Author Topic: Timber king M14 blade wobble  (Read 1091 times)
Offline Tom Caroselli
« on: September 08, 2018, 08:39:44 PM »
What causes the saw blade to wobble. Doesn't do it all the time
Offline JB Griffin
Re: Timber king M14 blade wobble
« Reply #1 on: September 08, 2018, 08:54:38 PM »
Many, many, many things. Heat being one. And would be highly suspect. Is the saw dragging hard on the cant when returning the carriage?  Sun shining on the saw can do it to. Also the saw may be loose and need hammered.
2000 LT40hyd remote 33hp Kubota, 160 Prentice, Frick 2 saw gang edger, Wright W-37 ABG, Suffolk dual tooth setter, Cat claw single tooth setter,'96 F-250 7.3 PSD 4x4, CS-590 Echo, MF 20c, M681 Memo.
Over 2.5 million bdft sawn with a Baker Dominator and counting.
Offline Don P
    • Calculator Index
« Reply #2 on: September 08, 2018, 09:48:07 PM »
Especially when I throttle down between cuts mine can get what I assume are speed related harmonics from deceleration that start getting it wandering around. If I throttle it back up a little it usually stands up enough to get out of it.
If it creates heat in cut and lays over, as it cools it will flop back in, wobble around a bit, continue to cool, and stand back up. If you suspect that kind of problem shut down and feel the blade temperature from rim to collar.
« Reply #3 on: September 09, 2018, 01:01:32 AM »
Thanks for the information, I'm new at this. What do u mean the saw needs hammered?
Offline bandmiller2
« Reply #4 on: September 09, 2018, 06:22:51 AM »
Tom, stuff already mentioned also if the blade wobbles when your carriage is moving your ways/base may be shaking. It doesn't take much to cause the saw to wobble. Frank C.
Offline JB Griffin
« Reply #5 on: September 09, 2018, 08:45:29 AM »
Saw blades are tensioned by hammering them. Tension is what makes the saw stand up and saw straight. The saws are hammered to run at a set rpm, yours being a belsaw most likely 540rpm. Running the saw too fast or too slow will cause it to wobble.
Offline PC-Urban-Sawyer
  • Been wasting time for sixty-eight years...
« Reply #6 on: September 09, 2018, 10:50:29 AM »
Got to mention that hammering a saw blade is not a task for novice sawyers. You need to locate and use an experienced "Saw Doctor" and hopefully part of the experience will be learning more about what's going on in a saw blade...
Good Luck!
Herb
Offline moodnacreek
  • Sawin by the notches
« Reply #7 on: September 09, 2018, 11:00:48 AM »
To start with the saw plate is not supposed to touch anything. Only the tooth cutting edge contacts wood. The tooth corners steer the saw or allow it to cut straight. to much corner on one side and the saw leans that way and the log/cant/board touches the plate and you have 3 problems all at once because of poor filing.   An experienced sawyer sees the saw line start to vary and looks for the trouble almost before it starts. This takes time to learn.  The above posts and many small things are all part of the circle sawmill.  It is very simple when it is working right.
Offline jimparamedic
« Reply #8 on: September 09, 2018, 11:17:47 AM »
shiny spots on the saw plate indicates hot spots in the saw
« Reply #9 on: September 09, 2018, 12:47:43 PM »
Thanks so much, you guys are awesome! I never knew there was so much involved in an old circle mill. I'm learning daily.
Offline BUGGUTZ
  • !wen m'I
« Reply #10 on: September 11, 2018, 09:16:33 PM »
Our engine club has a 56" on a steam mill. it tends to wobble in large wood. Usually indicates that the engine needs a bump to maintain the rpms for the blade.
Everyone has to be somewhere.
« Reply #11 on: September 11, 2018, 09:46:39 PM »
Do you have pics of you sawmill and power set up. We love pics here
Offline BUGGUTZ
  • !wen m'I
« Reply #12 on: September 15, 2018, 09:51:58 PM »
Next time I am out there I will get some pics. It is pretty impressive. I run a belsaw creation at home, there used to be a couple pics on here but I dont know where they went.
Started by Tom Caroselli on Sawmills and Milling
Last post September 22, 2018, 04:36:48 PM
by jimparamedic
Timber King 1220....backfire when blade disengages
Started by jander3 on Sawmills and Milling
Last post October 29, 2011, 05:29:33 AM
by ladylake
lucas mill blade wobble.
Started by scmilling on Sawmills and Milling
Last post July 05, 2015, 03:04:06 PM
by sigidi
Circle mill blade wobble
Started by ddcuning on Sawmills and Milling
Last post December 21, 2013, 07:55:29 AM
by bandmiller2
