Baltic Abrasives Technologies
Author Topic: Building a small cabin using a csm  (Read 1235 times)
Offline Roland
« on: September 11, 2018, 06:13:42 PM »
Hello folks, wanting to introduce myself, my name is Roland. Im like most of you on here just love working with wood and if I can experience it in the outdoors all the better.
Let's get to it! A cabin project post and beam structure out of the pine trees that grow on my property and is only accessible by a 4x4 jeep trl, thus the reason for the csm.
Most of these trees are relatively small I might be able to finesse an 8x10 out of a few but most are going to be smaller, which is fine for what I need. I'll be cutting joist, rafters and flooring material for a 1bedroom 1,000sq ft cabin with a loft.
I have about 1k to spend on a csm and ripping chains to get started, what would you pro's reccomend for this project?
I personally would like new and was looking at the echo cs800p and husky 390
Adopt the pace of nature her secret is patience.
RWE
Offline thecfarm
Re: Building a small cabin using a csm
« Reply #1 on: September 11, 2018, 06:17:43 PM »
Roland,I just want to welcome you to the forum. Sounds like a great build. Take pictures,videos. I wish I would have more with some of my projects.
Offline Roland
« Reply #2 on: September 11, 2018, 06:35:06 PM »
Yes sir I'll do that thank you. I posted this here by accident should of been under the chainsaw forum. So I went ahead and re posted it there too.
RWE
Offline DelawhereJoe
  • Trapped in Delawhere
« Reply #3 on: September 11, 2018, 07:18:14 PM »
With milling more hp & cc is always better, most will probably recommend the 390xp over the cs 800p. I think I read somewhere that the Echo is around 6hp but for the small stuff it should work fine, its cheaper too by a few hundred dollars. A 24" csm will probably work for you but its always better to have to much then not enough.
Offline thecfarm
« Reply #4 on: September 11, 2018, 07:26:03 PM »
Kinda goes in either one. :)
Offline Roland
« Reply #5 on: September 11, 2018, 07:33:52 PM »
I found a 2100 series for $250 which looks surprisingly clean I think it might be the ticket
RWE
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #6 on: September 11, 2018, 07:36:14 PM »
Welcome to the Forestry Forum, Roland!
~Chuck~
I LOVE MY SAWMILL
Offline nybhh
« Reply #7 on: September 11, 2018, 07:41:26 PM »
1,000 sqft wonít seem so small when youíre halfway done!  Thatís a pretty good sized cabin by my standards.
Iíve built a couple of small outbuildings on our farm with pine Iíve milled from trees off the property and its a great feeling to go from tree to building with your own hands on your own land.
Iím just wrapping up about 1100 BF of 1x6 pine decking for a new roof on a 20íx40í barn and Iím going to replace the siding with 1x8s when Iím done with the roof.  Iím using a bandsaw mill though and youíll have to work a lot harder with a chainsaw but Iíve enjoyed it immensely.
Check you local building codes if you need permits.  Many are no longer approving ungraded/milled lumber for structural members.  I can get away with it here for AG out-buildings but you would need an architect or engineer to sign of on timber frame and ungraded structural ďlumberĒ would be a no-go.
Take lots of pictures!
Woodmizer LT15, Kubota L3800, Stihl MS261
Offline Roland
« Reply #8 on: September 11, 2018, 08:08:39 PM »
Thank you
RWE
Offline SawyerTed
  • Summey Lumber Services, LLC
« Reply #9 on: September 11, 2018, 09:00:02 PM »
Welcome to the forum.  Chainsaw milling is hard work.  A 20'x50' cabin with a chainsaw mill will take some time.  Working smart it can be done.  Try to get your logs off the ground so you aren't working on your knees.  It is tough on the knees and back if working on the ground.  Make sure you can adequately sharpen a chain in the field. Chains get dull quickly cutting pine logs unless you debark the log.
Invest in some quality cant hooks to handle the logs.    A portable winch will be an added benefit.
If you can swing the cost a manual band saw mill will make production much faster.
