Author Topic: Log turning  (Read 2237 times)
Offline charles mann
Log turning
« on: September 10, 2018, 01:50:04 AM »
so without a hydraulic turner, and a tree to big to turn with a cant hook, either bc of diameter, or just shear weight. what have people used to turn logs, especially if once the log is on the bed, the wind crack isn't lined up parallel to the blade/bed?
the other day when i went to get a pecan, i needed to roll the log to get it off my chain so i could bind the logs down for transport. I took my rubbing choker and placed the nub and bell on the back side, wedged the front side and started winching till it picked the log up enough to get my chain out.
asking because I'm going to run into this issue once i get my mill build, and i won't be putting a turner on it just yet, and also don't want to potentially mar up the live edge during turning, especially using something like the WM's freddy kruger finger style turner. plus both pecans weigh over 5000# and my tractor cant do much more, than just be a 10,000# anchor.
Temple, Tx
Online ljohnsaw
Re: Log turning
« Reply #1 on: September 10, 2018, 02:00:55 AM »
When I want to turn a cant and not mar it up or even turn a big log, I use my SkyTrak and a nylon strap/tow rope.  I have one that is a very big continuous loop made from about a 20' strap.  I put it around the log so it cinches underneath.  Then I lift while pulling away from the log stop.  That allows it to roll towards the stop.  I use it to support most of the weight so it doesn't slam down on the bed.
I now have a second, bigger, cant hook and plan to try a two-man, two-hook turn to see how that goes.
John Sawicky
Offline kelLOGg
Re: Log turning
« Reply #2 on: September 10, 2018, 07:06:59 AM »
You might modify something like what I use with a tow strap.
Cook's MP-32, 16HP, 20' (modified w/ power feed, up/down, loader/turner)
DH kiln, CatClaw, setter, tandem trailer, log arches, tractor, thumb tacks
Online Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: Log turning
« Reply #3 on: September 10, 2018, 07:53:01 AM »
Whatever you do you can not do without a couple of these:  Cant Hooks - Logrite Tools LLC
Online firefighter ontheside
  • I like trees.
Re: Log turning
« Reply #4 on: September 10, 2018, 08:01:19 AM »
I have short woodmizer hook, but also homemade 6 foot hook made by former member here, gfadvm.  It probably wouldn’t do much with a 5000lb log though.  I plan to have a single hook on a chain to be able to turn logs on my mill with the tractor.  Should be able to turn logs that I can’t necessarily lift.
Woodmizer LT15
Kubota Grand L4200
Stihl 025 and MS291
2017 F350 Diesel 4WD
Online Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: Log turning
« Reply #5 on: September 10, 2018, 08:07:42 AM »
I regularly use these "Magic Hooks" that were repurposed from broken logging tongs.
Offline roger 4400
Re: Log turning
« Reply #6 on: September 10, 2018, 08:10:31 AM »
This summer I had some 30 inch pine logs on my manual Baker sawmill. To turn those logs **easily** I put one or two wedges on the mill cross members and use a 4 ft log rite. The logs easily turn on the metal cross members and the wedges hold them in place.
Baker 18hd sawmill, massey Ferguson 1643, Farmi winch, mini forwarder, Honda foreman 400, f-250, many wood working tools, 200 acres wooden lots,6 kids and a lovely and a comprehensive wife...and now a Metavic 1150 m14 log loader so my tractor is a forwarder now
Online mike_belben
  • Pulp Friction
Re: Log turning
« Reply #7 on: September 10, 2018, 08:20:27 AM »
Some blocking across the mill frame parallel to the log and a pair of good rigging bars levering off the block will inch it around.  May have to scoot the log away from the backstops then roll towards them with the bars and repeat.
Or come in from the backstop side with your loader, hook a chain over the the center of the log, then curl back to parbuckle in place against the backstops.  If you can do so gently and without harm to mill or machine, let the front tires park against the mill frame so you dont jar it out of alignment or off any footings etc.  Just a bit more stabilization.
Revelation 3:20
Offline PAmizerman
  • Just Another Day In Paradise!!
