TURBOSAWMILL GIANT SALE ON NOW UNTIL OCTOBER 31st
Author Topic: which of these 60-75cc saws would you buy?  (Read 2891 times)
Offline pdbrandt
« on: September 10, 2018, 03:42:38 PM »
Hello all.  This is my first post so hereís a quick intro Ė Iím a tree climber and own a small (1-person so far) tree care company in central NC.  I focus on tree care, pruning heritage trees, lightning protection systems, etc and have avoided removals for the most part.  Since I donít do many removals Iíve been able to get away with owning just two saws - both Huskys - an in tree saw and a 46cc farm/ranch saw. Iíve had enough jobs where I maxed out my 46cc saw that Iíve finally admitted that I need to get a bigger one.  I want to stick with Husqvarna and my local saw shop has three 60cc plus saws for sale:
1) Husq 562XP. 60cc, 4.7hp, he is asking $475
2) Husq 575XP. 74cc, 5.4hp, asking $575
3) Husq 365 Special. 65cc, 4.6hp, asking $475
Iím looking for a saw that can easily handle a 28Ē bar and I anticipate that it will be used for a few jobs per month.  Which saw would you buy if you were limited to these 3 and were on a budget?  The prices all seem about $50-75 high and Iím sure I can talk him down a bit.
Thanks,
Patrick
Offline Greyhound
Re: which of these 60-75cc saws would you buy?
« Reply #1 on: September 10, 2018, 05:09:29 PM »
I don't have any advice but I'm curious what others have to say. Good luck.
Offline slider
  • sawyer,trucker,tree service
« Reply #2 on: September 10, 2018, 06:01:26 PM »
Welcome pd . I don't know much about husq saws ,mostly stihl here but i do quiet a bit of removals . I have a older 361 with a 20 in bar that has been a work horse. The saw is 10 years old so i bought a new ms 362 20 in bar . I thought about a longer bar for the new saw and then got a deal on a ms 461 32 in bar . I get into some good size trees here from time to time and in not so good places so that 461 is always with me on jobs where i need it.
Two years ago i did a good size removal for a friend and he traded me a brand new 880 for the work . It has a 36 in bar and is nice on a big stump but i never use it much. The saw is fine but too heavy for me .
Good luck on your purchase and we wish you well .
al glenn
Offline barbender
« Reply #3 on: September 10, 2018, 06:16:47 PM »
575 if you're going to run a 28" bar. These are used saws, I take it? I've read about the 575 having a weak crank bearing I think, but I don't have any personal experience with it.
Offline barbender
« Reply #4 on: September 10, 2018, 06:18:11 PM »
Actually, that 365 would handle a 28" ok with skiptooth chain, I used to have the Jred version I ran a lot with a 24" on it.
Offline HolmenTree
« Reply #5 on: September 10, 2018, 06:54:45 PM »
Welcome Patrick,
I'm a one man operation tree service owner too but I do mostly removals big and small.
My go to saw is a 562XP-20" that I bought new 5 years ago.
Still going strong and run a 24" on it for backup.
I think the 562 with 24" is plenty of saw if your used to 46cc saws. The 562 is factory rated for a 28" .
For backup I got a new MS261CM' 16" beautiful little saw.
Big wood I got two Stihl 066s that run 20" 25" 28" 36"
Husqvarna 562XP and Stihl MS362CM are the best 60cc saws out there
Offline sawguy21
« Reply #6 on: September 10, 2018, 07:18:43 PM »
The prices don't seem out of line from a dealer. He will want to make sure they are in top shape if he has to stand behind them. I have only run the 365 then only for a short time in softwood, you would probably want skip with a 28" bar in hardwood to keep the revs up. I can't comment on the other two.
Offline DelawhereJoe
  • Trapped in Delawhere
« Reply #7 on: September 10, 2018, 07:21:30 PM »
With that hurricane coming your way you may want to get a new saw and skip any possible problems that a used saw may have. Any 60cc+  pro saw should do anything you want, Echo's cs 800p will run a 20-36" bar and be cheaper then its competitors in its cc size and hp class. I've heard that the 575 & 576 have had air leak problems in the past causing them to run lean and burn up so you may want to avoid them.
Offline Huntaholic
« Reply #8 on: September 10, 2018, 08:06:19 PM »
Ok, first a little info on me, Im self employed in the forestry business, (logger) and have been all my life. Ive ran mostly husqvarnas all my life. I ran the 372 and its earlier ancestors up until several years ago when Husqvarna discontinued them for some stupid reason. I then switched over to the 575 series saws and never went back to the 372s after they started making them again. The 575 saw was replaced by the 576 and Ive continued to run them primarily to present day. All of these people saying this or that about issues with the 575 class saws have never ran them! When it comes to cutting big wood, I prefer the 575/576 to the 372 that everybody loves. The 575/576 WILL outcut the 372 in big wood. I typically get between 4 and 6 million board feet out of a 576 before it needs a major repair. In all the years Ive been running them I don't think Ive ever had one fail prematurely due to a defect.
Offline Southside logger
« Reply #9 on: September 10, 2018, 08:45:48 PM »
Well, around here you can't touch a 372 for the price of that 575. I am a 372 guy, but have never run a 575, given what others have said, who have run both, I don't think you can go wrong there.
Woodmizer LT35 sawmill, KD250 kiln, BMS 250 sharpener and setter
Offline Skeans1
« Reply #10 on: September 10, 2018, 09:04:04 PM »
Iím a 562 guy but I run a 32 on mine, for years I ran a hopped up 372 it was a great saw till it grew legs one day. One thing Iíve noticed is the weight difference and anti vibe is much better in the 562.
