Baltic Abrasives Technologies
Author Topic: clearing the land  (Read 3027 times)
Offline JB Griffin
Re: clearing the land
« Reply #20 on: September 03, 2018, 11:16:55 PM »
Never seen anyone use a bucket like that before.  Curious to the reasoning behind that.
We always set the bucket flush to slightly below grade and drive foward.
2000 LT40hyd remote 33hp Kubota, 160 Prentice, Frick 2 saw gang edger, Wright W-37 ABG, Suffolk dual tooth setter, Cat claw single tooth setter,'96 F-250 7.3 PSD 4x4, CS-590 Echo, MF 20c, M681 Memo.
Over 2.5 million bdft sawn with a Baker Dominator and counting.
Offline thecfarm
« Reply #21 on: September 04, 2018, 09:34:35 AM »
I wanted to just get the so called,mounds of ferns and rocks. I did not want to run into the ground all that much.I tired forward a few times. Well more than a few. ;D But backwards works the best for me,in that area.I just felt I was able to skim the stuff that I did not want off the top backwards.
Offline mike_belben
  • Pulp Friction
« Reply #22 on: September 04, 2018, 11:32:06 AM »
I use backdrag constantly.  Every bucket heel should have ripper teeth.
Revelation 3:20
Offline thecfarm
Re: clearing the land,done!!!!! video added
« Reply #23 on: September 04, 2018, 11:51:09 AM »
Yes,done. That is a nice word.
Offline Papa1stuff
  • Can I trade for an LT70?
« Reply #24 on: September 04, 2018, 11:55:02 AM »
Happy Birthday my friend  8) 8) 8) 8) Have a great day!!
1987 PB Grader with forks added to bucket
2--2008 455 Rancher Husky
WM CBN Sharpener & Setter
Offline thecfarm
« Reply #25 on: September 04, 2018, 12:07:59 PM »
Why thank you.
one more video
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #26 on: September 04, 2018, 03:09:11 PM »
Thank you Ray for taking the time to show your work.  Of course it that was my property there would be Sweetgum trees and no rocks.  ;D
Offline Andries
  • Making buildings out of big curvy logs
« Reply #27 on: September 05, 2018, 09:34:33 AM »
Ray, I'm enjoying your videos.
Thanks for taking the time and effort to do them.
Maine looks a lot like Central and Eastern Canada to my eye.
Going back to what Mike Belden said about "every bucket should have ripper teeth on the heel".
That's new to me. Have to Google that.
LT30G24
Ford 545 Series loaders
Stihl chainsaws
Offline mike_belben
  • Pulp Friction
« Reply #28 on: September 05, 2018, 12:05:59 PM »
You may be looking for a while.  None of them do.
Revelation 3:20
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #29 on: September 05, 2018, 12:27:23 PM »
Offline Andries
« Reply #30 on: September 05, 2018, 02:03:29 PM »
Yep . . . now you've got me scratching my head.  :D
LT30G24
Stihl chainsaws
Offline JB Griffin
« Reply #31 on: September 05, 2018, 08:54:05 PM »
We back drag around here alot too, always after the "heavy" work is done, to smooth up.
Offline mike_belben
  • Pulp Friction
« Reply #32 on: September 05, 2018, 09:09:11 PM »
I want a smooth front edge bucket with ripper teeth on the back of it.  Drive backward with the bucket curled up and push down to loosen hardpan or compacted gravel.  Drive forward to scrape it up or backdrag with the front edge to smooth it.   Talking skidsteer.. I dont know if it'd be useful on a tractor but i dont like needing two buckets to do the job if both surfaces could be put on one.
I hate the chatter of trying to cut hard material going forward on a worn out machine.  The cutting edge gives too much leverage against the curl cylinder and the machines are too frontend light anyway so they want to wheelie when you are pushing forward.  Weight is biased like 70% to the back tires when empty bucket.  Putting teeth on the heel moves the force really close to the pivot and gives the curl cylinder a ton of advantage to hold things still.  When i use the heel to spread nothing chatters. But its just a flat surface and cant do much.  It much prefer there was small teeth to rake up roots and cut sod.
