Author Topic: Concrete Countertops  (Read 1698 times)
Offline DWyatt
« on: August 20, 2018, 02:33:20 PM »
Well the time has finally come in the house building process to get some countertops for the kitchen! A lot of what helped to make my decision was that I wanted an under-mount sink. This basically ruled out formica and price ruled out everything else. So i decided that I was going to do concrete. I have made a couple smaller pieces out of concrete but nothing like a full kitchen, although it is a small kitchen.
I made all my measurements in the kitchen somewhere close to 50 times and made a little sketch so I would confidently know my layout. The first few pictures are when we were pouring/the forming. I used melamine for all my forms and and 2" foam board for my sink molds. Previously we had connected the form edges using small blocks which was a pain. I decided to use pocket holes for everything which worked beautifully, a little more time consuming but a lot more exact!
Backsplash molds
Final product after a long day of pouring
It was a long day Friday, started with running to town to get the materials for the forms at 7 am and I got home a little after 11 that night but we got it all poured. My dad and one of his friends even stayed to supervise the whole time and a friend of mine who got me thinking about the idea for the counters
I took off the forms and flipped the counters Sunday as the side facing the melamine is actually your finished surface. Some help would have been great but everyone seems to disappear when the 250 lb chunk of concrete needs flipped ::)
All in all everything turned out great so far, I decided not to do any integral color and instead am using a polishing dye.  You can see how the edges have cured out a very light uniform grey and the rest is still a blochy grey as it cures.  Polishing will hopefully commence this Friday and I will update with more pictures!
Oh and a sneak peak of the cabinets, yes I still need drawer/door fronts, but drop dead move in deadline is this Saturday and we can live without those till winter :D
Offline catalina
  • Its a dogs Life!
Re: Concrete Countertops
« Reply #1 on: August 20, 2018, 02:36:53 PM »
Looking good!
Online Crusarius
  • Lost in....
    • RockModified.com
« Reply #2 on: August 20, 2018, 02:49:43 PM »
Looks nice. you just going to polish it and leave it grey?
Offline DWyatt
« Reply #3 on: August 20, 2018, 03:14:24 PM »
I actually got the sample kit of polishing dye, powder to be mixed with acetone, (meant to be put on after 800 grit polishing) it has 20 different colors. I will used a few of the dark greys and browns to hopefully get more of a texture to the look. The dyes are a new process to me so we will see how it goes, I have only worked with integral colors. I will probably use the extra colors to test how I can move the dye around after it is sprayed and how it looks spraying colors over top of each other. Then polish to 3000 before sealing.
Online Crusarius
  • Lost in....
    • RockModified.com
« Reply #4 on: August 20, 2018, 03:32:47 PM »
I always thought the die was in the concrete, not an after treatment?
Offline SwampDonkey
  • Large Tooth
« Reply #5 on: August 20, 2018, 04:31:09 PM »
Well, they will be heavy like the southern boys like. ;D
Very interesting approach.
Move'n on.
Offline Corley5
  • Wolverine, Michigan
    • Whittaker Farms
« Reply #6 on: August 20, 2018, 04:49:00 PM »
Huh...  Interesting indeed 8) ;D 8) ;D 8) 8) 8)  Looking forward to pics of the finished product.  What kind of concrete did you use ???
Offline DPatton
    • D & S Sawmill Services
« Reply #7 on: August 20, 2018, 09:20:43 PM »
DWyatt,
This is a great post and it looks as you have done a very nice job with your concrete tops so far. Im looking forward to seeing the dying process with final color and texture. Please continue to share your progress. Concrete tops can be very beautifully done and I think you have made a great choice that you will be proud of for years to come.
On a side note you said you ruled out Formica or plastic laminate tops because you wanted an undermount sink. Several years back a sink manufacturer called Karran started producing undermount sink systems for installation in plastic laminate tops. Their sink system is installed directly under the laminate creating a unique, flush, lipless, drip edge installation. Like you price was a driving factor for me when I remodeled my kitchen five years ago. I chose the Karran undermount sink in a high definition plastic laminate top and have not regretted my decision.
Thanks again for your post and good luck with completing your new tops.
TimberKing 1600, 30' gooseneck trailer, Chevy HD2500, Echo Chainsaw, 60" Logrite.
Work isn't so bad when you enjoy what your doing.
Offline DWyatt
« Reply #8 on: August 20, 2018, 09:47:46 PM »
Crusarius, There are multiple options for coloring the concrete, one of which is an integral color that changes the color throughout, there are other options for stains that are topical. One is this polishing dye that I am using, is an acetone based dye that because of the smaller molecules of the acetone compared to water, it can penetrate further into the polished surface of the concrete. Another option is for counters that aren't going to be polished, it is an acid stain and it needs the top "cream" from the concrete to react with and etch so the stain will penetrate correctly. Another option I know of can be used on very lightly polished and not polished concrete, it is similar to the acetone based stain, just a water based so it needs the larger open pores of the concrete to work.
SD, I don't think I am going to have to worry about fastening these down too much to keep them from moving  :D
Corley, I used a mix from a place in Columbus, OH called Decocrete. It is just their standard 5000 psi mix. Similar to a sakrete, except the stuff I got actually has enough cement to make a mix :D It also seems to have a lighter color which I would guess helps them to sell their colors/stains easier. I have been very impressed with the guys there, it's like they have actually used what they are selling which is a rarity anymore.
