Author Topic: Am I missing something with my filing?  (Read 994 times)
Offline KODAK
« on: September 08, 2018, 09:15:17 PM »
Hey everyone,
Iíve got a small problem Iím running into with my Alaskan chainsaw milling. Iíve got a bunch of milling ahead of me. Finished up a white oak and then a spalted maple I found on my new home property. I noticed that Iím getting wavy cuts. The white oak was my first time. Brand new ripping chain and 52Ē forester bar on my ms880. Used a ladder as my guide bar. Made sure it was level. Cut had nice chips but was wavy. Noticed my chain had some slack in it. On this spalted maple I sharpened my chain with a Stihl file at 10 degrees and used 2 2x4 as my guides. Log was only four feet long and 34 inches in diameter at the widest. Noticed cutting took tons of pushing and lots of dust. So I resharpened and took down the rakers and itís move a lot better but still tons of barely chips/thick dust. Last few cuts after resharp/rakers were wavy around 1/16 deviations. Is it my filing or does it look like chain slack, or even the 2x4s being warped?
Look forward to hearing from you guys. Iíve got another beautiful spalted maple Log bigger than this to cut and I donít want to mess it up for potential customers
Offline Downstream
Re: Am I missing something with my filing?
« Reply #1 on: September 09, 2018, 09:26:43 AM »
Looks like it is more concentrated in two spots based on looking at 1st photo.  that would rule out a chain issue i would think because that would be seen along entire length of log as it passed by in the loop.  I would get that more when i had to rock my grandberg setup more to try and get through a hard spot.  I learned to try not rock the chainsaw forward and back like i would just bucking a log because it usually left a surface that required more sanding. I hate sanding :laugh:!
EZ Boardwalk Jr,  Granberg Alaskan Chainsaw Mill, Stihl 660 and 211, Logrite 60" cant hook, Dixie 32 Tongs
Offline KODAK
« Reply #2 on: September 10, 2018, 07:57:30 AM »
Hmm good point. I was rocking it a few times to get it through the cut. My finish cut with my ladder as my guide rails didnít produce a better surface finish. Iím leaning towards loose tension and just not having my filing technique down well enough. My cut quality isnít too bad compared to fresh chain but the speed is way slower. More dust and less grab in the log. I really gotta push her through the cut
Offline mike_belben
  • Pulp Friction
« Reply #3 on: September 10, 2018, 08:10:42 AM »
Dust is pretty much all you get in chainsaw milling.  Rig up a hand crank rope winch to pull your rig down the line and take the strain off of you.
Revelation 3:20
Offline goose63
« Reply #4 on: September 10, 2018, 08:21:56 AM »
Like this
Makes for a lot less work  8)
goose
thank you to all the vets
Offline Weekend_Sawyer
  • Jack of all trades, master of fun
« Reply #5 on: September 10, 2018, 09:00:25 AM »
How wavy are we talking.
Can you take another pic with a straight edge on top of the plank and show us?
I absolutely agree with some sort of crank to help pull the mill through the cut.
Imagine, Me a Tree Farmer.
Jon, Appalachian American Wannabe. ... and it looks like my dream will come true!
Offline KODAK
« Reply #6 on: September 10, 2018, 10:05:29 AM »
Iíll try to grab another picture to show the wavy cut. Iíll also take a photo of my chain filing. I like that crank, was that DIY or ordered for the mill?
Offline goose63
« Reply #7 on: September 10, 2018, 10:20:03 AM »
KODAK mine is DIY
goose
Offline YellowHammer
  • Take Steps to Save Steps
    • Hobby Hardwood Alabama
« Reply #8 on: September 10, 2018, 12:07:09 PM »
Hereís another version, a thin piece of paracord and a bent piece of steel round stock as a crank.
Chainsaw milling is tough, any kind of crank will make it much easier.
HobbyHardwoodAlabama.com
« Reply #9 on: September 10, 2018, 12:53:09 PM »
Yep, I adopted Yellowhammer's crank to my mill.
Made it soooo much easier.
Offline mike_belben
  • Pulp Friction
« Reply #10 on: September 10, 2018, 01:07:44 PM »
Mine is a cord around a rod like that but it uses an eyelet to redirect so that the pull is from the far end.  Basically my silent helper who pushes on my command.
Revelation 3:20
Offline KODAK
« Reply #11 on: September 11, 2018, 08:46:52 AM »
does the rod style cause any deflection in the cut on wider slabbing say 52"?
Like this
Goose I think I see a log arch in the background, I made one very similar. It's been awesome. I've got many logs from that rig and it didn't cost me more than steel and a couple days of fiddling with it.
Offline goose63
« Reply #12 on: September 11, 2018, 05:07:01 PM »
KODAK that is my trailer
This is my log arch the 12.000 pound winch is a beast
goose
Saw Filing
Started by inspectorwoody on Sawmills and Milling
Last post February 12, 2011, 12:29:25 AM
by backwoods sawyer
square filing
Started by tony_marks on Chainsaws
Last post January 18, 2005, 06:48:46 PM
by leweee
filing gullets
Started by logosoluser on Chainsaws
Last post January 18, 2005, 07:35:43 AM
by beenthere
Raker Filing
Started by luvmexfood on Chainsaws
Last post December 26, 2013, 05:17:42 PM
by Al_Smith
