TURBOSAWMILL GIANT SALE ON NOW UNTIL OCTOBER 31st
Author Topic: Diesel Fuel Additive  (Read 1475 times)
Offline Runningalucas
Re: Diesel Fuel Additive
« Reply #20 on: August 25, 2018, 10:54:56 PM »
WMO, needs to be centrifuged to get the heavy metals, and particulates out.  I know a lot of guys swear by ATF for getting gummed up injectors, and other mechanical injection parts freed up; I've personally done this.  You can go read any mechanical injected diesel forum page, and the ATF is usually the first thing to get into a diesel engine that's sat for a long time; take the fuel filter off, fill it, crank the engine a little, and let it sit for 24 hours.
I'm thinking the 'don't use it, and it won't make a difference' is on the newer electronic/common rail engines.  These engines cost bookoo bucks when there's anything in the new low sulfur diesels; not a good thing for gas to be pumped into them.
Online barbender
« Reply #21 on: August 25, 2018, 11:04:39 PM »
The ball scar test I read had better results for biodiesel than any other additive, so it's great for lubricity. Our diesel in MN is all blended at least 5% bio, I don't worry about adding anything else at all except anti-gel additives in the winter. From what I understand, ULSD has lubricant reblended into it at the refinery. If they didn't, it would take the pump out of any diesel, whether new or old. I think all the concern about it is much ado about nothing, or even worse, folks get so concerned about a non existent problem that they create a real one by dumping junk in the fuel tank that doesn't belong there. My 02😊
Offline petefrom bearswamp
  • made 70-11 and still feelin pretty darned good!
« Reply #22 on: August 26, 2018, 07:53:16 AM »
Lots of quoting of empirical studies  and OMTs (old mechanics tales) on this thread
I use a commercial treatment only on the late fall and early spring as I dont saw in the winter.
Dont know the brand.
LT40SHDD51
Kubota 900 RTV
Polaris 550 Sportsman ATV
1 Husky 1 gas Echo 1 cordless Echo
241 acres of woodland
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #23 on: August 26, 2018, 08:27:03 AM »
Yes barbender, I read some of the same thing last night.  Biodiesel is always at the top of the list, and I also read that early on with the ULSD there was a lubricity problem but now the  proper lube is being added at the refinery or wherever to protect today's engines.
So my concerns were for naught and once again the knowledge level of the FF surpasses hype.  Now I have a $33 jug of Stanadyne that I guess that I will go ahead and use and chalk it up to lesson learned.  :P
Offline Southside logger
« Reply #24 on: August 26, 2018, 09:37:43 AM »
Magicman - just asking - but when you say todays engines are protected, does that include the older technology like most are speaking of?  My understanding is that the metal in those older pumps and injectors is not as hard as the late model ones, thus the issues with wear given the lack of lubrication.
Woodmizer LT35 sawmill, KD250 kiln, BMS 250 sharpener and setter
Online mike_belben
  • Pulp Friction
« Reply #25 on: August 26, 2018, 01:17:24 PM »
Call your favorite pump shop and ask them their opinions, they measure plungers and barrels all day long instead of just googling for the answer.  I use wvo as a REPLACEMENT for fuel, not a conditioner.  Ive had no trouble on any fuel yet.
Wives tales sell a lot of product.
Revelation 3:20
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #26 on: August 26, 2018, 03:36:46 PM »
Mike, I understood about your biodiesel fuel, but there are also biodiesel additives which are what I was addressing and they are always on the top of the studies.
Sadly most of the articles & studies are written and done by manufacturers peddling additives.
Southside, your question is what started me looking to begin with because the only Diesel engines that I have are older vintage.
I went back and read again and it said "high pressure common rail engines".  "The fuel refiners had to scramble to provide solutions for consumers (diesel fuel users are the consumers in this case). This is where diesel lubricity additives come in. The newly created need in the marketplace forced refineries and fuel suppliers to use more lubricity additives to ensure these ultra low sulfur diesel fuels didn't destroy engines."
I also read that it is not the actual sulfur that was providing the lubricity, but the process of removing the sulfur also reduced the lubricity.  Kind of a collateral kill.
Anyway I have older engines and it will not harm them nor break me to add the Stanadyne to the fuel.