I am like a little kid on Christmas morning, I am starting to twitch from excitement!!
Offline DWyatt
« Reply #9 on: August 20, 2018, 10:03:47 PM »
DWyatt,
Very interesting DPatton, I guess I never did any in-depth research for the sink with the formica. I couldn't make sense of the seams working with water so I didn't look into it any further. As my girlfriend who has been waiting for far too long to move into the house will say, "I am always looking for the slightest reason to try something off the wall and new to keep other people's 'junk' out on our house" She says junk with a large amount of sarcasm while rolling her eyes as that is what she always has to listen to me say :D Whoops  :)
Offline Larry
« Reply #10 on: August 20, 2018, 10:04:55 PM »
I've made three under mounts with formica with the first about 10 years ago.  They all came out excellent....but it was formica.
Quote
The easy way to do it is to buy a sheet of the cheapest luan underlayment you can find.  Cut it into 3" strips.  Make a template using a hot melt glue gun.  No measuring required.  That's the way the boys that make the cultured marble counter tops do it and they get perfect fits.
I've been thinking about a concrete counter top for years and would really like to do one.  Excellent thread, keep up the good work and maybe I can learn enough to try it.
Offline ljohnsaw
« Reply #11 on: August 21, 2018, 12:41:16 AM »
 :P
I'm gonna keep an eye on this one.  My cabin will be all wood interior.  I was thinking of slabs for the counter tops but I'm a little worried about the maintenance aspect and possible scratching of the finish.  A nice concrete (even just plain grey) would be a nice contrast to the light brown woods.  Anxious to see how the sink will fit up.  Are you doing a concrete sink as well?
John Sawicky
Online Crusarius
  • Lost in....
    • RockModified.com
« Reply #12 on: August 21, 2018, 07:25:08 AM »
Thanx Dwyatt. I have always been interested in the concrete tops. Then I bought a house with granite. So, I have not had a chance to experiment.
Offline DWyatt
« Reply #13 on: August 21, 2018, 07:43:22 AM »
I am not doing a concrete sink, it is a double basin stainless sink.
Integral concrete sinks are best when doing a Glass Fiber Reinforced Concrete (GRFC). The concrete mixture actually looks like fiberglass from having so much glass fiber. In the instance of GFRC, the glass fibers are actually a complete replacement for steel reinforcing; therefore, you can go with much thinner countertops than the normal 2". It then also helps with the large stresses that a sink would see and allows you to not have a 2" thick sink. With GRFC tops you spray a thin top coat of a sand based cement mix into the forms then pack the GRFC into the forms and use what looks like a paint roller with small fingers to align the fibers in the direction of the highest stresses. Look them up sometime on Youtube, the amount of fiber in those things is incredible! They will be next on my list of projects, you know right after I get moved into the house and get it finished and get my poor mill up and running, and, and, and......... ::) ::)
Offline DWyatt
« Reply #14 on: August 21, 2018, 07:46:49 AM »
Larry, I am not sure why I never considered doing a luan/cardboard template. Thanks for the advice because the next one will be done that way:)
Offline Raider Bill
  • Who will pull the wagon when everyone rides?
« Reply #15 on: August 21, 2018, 08:22:58 AM »
I have a friend that does these professionally. Many times he puts colored glass in the mud so when he polishes them the glass comes through. They sure are pretty.
The First 60 years of childhood is always the hardest.
Offline Ed_K
« Reply #16 on: August 21, 2018, 08:41:20 AM »
 Can someone explain the luan/cardboard template? I have a counter top thats been waiting for a concrete top for three yrs. We want to use green glass in it and try to make maple leafs in the top. Thanks for showing the concrete counter tops DWyatt.
Ed K
Offline Larry
« Reply #17 on: August 21, 2018, 09:08:04 AM »
Just lay the luan strips on top of the cabinets flush with the ends and walls.  Glue them all together with a hot melt gun.  Besides no measuring, this method also corrects for out of square walls.  Often a wall is bowed and this can be noted on the template.
Offline DWyatt
« Reply #18 on: August 21, 2018, 11:48:33 AM »
It's a whole lot cheaper, and less delay to cut a piece too small with luan than it is with the actual countertop, no matter what the material may be. Then just make your forms match the template :)
Offline Banjo picker
  • A goal without a plan is just a dream. Elbert H.
« Reply #19 on: August 21, 2018, 09:16:47 PM »
Looks good.  You just might inspire me to give it a try.  I thought when we remodled the kitchen and I layed tile for counter tops that I would never have to mess with that again.  Wrong.  Banjo
Cooks AC 36--Prentice 210C--Morgan edger--Kubota M7040 with loader--Case 580 K with extendahoe--Case 850C dozer--Int 1700 series twin cylinder dump/log/flatbed truck--logging arch--2 Logrite mill sp.--Cat claw sharpening system--And a bulldog to make sure it all stays here.
Started on new countertops.
Started by hackberry jake on General Woodworking
Last post August 31, 2018, 09:24:47 PM
by Peter Drouin
concrete
Started by thedeeredude on Timber Framing/Log construction
Last post November 03, 2005, 12:26:30 AM
by mometal77
concrete
Started by coxy on Firewood and Wood Heating
Last post July 18, 2016, 06:59:53 PM
by stumper
Concrete will not set.
Started by DR_Buck on General Board
Last post February 01, 2018, 07:09:05 AM
by barbender
