Council Tool
Author Topic: Franklin 120 Forwarder with a Roof Mount Loader.  (Read 1877 times)
Offline c greenham
« on: August 21, 2018, 11:20:40 AM »
Hi All,
I'm looking for some info on a Franklin Forwarder with a roof mount loader.  Not sure of the year.
Any one have any experience operating one? What common issues to look for when purchasing a machine like this.
Any Help greatly appreciated..
Offline nativewolf
  • Forester
Re: Franklin 120 Forwarder with a Roof Mount Loader.
« Reply #1 on: August 21, 2018, 05:19:49 PM »
If you search the forum you'll find several discussions on the franklin forwarder.  I looked at one that was not roof mounted but some folks have them and commented.  Basically, you have great vision and unfortunately you will wear hydraulic fluid.
It seems you've found what should be a very inexpensive machine, if I was handy and the price was right I'd have one like that for small spaces.  I'm not handy and the price on the one here in VA got pretty high in auction so I walked away from the bidding.
Liking Walnut
Offline Corley5
  • Wolverine, Michigan
    • Whittaker Farms
« Reply #2 on: August 21, 2018, 08:51:45 PM »
That's got a different style loader than my 132.  They work good but don't wear good clothes operating them.
Offline Corley5
    • Whittaker Farms
« Reply #3 on: August 21, 2018, 08:57:19 PM »
Look for slop in the pins.  All the pins.  Loader, blade, center.  Listen for noises that shouldn't be there.  Growls, clunks etc.  Play in shifting linkages.  Do the brakes work?  Detroit or Perkins engine?  Looks pretty straight :)  I don't like the exhaust sticking up like that.  It'll get ripped off.
Offline Corley5
    • Whittaker Farms
« Reply #4 on: August 21, 2018, 08:58:40 PM »
What are the milk crates for ???
Offline c greenham
« Reply #5 on: August 23, 2018, 12:26:43 PM »
I think the milk crates were used as a place to carry the chain saw.
Offline c greenham
« Reply #6 on: August 23, 2018, 12:29:03 PM »
It has a perkins engine.
Online barbender
« Reply #7 on: August 23, 2018, 09:12:27 PM »
To guard the exhaust!😁
Online GRANITEstateMP
  • LIVE FREE OR DIE
« Reply #8 on: August 24, 2018, 10:15:42 AM »
Ah, milk!  ;D
Hakki Pilke 1x37
Kubota M6040
Load Trail 12ft Dump Trailer
2015 GMC 3500HD SRW
1999 New Holland TC29
Online Logger RK
« Reply #9 on: August 24, 2018, 09:37:17 PM »
Maybe harvesting Almond Milk?
Offline mike_belben
  • Pulp Friction
« Reply #10 on: August 24, 2018, 10:06:31 PM »
Walnut shaker.  You just scooch up under there, bang the tree with the boom and profit.
Revelation 3:20
Offline bushmechanic
  • Someone else has it worse than you.
« Reply #11 on: August 26, 2018, 06:25:24 PM »
That boom is a Cranab 6025 with an extension. We had a lot of those back in the 90's they held up well but in some of the hills we were on were too much for them and they would break a tooth off the swing mast.
Offline c greenham
« Reply #12 on: September 14, 2018, 12:25:49 PM »
Got Her Home!!
br>
Offline Puffergas
    • Puffergas
« Reply #13 on: September 14, 2018, 02:14:13 PM »
Those photos are killing me.  :)
Somewhere 20 miles south of Lake Erie.
GEHL 5624 skid steer, IHC 300 Utility, Timberjack 225D, Burg Bandsaw mill, Steiger Bearcat II
Offline mike_belben
  • Pulp Friction
« Reply #14 on: September 14, 2018, 09:48:52 PM »
Looks good.  Should be fast with those racing slicks!
:laugh:
Revelation 3:20
Online barbender
« Reply #15 on: September 14, 2018, 10:39:25 PM »
Nice score! A little paint and it will clean right up, go through those hoses over the cab and save yourself some oil showers down the line.
Offline thecfarm
« Reply #16 on: September 15, 2018, 05:59:15 AM »
I like it!!
Offline Corley5
    • Whittaker Farms
« Reply #17 on: September 15, 2018, 07:34:32 AM »
Good looking old buggy 8) 8) 8)  X2 on the hoses over the cab.  I've been showered.
Offline mike_belben
  • Pulp Friction
« Reply #18 on: September 15, 2018, 10:47:53 AM »
Get some firehose, and slip it over any hoses that put you in danger as you replace them.  Itll keep sun degrading down, and reduce your chance of getting a fluid injection or a serious oil bath.
Hoses are replaced periodically and ive been lucky enough to get a few unused spools free.  Works great. Way cheaper than spiral wrap. Ask around at fire depts or any fire service companies for expired or damaged hose.
Revelation 3:20
Offline c greenham
« Reply #19 on: September 15, 2018, 01:35:23 PM »
Thanks for the idea on using a fire hose on the lines great idea.
Offline mike_belben
  • Pulp Friction
« Reply #20 on: September 15, 2018, 03:58:03 PM »
Sure no problem.
Speaking of oil baths, the return hose just jumped off the barb on my splitter and showered the entire pile.  Customers gonna love the BTUs in that load. LOL
Revelation 3:20
Offline thecfarm
« Reply #21 on: September 15, 2018, 06:03:46 PM »
 ;D  ;D
Offline c greenham
« Reply #22 on: September 16, 2018, 05:27:05 AM »
Anyone have any info on the braking system for this unit?? All that I can find is the brake pedal it seems the master cylinder as been removed.
The blade does work fine but I would like a brake, this is the first forwarder I have ever owned or operated.
Offline Corley5
    • Whittaker Farms
« Reply #23 on: September 16, 2018, 09:02:22 AM »
It may have internal brakes in the transfer case.  That's where my 132 has them.
Offline c greenham
« Reply #24 on: September 18, 2018, 01:45:31 PM »
The Brakes haven't worked in some time, the blade is half worn away from being used as a brake.
Thinking of trying to install a caliber system as mentioned on here in previous posts.
Offline c greenham
« Reply #25 on: September 21, 2018, 12:41:43 PM »
Anyone got any tips on removing the blade?
roof mount forwarder loader
Started by SteveB on Forestry and Logging
Last post March 13, 2006, 05:46:10 PM
by Reddog
Rear Mount Loader
Started by LaegersATC500R on Forestry and Logging
Last post June 22, 2016, 11:01:29 PM
by killamplanes
170 Franklin Forwarder
Started by bmwood on Forestry and Logging
Last post October 30, 2015, 08:17:27 AM
by bmwood
Franklin 132 Forwarder
Started by lostyooper6 on Forestry and Logging
Last post July 16, 2011, 06:25:05 AM
by lostyooper6
