Author Topic: 1950's Circle Mill Trouble Shooting  (Read 4131 times)
Offline hacknchop
Re: 1950's Circle Mill Trouble Shooting
« Reply #60 on: February 09, 2019, 11:59:54 PM »
I had trouble with a saw once until an older fella came along and told me to remove every second tooth and I did and it made the difference I think your just underpowered every tooth draws .Check with some of the other guys like Jeff  they will know what I'm talking about.
Often wrong never indoubt
Offline moodnacreek
  • Sawin by the notches
« Reply #61 on: February 10, 2019, 04:11:55 PM »
Worth a try, slow feed in knots or cross grain. Of course you can't just take out teeth or the saw will curl. Have to blunt or have every other tooth short. I have seen old solid tooth saws with every other tooth sawed off, must have been sawing with a fordson.
Offline Ron Wenrich
« Reply #62 on: February 10, 2019, 06:53:15 PM »
The problem with using a skip tooth method is that you have half the gullet space for dust.  That means you have to slow your feed down or you'll hang the saw.  Hanging the saw puts a lot of stress around the eye of the saw, and you'll need to get it hammered.  Probably okay for a hobby operation.  But, its just putting a band aid on the problem.
Offline Jeff
  • Fearless Leader
  • I know that I do not know.
    • THEE Forestry Forum
« Reply #63 on: February 10, 2019, 08:23:58 PM »
Ditto.
Offline Jeff
  • Fearless Leader
« Reply #64 on: February 10, 2019, 08:27:40 PM »
Hanging a saw is an experience. I can almost guarantee if it happens to you, the first words out of your mouth will be "what the he....!"
Offline hacknchop
« Reply #65 on: February 10, 2019, 09:44:09 PM »
The experience that I had was we had worked on this mill for about a week every day , checked first to make sure everything was level ,made sure the lead was right bought a brand new jockey grinder and stellite teeth ,messed with the governor didínt help because the saw was underpowered when I would start into a cut I would have to really watch my feed speed because the motor couldnít keep up. Not after remove every second tooth I would cut on average a tandem load a day, the only other thing that made a difference was in big spruce we would try to saw from the butt end which was new to me as before that I never paid attention. Iím just a sawyer not a millright but a fella does learn a few things along the way.
Offline hacknchop
« Reply #66 on: February 10, 2019, 10:02:53 PM »
The only other thing I want to add is I was a somewhat experienced sawmill operator hired to resurrect this moth balled butchered mill and when I couldnít get it to work I reached out to older more experienced ones and they saved my job and reputation,I didnít know about the forestry forum or it may not have been around then 1998 but it was the same type of experience so reach out to your    closest saw filer and ask thatís what I did .
                                                    All the best Terry Ferris
Offline Ianab
« Reply #67 on: February 11, 2019, 04:25:33 AM »
Reducing the number of teeth should allow you to cut better, at a reduced speed.
The problem is that each time a tooth bites in it has to cut though all the wood fibres in it's path. Now whether it bites in 1/32" or 1/16", the load on the saw is similar.  So slowing down the feed doesn't help as much as you might think.
Now if the saw has less teeth, you can keep up the 1/16" feed rate per cut, which will only be 1/2 the speed of a full comp saw with heaps of power.
Same way a swing blade mill with only 4 - 6 teeth can cut OK, and throw decent chips (not dust). Because each cutter on the blade needs 2-3 HP to keep it working properly,. So 6 cutters on my mill with 13 hp works. 50 teeth on a circle blade, then you want 100+ HP pushing it. Drop it back to only 25  teeth, and 50 hp should drive it, but at 1/2 the feed speed. Each tooth is taking a proper bite, throwing out chips etc.  But you have to watch that feed speed, and not stall the saw.
Offline sharp edge
  • Keep it stupid, simple!!!
« Reply #68 on: February 11, 2019, 06:33:36 AM »
Start with cutting 8"-10" white pine logs, then work your way up. The knots are even soft in white pine.
That board you cut would be hard to do on a good mill.
SE
The stroke of a pen is mighter than the stroke of a sword, but we like pictures.
91' escort powered A-14 belsaw, JD 350-c cat with jamer and dray, 12" powermatic planer
Offline dgdrls
  • Learning the Art of Milling Logs, Lucas 8/27
« Reply #69 on: February 12, 2019, 07:24:49 PM »
Jemmy
did you figure out what pattern you're saw is?
How many teeth?
D
Offline jemmy
« Reply #70 on: February 12, 2019, 09:11:45 PM »
I can get some photos from things Ive cut along with over all photos, I believe the motor has at least 100hp, and I was told that it had plenty of power but I could be wrong, Im fine with switching out motors. But I dont think thats the issue as of right now. Im gonna start with the teeth, blade alignment etc, leveling, etc then try and cut next. I got a decent list going now. And I am in school full time till may but i want to be producing something in 2 weeks or less, and by 3 months have things decently fluid.
Plan for the worst, hope for the best, and take what comes with a grin. - Grandpa Chuck
Offline Jeff
  • Fearless Leader
« Reply #71 on: February 12, 2019, 09:47:59 PM »
Circle sawmilling is a science, it is an art, and it is witchcraft.  You need to get the science part straight first.  You will get know where unless you procedurally go through the setup and alignment of the mill, the power and transfer of power to the mill, and the blade and teeth. All of these have to be correct to run a circle sawmill.   Go at it halfassed and try and skip the important stuff and you are destined to fail.  Once we get past the science stage, we can then help you with the art and then the witchcraft stages.  :D
glow plug trouble shooting???
Started by shinnlinger on General Board
Last post November 18, 2010, 06:14:25 AM
by StorminN
Trouble shooting a Grand Cherokee
Last post October 19, 2012, 09:46:50 PM
by beenthere
question
Help trouble-shooting my 2000 Ford Ranger please
Started by RynSmith on General Board
Last post May 26, 2013, 07:52:07 PM
by millwright
Trouble with Alaskan Mill, especially Mini Mill
Started by danf26 on Sawmills and Milling
Last post April 01, 2011, 08:31:45 PM
by danf26
