Author Topic: Drying wide boards  (Read 448 times)
Offline logbyr
Drying wide boards
« on: September 02, 2018, 08:18:11 AM »
I am been flitch sawing some bigger logs which yield some wide boards.   The widest boards nearer heart have both rift/qtr and flat sawn grain.  I edge pith out of  boards  in center which gives me a few pure rft/qtr boards.
  I have some of this on sticks and after 1 - 2 years it has air dried flat.  Will these give me warp issues as i get them into the kiln?  Will they all dry to same % moisture in the kiln?
Logs r woods grown northern appalachain region.  Generally slow growth/ thin sap with good structure/shape.  Species include cherry, soft maple,butternut, walnut.
Kiln is nyle  L 200.
Thx in advance
Offline DR_Buck
  • Nuff said.....
    • Got Logs?
Re: Drying wide boards
« Reply #1 on: September 02, 2018, 08:28:11 AM »
Not sure of how wide your boards are or the thickness, but when I have wide boards (usually 5/4) for going in the Nyle I try and stack the widest stuff on the bottom.   I've had very good success with them staying flat by doing this.  I almost always put my 8/4 and thicker stuff on top of the stacks.
Hidden Acres Farm
Been there, done that.   Never got caught
Wood-Mizer LT40HDG38
Lucas Dedicated 60" Slabber
Offline GeneWengert-WoodDoc
« Reply #2 on: September 02, 2018, 12:19:43 PM »
Chances are that the flinches you have are around 13% MC.  Wood cells shrink from 30% MC going to 0% MC.  Drying the glitches from 13% to 7% MC is a difference of 6% MC.  Drying from 30% to 13% MC is a difference of 17% MC.  Shrinkage is linear with MC loss.  So, you have had about 3/4 of the shrinkage already happen.  You have about 1/4 to go.  If you are flat and straight now, you should not see much additional warp...just normal shrinkage.  A key is to make sure you do not add any moisture to the surface when you start the kiln.
drying wide boards
Started by tazz on Sawmills and Milling
Last post June 18, 2010, 01:34:40 AM
by Left Coast Chris
Help with wide boards
Started by KjBarnwood on Drying and Processing
Last post February 21, 2012, 02:42:41 PM
by Den Socling
Wide Boards ?
Started by Qweaver on Sawmills and Milling
Last post April 05, 2015, 08:57:38 PM
by dean herring
Wide 1x boards
Started by Randy on Sawmills and Milling
Last post April 11, 2005, 12:52:24 AM
by UNCLEBUCK
