Author Topic: Wide slabbing band mill  (Read 2809 times)
Offline Busysawyer
« on: August 25, 2018, 09:31:30 PM »
We are considering adding a wide slabbing band mill to our operation.  Looking for options and opinions.  I'll list the options I've found in the order of price. Highest to lowest.
The big boy woodmizer wm 1000, Hudson mills oscar 60 and cooks sw62. I've been doing well the last couple weeks on the smaller slabs I'm able to cut on the 70 wide but I'm missing out big time on the single slab table market.  I would really like the wm 1000 but its pricey.  Does anyone know any other options besides the three listed above? Anyone here running one of these three?
Even a blind squirrel finds a nut every once in awhile
Offline 4x4American
  • Team red, white, blue and orange
    • Website Link
Re: Wide slabbing band mill
« Reply #1 on: August 25, 2018, 09:41:38 PM »
Boy, back in my day..
Online Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #2 on: August 25, 2018, 09:43:04 PM »
Member @redbeard has an Oscar60.
Offline nopoint
« Reply #3 on: August 25, 2018, 09:53:40 PM »
Saw a tru cut in operation today for the first time. This one was totally manual but solidly built deck etc. needs power feed in my opinion, think it might be an option on more expensive versions. Slabing some 4 wide oak did a nice job.
Online nativewolf
« Reply #4 on: August 25, 2018, 10:24:28 PM »
You could always do what Matthew Cremona did:
https://www.youtube.com/playlist?list=PL0dX5redvVZQT-bJ-HNfrJEXlQJleCwun
His mill is very nice indeed, less than 10k
Liking Walnut
Online nativewolf
« Reply #5 on: August 25, 2018, 10:32:35 PM »
we've been doing a bit of slabbing on a Lucas swing blade mill with the dedicated slabber, works well.
Liking Walnut
Offline Bruno of NH
« Reply #6 on: August 26, 2018, 03:49:47 AM »
Thomas Bandsaw mills has a wide unit.
Tru-cut has a full powered up/down
With power feed unit.
A member has a Tru-cut
thomas 8013 mill ,Mahindra 3540 cab tractor loader  Dump trailer  and lot of contracting tools
Offline Satamax
« Reply #7 on: August 26, 2018, 07:25:14 AM »
Hey Busysawyer.
Can't you find a cheap enough WM1000?
Otherwise, you could may be find a Loglogic autotrek in the states?   Or a CD8 from Brenta.
If ever one made it to the states.
I have the little sister, a CD4.
Or even may be import one?
There's two for sale on Fordaq for the moment. One mobile, one fixed.
French CD4 sawmill. Latil TL 73. Self moving hydraulic crane. Iveco daily 4x4 lwb.
Offline Busysawyer
« Reply #8 on: August 26, 2018, 08:28:05 AM »
4x4 I have ten kids and am trying start up and run a new business. I dont have time to pick my nose, no way I have time to build something.
Mm, thank you for the info.
Everyone else thank you for letting me know about some other options to research and consider. I'm not sure if I should go with one of the more expensive options or go with a more affordable option for now. I have a local business who wants to buy 30 slabs per month in the 40in plus range and a few other buyers that need 2-3 per month. Then there is the people looking for a single slab at full retail.
Offline terrifictimbersllc
    • Terrific Timbers LLC
« Reply #9 on: August 26, 2018, 11:34:18 AM »
I have a Peterson WPF10 with the slabber attachment.  Mostly chain slabbing is what I use it for.  I think you would do well with it or the Lucas equivalent if you were set up at home base and could handle the logs and slabs.  The swing mill/add on slabber  with either mfgr is more expensive than a dedicated slabber which aren't that expensive even new and look like would serve your needs well.
Wide bandsawing is a different story.  Look what the guy who is building one in the link given above has gotten himself into.
DJ Hoover, Terrific Timbers LLC,  Mystic CT  2001 WM LT40SHDD (42HP Kubota, Accuset2, FAO's, Lubemizer, debarker), Peterson WPF 10-30 with chain slabber. Logrite fetching arch, WM BMS250 sharpener/BMT250 setter.  2001 F350 7.3L PSD 6 spd manual ZF 4x4 Crew Cab Long Bed
Offline Satamax
« Reply #10 on: August 26, 2018, 12:36:16 PM »
Busysawyer, i wonder if you are aware of this thread.
I cut my sawmill in half! in Sawmills and Milling
Offline shenandoahsawmill
« Reply #11 on: August 26, 2018, 03:43:22 PM »
I am not sure that a narrow  blade, bandsaw mill (below 3" wide)  is up to the task of cutting wide slabs on a production basis. With everything perfect ( bandsaw blades very sharp, aligned well and slow feed rate) this might be possible. If one of these variables is not perfect, all bets are off. A wide bandsaw mill of 5" or wider is more forgiving in all three of these parameters. You might want talk to a WM 1000 owner/operator who saws on a production basis for more info.