Online barbender
« Reply #27 on: August 26, 2018, 05:32:36 PM »
Magic, one other property of biodiesel, as I understand it, is that it can a cleaning effect on your fuel system. That cuts both ways, it can help keep the system clean, but if you start running it on an older fuel system it can break lots of stuff loose and plug a lot of filters. We saw that up here the first year it was mandated to be blended in our fuel. We got the first cold day, and there were trucks on the side of the road everywhere! Between it plugging filters and gelling the fuel, it caused a ton of problems, to the point that the state had to do an emergency rescinding of the mandate for our winter fuels for a few years. Now we've all caught up with it, and we're running that 5-10% blend (mandated) year round without issue.
Offline scsmith42
    • Whispering Pines Farm
« Reply #28 on: August 26, 2018, 08:35:51 PM »
Engine oil standards also changed in the last several years for diesel engines, partially in response to the reduced sulfur in the fuel.
Tom's 3638D Baker band mill
Online barbender
« Reply #29 on: August 26, 2018, 10:05:22 PM »
That's right, the new spec is for 5w-30, I can't remember, is it CK-4 now? The 5-30 is not backwards compatible in a lot of older engines. I was running a 2009 Ponsse forwarder with a 6 cylinder Mercedes and about 14,000 hours. Ponsse switched over to the new oil, I was sure my engine would start burning it but no problems. Sometimes have to add 1/2 to 1 gallon when approaching the 500 hour oil change, no different than the 5w-40 we were running previously.
Online mike_belben
  • Pulp Friction
« Reply #30 on: August 26, 2018, 10:09:28 PM »
Just to clear up a few points..  Straight 100% Waste veggie oil in a two tank system is what i ran in the dodge.  Start in diesel, get up to temp, switch over to grease when its 160F or hotter.  Stop on diesel to flush lines out.
I have also blended wvo into stock diesel fuel tanks.  Copper senders are the devil.
"Biodiesel" is a wvo base stock that has had the glycerin (hippie soap) removed by a cracking process that uses methanol and lye (sounds green right) to remove the glycerin and reduce the viscosity to a sprayable viscosity.  Afterward the brewer washes the methanol out of the broth.  If this isnt done thoroughly youll have a lot of alcohol remaining in your fuel and that swells and eats rubber.  Its a solvent.
Cold plugging is generally gonna be a consequence of plant oils having a lower cloud point then petroleum.
Sidenote of the day.  There are umpteen million dollars of grants for all the clean fuel initiatives you can dream up, and theyre all a scam.  Get caught running one tank of untaxed wvo and youre in big trouble.  Yet i have tried paying the tax via the dept of revenue in THREE states now.  Nope, we cant do that sorry.
The green wealth transfer scheme at work.
Revelation 3:20
« Reply #31 on: October 19, 2018, 08:08:57 PM »
Mel from Conestoga Diesel in PA, sells performance pumps for the older 7.3 idi, and I believe powerstroke; at least last I checked, his opinion was that the newer fuels do require supplemental additives.  If memory recalls correctly, he recommends the stanadyne additive.
Offline DPatton
« Reply #32 on: October 19, 2018, 10:26:20 PM »
The good part about what your saying is it was plugging filters. Therefore it wasnt plugging injectors or causing performance robbing abrasive deposits. In my area of the country we start preparing for low quality fuel issues and cold weather around November 1st. Switching to a higher quality winter blend and diesel additives helps assure we never have that problem.
TimberKing 1600, 30' gooseneck trailer, Chevy HD2500, Echo Chainsaw, 60" Logrite.
Work isn't so bad when you enjoy what your doing.
Offline woodmaker
« Reply #33 on: October 21, 2018, 08:56:45 PM »
I have many diesels,from the early 70's to the early 2000's. All run straight pump low sulfur fuel in the summer,and get dosed with Howes beginning this time of year until March or April. The colder the forecast ,the more Howes they get. So far,I have had no pump or injector problems
franklin q80,builtrite 40,husky 372,sachs dolmar 123, dozers,excavators,loaders,tri-axle dump trucks ,autocar tractor with dump,flatbed and detachable trailers, and 8  f350 diesels
2 stroke fuel additive
Started by Dean Hylton on Chainsaws
Last post January 28, 2005, 05:08:26 AM
by scottr
Kohler gas engine fuel additive/treatments
Started by AshArb on Sawmills and Milling
Last post October 23, 2016, 10:07:23 PM
by Bluejay27
xylene/acetone/synthetic oil diesel and gas additive???
Started by shinnlinger on General Board
Last post October 17, 2009, 06:50:18 AM
by Toolman
moved
MOVED: Rentech opens synthetic fuel plant in Colorado Jet & Diesel fuel
Started by Tom on General Board
Last post August 07, 2008, 11:11:44 AM
by Tom