Revelation 3:20
Offline thecfarm
« Reply #33 on: September 05, 2018, 09:35:16 PM »
Good idea Mike. That soil you see in the video is soft.A spade would go into that easy. As I said in the video that whole place was diffeant.I dug a few good size rocks out of there,but the soil looked diffeant in the holes. Most places around here I remove the topsoil and I am into to rocks. It starts out with small ones,golf ball size and gets bigger as I go down. And harder too.
I really need a excavator or a backhoe. This digging a 6 foot hole,and sometimes much bigger,the width of my bucket,to dig a rock out is a bother to say the least. I've had rocks the size of my head hold me up from getting a rock out. A backhoe with a narrow bucket,would really help me out.
Offline mike_belben
  • Pulp Friction
« Reply #34 on: September 05, 2018, 09:55:38 PM »
I know whatcha mean, loaders are a pain for that type of work.
A stump bucket with a grapple would work a ton better for you.  Im building a stone retaining wall now and its the next best thing to an excavator.  So much dexterity, and all the power focused into a 12" wide tooth edge.  You can get at the exact spot you want without a rock thats 2 feet away sticking its nose into your cutting edges business.
Revelation 3:20
Online Crusarius
  • Lost in....
    • RockModified.com
« Reply #35 on: September 06, 2018, 11:00:48 AM »
I agree about the sharp teeth on the back side of the bucket. That would be great. my problem is there are a lot of times I don't want them in the way especially using the bucket for lifting logs.
I use my 3pt box blade for almost everything landscape related now. when dragging behind the tractor is smooths real nice but as you guys said when pushing with it it sure is hard on the tractor.
I wonder if its worth making a set of teeth and mounting them on the back edge of the bucket. Could actually put them on a hinge and just flip them up flat against the back of the bucket when I do not need them in the way.
Offline mike_belben
  • Pulp Friction
« Reply #36 on: September 06, 2018, 09:58:43 PM »
I did make a sort of cutter comb that bolted onto the back of a "dozer blade" on my deere 140 for backdragging.  Say you wanted to put a trail through a spot with high ferns and brush without wrecking the ground, it was excellent at that.  One push forward to lay them down and one or two drags back to cut them off.  But it didnt take off the topsoil or duff mat.   just severed the greens and raked leaves.
The teeth were just slugs from a knockout slot punch.  And obviously the sharpened angle irons.
These little grubber heels were later welded to the side plates to be removable.  Theyd pinch a sappling when you hooked it and reversed.  promptly wacking you in the face before uprooting most times.
Corner cutters worked incredible too.
Revelation 3:20
Online Crusarius
  • Lost in....
    • RockModified.com
« Reply #37 on: September 07, 2018, 07:47:15 AM »
those look angry. I like it :)
Offline mike_belben
  • Pulp Friction
« Reply #38 on: September 07, 2018, 08:10:51 AM »
Yeah, great for grubbing your toe if you werent careful walking by.  People think a hitchball sneak attack is bad...
Sharp corners and sideplates are really handy for breaking up dirtpiles and hills that have over grown.  The severing action cuts the rooty junk that holds it all in place.  Just keep peeling dirt off with the corner and pushing it out.
Revelation 3:20
Offline DeerMeadowFarm
« Reply #39 on: September 07, 2018, 11:32:47 AM »
Nice work Ray! Hardly any rocks compared to what you're used to seeing. I do think a stone bucket would help you out. I have one and it works great for that kind of reclamation work.
Clearing some Land
Started by DonE911 on General Board
Last post November 12, 2005, 02:52:28 PM
by pappy
Land clearing
Started by florida on Forestry and Logging
Last post May 19, 2017, 10:38:27 PM
by TreesLogan
Land Clearing
Started by KjBarnwood on Forestry and Logging
Last post November 05, 2010, 02:40:10 PM
by Skiddah
land clearing
Started by br389 on Forestry and Logging
Last post May 29, 2014, 05:27:59 AM
by timberlinetree
