Author Topic: for those that have a pond,...  (Read 1834 times)
Offline moosehunter
  • Every once in a while
    • Saw it Coming
« on: August 24, 2018, 08:45:17 PM »
If you keep the shore trimmed how do you do it?
I use a Stihl (I think it is a FS 45) trimmer with a metal tri-blade that does a great job of cutting everything in its path. The problem is that running it kills my back with all the bending to reach the waterline.
What do you use to keep the weeds and cattails at bay?
Chemicals are a absolute no.
We do use barley straw in the pond, that really helps with plants in the pond.
mh
If it is true that we learn from our mistakes, I must be Brilliant!
Offline gspren
Re: for those that have a pond,...
« Reply #1 on: August 24, 2018, 08:58:16 PM »
I use a hedge trimmer attachment on my Stihl Combi, it doesn't throw stuff like a blade or strings and then I use a rake to pull out anything that fell in. I don't know if that's better but it's what I do.
Offline garyfg
« Reply #2 on: August 24, 2018, 10:04:54 PM »
wait till you 67
Offline Papa1stuff
  • Can I trade for an LT70?
« Reply #3 on: August 25, 2018, 05:15:33 AM »
wait till your 83 ;D
1987 PB Grader with forks added to bucket
2--2008 455 Rancher Husky
WM CBN Sharpener & Setter
Offline LeeB
« Reply #4 on: August 25, 2018, 06:27:57 AM »
OK, I'll take your advise. If I ever get a pond, I'll wait until I'm 83 to trim it.
Offline DelawhereJoe
  • Trapped in Delawhere
« Reply #5 on: August 25, 2018, 07:16:07 AM »
Someone on here, I can't remember who, would chain 2 long pipes/poles from there tractor bucket and suspend an old push mower from the end of it to mow around there pond.
Offline Brad_S.
« Reply #6 on: August 25, 2018, 10:38:34 AM »
 :D
I want to see a video of that!
Offline florida
« Reply #7 on: August 25, 2018, 11:14:55 AM »
I have a small pond with steep banks and have the same problem keeping it trimmed. I've found that working from the middle of the bank and sweeping the trimmer sideways to the bank is easiest and least tiring. Alternately I try to get one of my sons or my SIL to do it!
General contractor and carpenter for 50 years.
Online mike_belben
  • Pulp Friction
« Reply #8 on: August 25, 2018, 01:51:24 PM »
When youre 83 you wont need to trim it, you'll need to log it.
Revelation 3:20
Online Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #9 on: August 25, 2018, 02:06:15 PM »
The worst thing that I did at my pond was planting Cypress trees.  Spraying will not be "out" for me because I will have to kill all of the roots when the trees come down....very soon.
Cypress knees are bad dudes.  :-\
Offline Bruno of NH
« Reply #10 on: August 25, 2018, 03:00:39 PM »
I let my pond have the woodsy look  :)
thomas 8013 mill ,Mahindra 3540 cab tractor loader  Dump trailer  and lot of contracting tools
Offline lxskllr
  • dummy with saw
« Reply #11 on: August 25, 2018, 03:36:12 PM »
I don't have a pond, and most people wouldn't like my laissez faire management style, but when I find myself fighting nature, I question my goals and tactics, then see where I can adjust to make my life easier. Options for me would be letting some of it grow wild(cattails are attractive, and food!), then keep a small portion clear for whatever(view, fishing, boat launch...). Maybe split the difference and selectively cut to keep it semi wild. Lots of options if you aren't going for a Southern Living cover.
My overall philosophy is nature always wins, and will outlast me. If I can change myself to get along, it'll make things easier for all involved, and will probably be objectively better, if not subjectively.
« Reply #12 on: August 25, 2018, 04:34:33 PM »
How about some goats ?
Offline TKehl
  • Certified Contrarian
    • Kehlhof Ranch
« Reply #13 on: August 25, 2018, 09:27:25 PM »
Sheep would be better.  Goats prefer mostly leaves not grass.
We turn our cows in there periodically and goats to tame the herbacious growth.
Online mike_belben
  • Pulp Friction
« Reply #14 on: August 25, 2018, 09:53:00 PM »
Dump some tires, cinder blocks, shingles, glass and 55gal chemical drums around the perimeter.  Insist that this is modern industrial art.  And stand your ground on that.
Your wife and neighbors will will ask that you fertilize instead of mow thereafter.  Problem solved.
Revelation 3:20
Offline Southside logger
« Reply #15 on: August 25, 2018, 10:53:53 PM »
Shooting coyotes that want to eat my chickens seems to keep the grass short around one of our ponds.
Online WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #16 on: August 26, 2018, 08:22:01 AM »
Leave it thick to make it harder for trespassers to fish  ;D.
Offline No_Dude
« Reply #17 on: August 26, 2018, 05:18:48 PM »
At risk of sounding dumb, I dont get it  :) :)
« Reply #18 on: August 26, 2018, 08:25:53 PM »
A little poetic license there as in I have so many yotes after my chickens around the pond that the bullets keep the grass mowed. Obviously not quite that bad, but it sure is close to it. We are overrun with them at times. Middle of the day I have seen them come out and grab a bird, of course the only thing I have close by is a sharp stick when that happens.  >:(
Offline Stuart Caruk
  • Gender: Female
  • Woodmizer LX450 DieselStationary timber processing
« Reply #19 on: August 26, 2018, 10:12:18 PM »
I use a Bobcat with a 5' wide brush cutter. For the tough to reach places I use my excavator with a flail mower on the end. Makes quick work of a tough job. I just upgraded to a bigger excavator so I could get AC in the summer.
Stuart Caruk
Wood-Mizer LX450 Diesel w/ debarker and home brewed extension, live log deck and outfeed rolls. Woodmizer twin blade edger, Barko 450 log loader, Clark 666 Grapple Skidder w/ 200' of mainline. Bobcats and forklifts.
Log Pond?
Started by krusty on Sawmills and Milling
Last post February 12, 2007, 02:47:06 PM
by Minnesota_boy
pond ice
Started by bandmiller2 on Chainsaws
Last post March 10, 2015, 09:50:57 AM
by John Mc
Fish Pond
Started by Ken on The Outdoor Board
Last post July 15, 2015, 09:02:29 PM
by Ken
Something creepy is in the pond.
Started by Mooseherder on General Board
Last post November 25, 2007, 10:38:20 PM
by Bow Saw
