complain about my 14 year old Dodge either. It's been good and will last another 14 with normal wear type maintenance every so often.  It goes from Florida to Maine every year and sometimes twice.  My Son In Law sells Chevys and Fords to companies who operate Fleets.  He said Chevy will have a new Truck around September.  Ford sells no matter what.  Big brand loyalty there.  He gives 2019 to Dodge.  They nailed it. A lot of good Trucks and options coming soon from what I have read, especially Chevy.  Ya just want to part with that hard earned cash to get one.
Lane Circle Mill
Offline Bandmill Bandit
Re: Hey Dodge Guys
« Reply #17 on: August 19, 2018, 11:22:23 PM »
In 1996 Dodge got my butt OUT out a Ford and in their truck because of the SEATS! MY last Dodge is 2001 With 398 000 KMs. The new dodge LOST my butt to a 2018 Super Crew F150 Lariat  3.5 Eco Boost with all but a glass roof because of the SEATS. Nothing else compares so far.
Chev and Dodge have some ground cover to catch up right now. But it will happen I am sure.
If you ain't livin on the edge you are takin up way to much room. Of course at my age if I get too close to that edge any more theres a good chance I may fall off.
2001 Dodge 1500 4x4. 2018 F150
2007 Woodmizer LT40HDG28 almost Super
2 Logrite 36 inch cant hooks and a bunch of stuff I built myself
Online mike_belben
  • Pulp Friction
Re: Hey Dodge Guys
« Reply #18 on: August 20, 2018, 12:38:04 PM »
I had em all and then some by 200k.
Revelation 3:20
Online Corley5
    • Whittaker Farms
Re: Hey Dodge Guys
« Reply #19 on: August 20, 2018, 01:33:07 PM »
285,000 miles on mine when we gave up on the body.
05 dodge
Started by coxy on General Board
Last post January 18, 2018, 08:03:34 PM
by coxy
dodge
Last post July 02, 2015, 08:00:41 PM
by coxy
Dodge 800
Started by redbeard on General Board
Last post February 06, 2012, 09:47:12 AM
by sawguy21
dodge issues
Started by OH logger on Forestry and Logging
Last post April 29, 2017, 06:54:04 PM
by lopet
