Author Topic: Adjusting an MS260  (Read 1131 times)
Offline DLMaine01
Adjusting an MS260
« on: August 27, 2018, 10:38:53 AM »
I am having trouble adjusting the carb on my 260. I replaced the carburetor with an aftermarket one. It starts on choke fine and will idle ok but will not spool up enough to turn the chain much. I put the carb to factory settings but any other adjustments I do does not seem to help much. I replaced the carb due to age and general lower performance issues. It is a cheap aftermarket carb but I know some others that have worked just fine.
Any advice appreciated!
Offline DelawhereJoe
  • Trapped in Delawhere
Re: Adjusting an MS260
« Reply #1 on: August 27, 2018, 11:22:42 AM »
Did you replace the fuel lines, there could be a crack in it and that crack is sucking in air.
Offline DLMaine01
« Reply #2 on: August 27, 2018, 12:21:45 PM »
Yes, replaced fuel line with a genuine Stihl one and the impulse line as well.
Offline Woodcutter_Mo
« Reply #3 on: August 28, 2018, 03:53:54 PM »
 I used a cheap aftermarket carb on my 024 which worked good for a while then started acting up. I opened up the carb and found some fine metal dust inside, I assume from the manufacturing process, that I believe to be the issue. Maybe open it up and see.
- WoodMizer LT25, Kohler, all manual, old "drag" style WoodMizer sharpener, cat claw single  setter
- Husqvarna 372XP X-Torque/24" bar, 455 Rancher X-Torque/20" bar, 550XP/20" bar, Stihl 024AV/18" Oregon speedcut
- Kioti DK45, '92 Dodge Cummins with Cannonball  bed, '07 Honda Rancher
Offline millwright
« Reply #4 on: August 28, 2018, 06:35:46 PM »
Also make sure the muffler screen is open, if it is plugged it will idle but not rev up.
Offline DLMaine01
« Reply #5 on: August 31, 2018, 03:20:27 PM »
Thanks for the replies. I did check the muffler screen as I had read that could be a problem in some of my research.
I was able to find a step by step for adjusting the saw which I will try this weekend. If that is a no go I will open up the carb and clean.
Thanks again.
Offline Pulphook
  • Duty, Honor, Country
« Reply #6 on: August 31, 2018, 07:34:54 PM »
Worth the extra $$$ to refit with the Stihl carb for the 260. Aftermarket copies don't have the same tolerances; often China.
Not worth the hastle, since most of the effort is the install.
We've all been there.
Two wood stoves ( Jotul Rangely ,Jotul Oslo ) heating 99 44/100%
24/7. No central heat. 6-8 cords firewood from the woodlot /year. Low low tech: ATV with trailer, 3 saws, 2 electric splitters, a worn pulphook, peavy, climbing line for skidding, Fiskars 27, an old back getting older.
Offline teakwood
  • Switzerland
« Reply #7 on: September 01, 2018, 08:40:35 AM »
Aftermarket carb works fine. i did two 260s with AM chinese carbs, around 12-15$. they work well.  We have members here that have used dozens of AM carbs on their rebuilds and they haven't complained
Offline Pulphook
« Reply #8 on: September 05, 2018, 10:49:17 AM »
I'm complaining.....2X.
Offline Mad Professor
« Reply #9 on: September 06, 2018, 04:36:51 PM »
Fatten up low (CCW) a bit
Offline ZeroJunk
« Reply #10 on: September 07, 2018, 06:31:13 AM »
Could also be that your lower performance issues weren't the carb to start with.
Offline DLMaine01
« Reply #11 on: September 07, 2018, 02:44:11 PM »
Success! Used the instructions I found online and it is running fine now. I bought the saw used so I never had a manual for it. Was able to cut for a bit today and all was good. I also thought the aftermarket carb was a risk, hit or miss, but this one is doing OK at the moment.
I also have a MS290 and these 2 saws make a good team.
Adjusting lt 40
Started by Woods on Sawmills and Milling
Last post November 25, 2017, 08:02:18 AM
by drobertson
Adjusting oiler?
Started by MNBobcat on Chainsaws
Last post October 28, 2017, 09:47:30 PM
by Al_Smith
Adjusting carb
Started by vinc5d on Chainsaws
Last post February 15, 2015, 11:00:58 AM
by vinc5d
Adjusting the carb on my new saw
Started by 21ftnitro on Chainsaws
Last post March 17, 2015, 10:26:38 PM
by Andyshine77
