Author Topic: 562xp stopped  (Read 917 times)
Offline DDDfarmer
  • did you know 4/3 people don' know their fractions
562xp stopped
« on: August 27, 2018, 09:57:03 AM »
Hey guys,  was using the 562xp the other day running fine and then it just quit.  Pulled the cord, started, back to cutting and then just like I hit the stop button... quit.   Repeat a couple more times....  then it just won't start.  1/2 tank of gas so I know that's not the problem, pull, pull and pull some more but no go.
Pulled the plug, looks good and sparks but dry.  Bit of gas right into the cylinder fires and then quits.  Same with gas right into the carb.  Primer is full and if it works like I think it does, it just pulls gas from pump and exits to tank just to fill the system correct?  In which case the system is full and should be ready to go?  I even drained the gas tank and re-filled ( everything looked fine)
Let the saw sit and still doesn't work and tired of pulling the cord.  is it possible something got past the filter and plugged the jet?  or does the autotune carb have a electro-switch that will cut the gas flow similar to older IH carb setups?
Double whammy, 576xp has a broken intake boot, cant use it lol..     Trying not to take to dealer don't need another expense right now.  I like these auto-tune saws once past the learning curve, start-tune and run no hesitation no tools.  Just nervous to work on with the electronics that I may short out, is that justified?
Treefarmer C5C with cancar 20 (gearmatic 119) winch, Husky 562xp 576xp chainsaws
Offline Maine logger88
  • Don't force it get a bigger hammer
Re: 562xp stopped
« Reply #1 on: August 27, 2018, 02:59:52 PM »
Try the ground for the coil I had one come loose and do like your talking about. Shouldnt have to worry about a short cause theres no power when the saws not running
Offline John Mc
Re: 562xp stopped
« Reply #2 on: August 28, 2018, 01:17:10 PM »
If you let it cool all the way down, will it start and run again? If so, I suspect a bad ignition module (sometimes they fail in a way that only shows up when hot) or possibly vapor lock (though normally vapor lock is more of an issue when you shut down and then try to restart).
When it stops, have you removed the gas cap and reinstalled? Sometimes if the vent gets plugged, the negative pressure that develops in the tank as the gas is used is enough to prevent gas from flowing into the carb.
Offline DDDfarmer
Re: 562xp stopped
« Reply #3 on: August 29, 2018, 10:01:24 AM »
Lots of spark, so I don't think would be a coil problem.  Cooled down and won't even sputter when cranked over.  Little gas right into the carb and she comes to life.....until it gets used up.
Opened-drained and refilled the gas tank so don't think air lock.
Can pull starter cord with choke on until your arm is numb then remove spark plug and its bone dry,  makes me think something in the carb plugged or broke.
Guess I get to play doctor and preform some surgery, must be a video on youtube on this carb and not damaging wires/etc.
Last time the saw was at the dealer ( recall on the gaskets if I remember right)  they either stripped or left a muffler bolt loose(under the cover).  I've snugged it up a couple times but now its vibrated ALL the threads away to nothing.  Wonder if there is enough meat there to install a heli-coil?  Too may mechanics in that shop and you take a chance whom you get...
Offline John Mc
Re: 562xp stopped
« Reply #4 on: August 29, 2018, 12:20:11 PM »
Normally, vapor lock happens on the fuel lines, not in the tank. It happens when the fuel in the line gets hot enough to boil and turns to vapor, which can stop the flow of fuel to the carb. That little bit of gas into the carb would bypass the vapor lock, which makes it sound as though vapor lock is a possibility. However, this would normally clear up once the saw has cooled down.
If you are referring to a plugged fuel vent, opening the tank (whether you drained and refilled or not) should have temporarily corrected that problem.
So I'm giving both of those a low probability at this point (assuming you did let the saw cool down thoroughly before attempting restart).
Is your fuel filter in good shape?
Given that it's a 562XP, I'm guessing it's not all that old, so the diaphragm has not gone bad?
Offline Grandpa
Re: 562xp stopped
« Reply #5 on: August 29, 2018, 08:27:48 PM »
Just a shot in the dark. Did you check the impulse hose?
Offline realzed
  • Old Fart but - I'm new!
Re: 562xp stopped
« Reply #6 on: August 29, 2018, 11:11:45 PM »
 Probably not the cause - but I had an 026 stop running fairly abruptly and it would start up and run momentarily when fed gas thru the carb or dumped into the cylinder but that sustained operation for a brief high rpm few seconds, and then it was dead again.. culprit was a crankcase seal that finally broke down and leaked a massive amount of air..
Luckily it went quickly before the engine ran lean for too long and replacing it brought the saw back off life support immediately without any issues other than the cost of the replacement seals (actually I changed both sides assuming the other one could/would be bad soon after) - You know the 'Murphy's Law' - thing!
Offline mike_belben
  • Pulp Friction
Re: 562xp stopped
« Reply #7 on: August 30, 2018, 09:00:44 PM »
First things first, pull muffler and see if you scored the bore. If so the rest of these checks are for naught.
Revelation 3:20
Look Who Stopped By...
Started by Ruffneck on The Outdoor Board
Last post October 30, 2016, 09:11:19 PM
by WV Sawmiller
Guess who stopped?
Started by thecfarm on Forestry and Logging
Last post December 24, 2016, 07:40:30 AM
by Roxie
thumbup
Ears have stopped ringing at least...
Started by Ianab on General Board
Last post October 18, 2010, 02:04:31 PM
by D Hagens
CSM ( Timberjig) stopped cutting
Started by hammerfore on Sawmills and Milling
Last post October 21, 2014, 07:32:48 AM
by hammerfore