Offline HolmenTree
« Reply #11 on: September 10, 2018, 09:16:49 PM »
I agree the 562 is the best choice for the OP, ..light , hyper fast powerband and smooth.
Don"t forget the OP is only used to a couple of 46cc farm saws. :o
Offline pdbrandt
« Reply #12 on: September 10, 2018, 09:32:28 PM »
Yup. They are all used saws, but in good condition.  The 575 XP is a 2004 version. The 365 special is 2014 and the 562 XP is a 2016.
Offline pdbrandt
« Reply #13 on: September 10, 2018, 09:34:45 PM »
I'm sure I'll be spoiled quickly by a bigger saw, then will need another one...
Offline ehp
  • logger/chainsaw hack
    • ehpsaws.com
« Reply #14 on: September 10, 2018, 10:06:15 PM »
your saying the 365 was made in 2014 ? Where is the decompressure on that saw ? If it is made in 2014 then it should be a 365 XT which is the same saw as the 372 just has the limited transfer covers on it . If that saw is that and in good shape I would take it over the others as they have very little trouble
Offline Maine logger88
  • Don't force it get a bigger hammer
« Reply #15 on: September 10, 2018, 10:20:45 PM »
X2! 365xt/2166 is a great saw They have been my main saws for 5 years now
Offline Greenerpastures
« Reply #16 on: September 11, 2018, 07:12:25 AM »
Hi
I currently have no Husqvarnas, but had a new 372xp which was a real nice saw.
Out of the three you mention, you have auto-tune and standard carb models,
if you are happy with the standard carb and making adjustments to them then
maybe keep that in mind.
Personalty I would only buy auto tune on a new saw where the warranty would
cover any repairs, electronics are know to deteriorate over time, and the vibes on
a saw could shorten that time, it will not be a cheap fix if the auto tune gives up.
not trying to scare you regarding auto tune, in my opinion the longevity needs to
be proven yet, where as a man that depends on his saw and can't afford a bunch
of cash to throw at repairing auto tune should keep this in mind.
If you have a good paying job to put her straight into that would pay for the saw,
then thats another bonus, at least you would have her paid for in the short term
making other work done a bonus / earner.
I would take the 560p, a good running one has some serious cutting potential and
will get your jobs done without wasting time, the 365 should be reliable,
slower to cut with,  slow reliable and potentioally longer life works for a lot of people
too, though heavier.
Ultimately only you (the OP) will know what suits your needs and way of working.
If the seller will allow you to try the saw for the day, after looking them
over and selecting the best one in your eyes, maybe you could hire it for a day and see how
it performs, the 562 is also a light saw to hold, that is not to be over looked if
you struggle with weight.
In all honesty, in our part of the world we run as small a bar as gets the job
done, one never sees bars like the op mentions on the saws he mentions.
The 575 would thus be a better saw on the longer bars.
Of course there are other saws, I like the Echo, they are usually well priced too,
and the Makita / Dolmar brands, all good saws, if I could not get the size and
weight and price in one model I chose another, never had a Stihl 461, seen
them cut though, and a ported one really tickles my fancy.
In any event, if money is the limiting factor, it will probably matter more
that the OP choses the saw with the lowest hours and best cared for example,
I wish him all the best with what ever he choses.
Online Upstatewoodchuc
« Reply #17 on: September 11, 2018, 09:06:41 AM »
I have to agree with the others here, if that 365 is indeed a 2014, than it's an xt, not a special and an incredible amount of saw for the money. I bought a brand new 365xt in very early 2016 and proceeded to beat it mercilessly for the next two years, it's my go to saw because it can do the work of a little saw, but has the guts to cut big stuff too without working itself to death. Always starts within 2-3 pulls no matter what temperature, and 1 pull once warmed up. All I've done to mine is clean/change air filters, sharpen chains/flip bars, and blow the sawdust out of it. I just recently had to adjust the idle a smidge and that was the first time I've touched it since new.
-Pat
Current collection: Husky 3120xp,  394xp, 365, 345, stihl 017, homelite xl12.  Ford 8n with loader and forks. 1968 Chevy C50 dump truck
Offline barbender
« Reply #18 on: September 11, 2018, 10:03:12 AM »
The origjnal 365 was an underrated saw with a nice smooth power delivery.
Offline John Mc
« Reply #19 on: September 11, 2018, 06:29:11 PM »
In all honesty, in our part of the world we run as small a bar as gets the job done, one never sees bars like the op mentions on the saws he mentions.
What part of the world would that be?
I agree - I typically run 16" bars on my saws, but then 80% or more of what I'm cutting is 16" diameter or less, and 95% is 20" or less. The 16" bar does not come off unless I know I'm going to be doing a significant amount of cutting over 16". I'd rather carry a smaller, lighter saw all day even if it means I occasionally have to do some extra cutting here and there.
Hot Rod 75cc Chainsaw Closeout!
Started by KC on Chainsaws
Last post December 18, 2008, 10:49:21 AM
by zackman1801
A case for old Vintage Homie & Mac saws vs. new home owner grade saws..
Started by weimedog on Chainsaws
Last post November 25, 2013, 09:01:56 AM
by Bret4207
Bow Saws?
Started by Axe Handle Hound on General Board
Last post October 24, 2013, 07:56:28 PM
by two-legged-sawmill
old saws
Started by james on Chainsaws
Last post December 18, 2004, 10:36:56 PM
by chet