Offline Satamax
« Reply #12 on: August 26, 2018, 06:08:33 PM »
shenandoahsawmill, i have a wide band. 5 inch or so, with 4 inch wheels. All metal construction. and i can tell you that from what i see on other's videos with narrow bands, wide band, thick kerf, when it gets dull, is no better than narrow thin kerf blades.
When the blade wants to cut wavy, it does!
« Reply #13 on: August 26, 2018, 08:05:20 PM »
I started sawing slabs with a double ended CSM with 2 090s then switched to an LT 40 then a Peterson with clip on slabber then the 5" wide double cut band mill with a 42" throat that I use now. I would prefer to never go backwards through that progression. Yes the 5" wide band cuts wavy boards occasionally when I am really pushing it or it is very dull but it stays accurate much longer and saws 8 times faster than the CSM and 2 to 3 times faster than the narrow band.
Offline gmmills
« Reply #14 on: August 26, 2018, 09:40:49 PM »
   Give Baker a call. They were demoing a wide slabbing mill at the Richmond Expo this year. Impressive machine. Very well built. The Hudson is way too light for any real repeatable accuracy at any productive rate. I have seen one up close a couple of years back.  You could grab on to one of the four posts of the head frame and were able to shake the whole flimsy head.
Custom sawing full-time since 2000.
WM LT70D62 Remote with Accuset
Sawing since 1995
« Reply #15 on: August 26, 2018, 09:59:53 PM »
Here are a couple of pics. of the Baker at the Richmond expo;
Offline redbeard
    • whidbeysawmill.comwww.whidbeysawmill.com
« Reply #16 on: August 27, 2018, 12:17:11 PM »
Not sure why you think the Hudson 60 mill is light duty, I find it quite durable and with the 34 hp Kabota diesel it will make a pile of 48"-50" wide slabs quickly.
I have had no problem with using .055 x 1-1/2" band blades.  Slabs are one of the many uses of having a wide head sawmill, breaking big logs down to manage better on our other sawmill is the main use. Finding figured wood in wide crotches is another. Only time there has been a problem is when quartering 40" dia + logs when taking a center cut at the pith you have to put some wedges in as your milling or it will pinch blade as you exit log, it has happened twice in a dozen times. There's 28" of room above the blade that's some heavy wood. Especially when milling 30' + beams.
As far as Slab production I guess it comes down too how many slabs you wanna mill in a day.
Most slabbing mills including the Hudson 60 will definitely out slab the energy you have of handling the slabs the mill can produce in a day.
Whidbey Woodworks and Custom Milling  2019 Cooks AC 3662T High production band mill and a Hud-son 60 Diesel wide cut bandmill  JD 2240 50hp Tractor with 145 loader IR 1044 all terrain fork lift  Cooks sharp
Offline Busysawyer
« Reply #17 on: August 27, 2018, 07:55:45 PM »
Thank you guys for all the options and opinions. Looks like a have a few more options to consider and research.  I had a nice conversation on the phone with redbeard last night and he is very pleased with his oscar 60. The only negative that caught my attention for me would be the max blade height. It sounds like the head might not travel up far enough to start slabbing at the top of really big logs.
Shenendoah dies the price on that Baker say 16600?
Offline Lawg Dawg
  • True South Sawmill Lumber
« Reply #18 on: August 27, 2018, 08:17:41 PM »
I'd buy 2 at that price  :D
2018  LT 40 Wide 999cc
John Deere 5020, John Deere 4000, 2016 F150, Husky 268, 394xp, Shindiawa 591, 2 Railroad jacks, and a comealong. Woodmaster Planer, and a Skilsaw, bunch of Phillips head screwdrivers, and a pair of pliers!
100,000 bf club member
Pro Sawyer Network
Offline Busysawyer
« Reply #19 on: August 27, 2018, 08:39:29 PM »
Ld , I know it. I cant see the pic that well but it sure looks like 16600. Doesnt seem right.
Wide throat/slabbing mill portable PA needed...
Started by bkaimwood on Sawmills and Milling
Last post October 24, 2015, 08:52:15 PM
by Nomad
wide head mill band life?
Started by caveman on Sawmills and Milling
Last post December 12, 2018, 09:19:56 PM
by longtime lurker
6" wide band mill with only 8 horsepower.
Started by Dave Shepard on Sawmills and Milling
Last post March 23, 2015, 06:34:59 PM
by terrifictimbersllc
slabber versus wide manual band mill
Started by Norwiscutter on Sawmills and Milling
Last post February 15, 2007, 03:48:35 PM
by Ianab