Re: Log turning
« Reply #8 on: September 10, 2018, 08:29:36 AM »
What ljohnsaw said!
Hydraulics everywhere
Traverse 6035 telehandler
WM bms250 sharpener
WM bmt250 setter
Online Crusarius
  • Lost in....
    • RockModified.com
Re: Log turning
« Reply #9 on: September 10, 2018, 08:42:45 AM »
I thought about mounting an electric winch with a hook, then mount it to my carriage just to roll the log. But not sure its a good idea. Especially since I want something to be able to roll logs up the ramps to.
Online Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: Log turning
« Reply #10 on: September 10, 2018, 08:59:57 AM »
I have "reverse" turned a big/heavy log using a chain, Magic Hook, and log clamp.
When the clamp moved in the log was reverse turned against the side supports.  Works like a charm.  ;)
Offline Skipper11A
Re: Log turning
« Reply #11 on: September 10, 2018, 01:54:20 PM »
Charles,  Your tractor CAN turn those 5,000 pound logs.  Remember, it doesn't have to lift the logs, it just needs to roll them against the backstops.  Your tractor will handle that with ease.  The other posters have provided different rigging suggestions and they all work great.  I think the J hook is the least reliable option because it doesn't always bite into the log well enough...but they work.
Online Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: Log turning
« Reply #12 on: September 10, 2018, 02:04:18 PM »
You very obviously have never used one.
Online Crusarius
  • Lost in....
    • RockModified.com
Re: Log turning
« Reply #13 on: September 10, 2018, 02:14:19 PM »
Wonder if Logrite will sell just the hook? That would be nice on the end of a cable
Online Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: Log turning
« Reply #14 on: September 10, 2018, 02:22:05 PM »
Offline PC-Urban-Sawyer
  • Been wasting time for sixty-eight years...
Re: Log turning
« Reply #15 on: September 10, 2018, 02:24:10 PM »
You beat me to MM...
Herb
Online Crusarius
  • Lost in....
    • RockModified.com
Re: Log turning
« Reply #16 on: September 10, 2018, 02:32:12 PM »
Sweet, you guys are awesome. Thanx.
Offline Skipper11A
Re: Log turning
« Reply #17 on: September 10, 2018, 06:06:14 PM »
MM, your condescension seems inappropriate on this forum.   Actually, A "J" hook is what I  always use to turn the big ones, and they can have trouble biting into the wood.
Crusarius, I just looked at my Logrite Cant Hooks and I think their hooks would work great on the end of a cable.  You may have to hammer the point into the log but they look thick enough to do the job.  Get their longest hook.
Online Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: Log turning
« Reply #18 on: September 10, 2018, 07:06:22 PM »
My apology to you if my words seemed harsh or were misinterpreted.  The backside of my hooks are shiny where they always get a rap or two with my hatchet before any load is applied.  The above pictures happened to be taken before such action took place.
I said:  " Works like a charm."
You stated:  "I think the J hook is the least reliable option because it doesn't always bite into the log well enough...but they work."
I agree with you that "they work" but I fail to agree with you that they are in any way "unreliable".
I do not see "condescending" but I do see "disagreeing".
Offline Hilltop366
Re: Log turning
« Reply #19 on: September 10, 2018, 07:51:25 PM »
Sounds like ljohnsaw's tow strap ls the best answer for this purpose.
The non marring log turner could be in demand with all the slab making going on, I'm thinking some sort of conveyer belts arranged in a V shape that would push up the log and turn it or a pair of wheels and tires.
turning
Started by lpresnell on General Woodworking
Last post December 31, 2012, 02:05:47 PM
by Lud
log turning
Started by revid on Sawmills and Milling
Last post February 19, 2015, 11:46:27 AM
by logboy
pen turning
Started by thedeeredude on General Woodworking
Last post July 21, 2008, 01:24:39 AM
by Don P
larch for turning ?
Started by james on Tree, Plant and Wood I.D.
Last post May 07, 2004, 04:07:14 AM
by SwampDonkey
