Author Topic: Hydraulic Sawmill  (Read 5743 times)
Offline tacks Y
Re: Hydraulic Sawmill
« Reply #120 on: September 09, 2018, 12:52:11 PM »
I have a Logmaster LM3 with a 30+ hp cat. Would you like me to measure my pulleys? It has a auto clutch on it, and I like it. Speed up engine and saw away.
Offline charles mann
« Reply #121 on: September 09, 2018, 02:09:32 PM »
Yes sir. That would help out great.
Pulley center to center too if you dont mind. Thank you.
Temple, Tx
Offline tacks Y
« Reply #122 on: September 11, 2018, 02:39:50 PM »
On the engine is a single pulley that runs the hydraulic pump. After that is a 4 3/4" double v pulley on the centrifical clutch. It runs a single belt, 2 v.  37" to a 19" pulley on a 2" shaft. The band wheel on the 2" shaft is 30". So 37" between engine shaft and band shaft.
« Reply #123 on: September 11, 2018, 05:10:27 PM »
Tacks,
I wont have a clutch system on the mill unless i opt for a clutch sys like whats on a car/tck or some kind of manual xmsn piece of equipment.
Intially, i didnt have enough power with the 2 lawn/garden engines. Now i have to much power for regular style centrifugal clutches.
Temple, Tx
Offline Wintergreen Mountain
« Reply #124 on: September 23, 2018, 10:39:50 AM »
I have a 36" Turner sawmill that I purchased without the engine in 2011. I built a hydraulic drive for the saw with a 51 HP VW RABBIT diesel engine @ 2200 rpm. The engine can be 50 feet from the mill via 1" hydraulic hoses. All you hear at the mill is the saw..         15 gpm @ 1800rpm Vickers pressure compensated pump, 18 gpm hydraulic gear motor, 5 1/2" pulley driving a 15" pulley driving the 20" band wheel.      I have sawed about 24000 BF with no problems at all.   I haven't sawed for 5 years but just got it fired up again last week. Hope to saw some sticks to build a cabin with next summer.                        Also just bought a new Cooks Cat-Claw sharpener + dual tooth setter   I've sharpened 12 blades so far and they are sharpened better than any I have paid to have sharpened . I am very pleased with them. Still learning though.   Leon
1920 Ford 4x4 tractor, forks & bucket.      2010  36" Turner Mills band mill.      Cat D3C crawler dozer.       Cat 215c excavator,      Ford L9000 dump truck.
Hudson portable 360 hydraulic sawmill
Started by Conard on Sawmills and Milling
Last post August 07, 2018, 09:11:38 AM
by thecfarm
Wanted: Hydraulic portable sawmill
Started by Fightfortheright1776 on Wanted
Last post September 28, 2015, 02:37:24 PM
Sawmill plan/drawings all hydraulic.
Started by black on Sawmills and Milling
Last post November 13, 2016, 03:15:26 PM
by fishfighter
moved
MOVED: Hudson portable 360 hydraulic sawmill
Started by Jeff on Ask The Forester
Last post August 07, 2018, 07:56:20 AM
by Jeff
