Author Topic: OSB for stickers?  (Read 972 times)
Offline nybhh
OSB for stickers?
« on: September 11, 2018, 12:23:14 PM »
I'm in desperate need of some dry stickers (for ash) and just remembered I have a couple sheets of 3/4" OSB in the barn loft.  It won't be going to a Kiln - is for air drying only.  Figure I should be able to get about 90 4' strips per sheet.  I'll be able to keep the stack pretty dry except for a little blowing rain or snow but I'm a little worried about the glue staining the ash.  Anyone use it before or forsee any issues?
Woodmizer LT15 Start, Kubota L3800, Stihl MS261
Offline Jack Lilley
Re: OSB for stickers?
« Reply #1 on: September 11, 2018, 02:43:23 PM »
Seems like it should be fine but I have never tried osb before.
Offline Southside logger
« Reply #2 on: September 11, 2018, 04:09:51 PM »
Around here I would be concerned that 3/4" would not provide enough air flow, but we are quite humid so perhaps it's not such an issue where you are.
Offline jimparamedic
« Reply #3 on: September 11, 2018, 10:09:36 PM »
It will leave sticker stain and it can run deep mainly in the out side boards because it can draw in moister
Offline Brad_bb
    • My timberframe blog
« Reply #4 on: September 11, 2018, 11:00:51 PM »
It will mold too I think, and if it gets wet, will probably come apart.  If you're desperate, go down to the box store and get furring strips.  Then the first thing you should mill is Ash stickers.  It won't take too long for them to dry enough to use.  I use Ash stickers for most everything.
Offline Lawg Dawg
  • True South Sawmill Lumber
« Reply #5 on: September 11, 2018, 11:06:23 PM »
I would use Advantec osb stickers.  Has held up great in all the homes I've built and got rained on before we got the roof on...all the books on drying say 3/4" stickers, so I'd go for it.  Post your results so we can see how it turns out. In other words just try a little bit and see how it does...use what you got, my Granddad always said, it don't hert to try something new
2018  LT 40 Wide 999cc
John Deere 5020, John Deere 4000, 2016 F150, Husky 268, 394xp, Shindiawa 591, 2 Railroad jacks, and a comealong. Woodmaster Planer, and a Skilsaw, bunch of Phillips head screwdrivers, and a pair of pliers!
100,000 bf club member
Pro Sawyer Network
Offline nybhh
« Reply #6 on: September 12, 2018, 05:00:13 AM »
Thanks guys.  Sounds like its probably too risky.  I think Ill go ahead and cut a firewood grade ash into stickers here pretty soon and that will give me a feel for the ash before I get into the good stuff anyway.  Heating season will be here in a couple of weeks so I can move them into my shop with a fan and radiator to dry out quicker.
Ill probably give the OSB a try on my next palette of pine roof decking or something that wont really matter if it stains as an experiment but I dont want to take any chances with the ash.
Offline Crusarius
  • Lost in....
    • RockModified.com
« Reply #7 on: September 12, 2018, 07:54:46 AM »
I would love to see the results of this. I have thought about it but since all my piles are sitting outside in the weather I chose not to use it.
What I found myself doing is starting at the top of the tree, taking all the limbs off, then chopping the firewood diameter logs into 16" lengths for the wood stove, then when I got to about 8" diameter I cut them into 42" long pieces to make stickers, when I got into 12" size I started cutting saw logs the rest of the tree.
Offline YellowHammer
  • Aerospace Engineer Owner Full Time Lumber Business
    • Hobby Hardwood Alabama
« Reply #8 on: September 12, 2018, 08:08:47 AM »
If you cut the stickers from real wood, (not OSB, I would avoid it) and put them on the hot concrete or asphalt, assuming there's still a hot day or two left, then they will dry out in a couple days.  Just spread them out and let them cook.  Some will move bit when drying unconstrained, but as soon as you put them in the stacks of boards, they will get pressed flat, some will be too bad to use, just throw them out.  I've done it a few times when I was hurting for stickers.
HobbyHardwoodAlabama.com
Offline Peter Drouin
    • A&P Saw mill LLC
« Reply #9 on: September 14, 2018, 06:27:26 AM »
That stuff is junk, It will fall apart. I wouldn't build a dog house with it.
A&P saw Mill LLC.
License NH softwood grader.
stickers
Started by gtr on Sawmills and Milling
Last post June 06, 2006, 02:35:16 PM
by ohsoloco
question
Stickers
Started by SkyDoc on Sawmills and Milling
Last post January 24, 2017, 02:13:42 AM
by 5quarter
Stickers
Started by Woodlandbuddies on Drying and Processing
Last post November 07, 2018, 10:55:10 AM
by Woodlandbuddies
Stickers
Started by whittle1 on Drying and Processing
Last post March 16, 2016, 12:02:48 PM
by mesquite buckeye