Woodmizer LT35HD25, Kubota MX5100, IH McCormick Farmall 140, Granberg Alaskan Chainsaw Mill, Husqvarna 372XP, Husqvarna 455 Rancher, Ram 3500 6.7 Cummins
Offline Peter Drouin
    • A&P Saw mill LLC
« Reply #10 on: September 11, 2018, 09:07:53 PM »
smiley_wavy Welcome aboard.
Offline Greenerpastures
« Reply #11 on: September 12, 2018, 10:19:54 AM »
Hi, what is a 2100 series, am not familiar with this.
Given the size of trees you have on your property, I would go with
the Echo, its cheaper too, and they are a good saw, older technology
and proven, the Husqvarna 390 originally had cylinder problems, they
bored it out and it cracked because the walls were too thin, this was
a long time back so hopefully they sorted it out, no such problems with
the echo, they may be a slower saw but they will last you.
And just to add am not knocking any brand, I used echo, makita, shindaiwa
stihl and had a new 372 husqvarna, I like them all, then had zero probpems
other than slight niggles, like dust in the carb of the shindaiwa, that only took
a piece of breathable material over a hole in the deck to solve, had bar oil
problem, but that turned out to be the wrong bar, it was modified to suit the
saw yet leaked oil all over the place, changed to the right bar and no oil all
over the saw, it went up the bar where it should, that echo CS800 also has an
additional hand pump for oiling the bar, which can help if you think the onboard
oiler is not enough, though this has not been an issue, I will in fact be buying
the echo 680 in the near future, no auto-tune or mtronic to cause me trouble,
just a straight forward carb.
Offline reride82
« Reply #12 on: September 12, 2018, 12:40:00 PM »
That 2100 husqvarna(series 2, approximately 100 cc) should mill just fine, as long as it stays running as parts are getting harder to find. It is a quite a bit heavier than say my 395xp, but in a milling situation it shouldn't make that much difference. I don't know if your local shop will work on it, so I hope you are handy! Chainsaw milling is hard work and adding a rope winch to your mill frame to help pull it through the log will make it easier. Good luck and post lots of pictures!
Levi
'Do it once, do it right'
'First we shape our buildings, then our buildings shape us'
Living life on the Continental Divide in Montana
Offline Roland
« Reply #13 on: September 12, 2018, 04:58:07 PM »
Hey everyone thx for the replies and kind words. I can see how a small winch to help pull the saw through the log would help watched a video on a cool little set up and will be getting one for sure.
Where these logs fall is where they will be milled. Not going to move them to a different area before milling no way.
I'm looking at a bunch of different old saws in the 90 to 100cc class for cheap. Echos,husky, McCulloch any favorites out of these three for milling?
RWE
Offline Roland
« Reply #14 on: September 12, 2018, 05:02:44 PM »
It's an 80's model 99cc husky. An oldie but goodie from what I hear.
RWE
Offline Roland
« Reply #15 on: September 12, 2018, 05:25:01 PM »
I can see having a local shop will b handy. I'll have to see who is in the area. Thx
RWE
Offline HolmenTree
« Reply #16 on: September 13, 2018, 09:42:35 AM »
Roland, another option is runs 2 powerheads on a double ended bar.
I modified this 36" hard nose bar to accept my 090 and 066.
No expensive machine shop needed I just used a drill press, angle grinder and bench grinder.
The powerheads don't need to be the same. The 090/066 milled perfect together.
Put 2 small 60cc saws together and you could rig up a second throttle by a cable to through the mills handle pipe. And still be able to work by your self.
Offline mike_belben
  • Pulp Friction
« Reply #17 on: September 13, 2018, 04:25:14 PM »
My back hurts just thinking about that
Revelation 3:20
Offline Don P
    • Calculator Index
« Reply #18 on: September 13, 2018, 09:01:00 PM »
Mind over matter, if you don't mind, it don't matter :D.  It might be just a tad slower but I do enjoy milling in the woods as opposed to working beside a pile in a pasture. I will admit we mainly use the csm for stuff that won't go on one of the other mills.
We've had a discussion sittin on the stump, how much hotter is that saw running?
DRP :)
Offline ehp
  • logger/chainsaw hack
    • ehpsaws.com
« Reply #19 on: September 13, 2018, 09:34:03 PM »
if the 2100 is in good shape grab it  or the 390 , 2100 is a good saw to mill with as its got lots of torque . Parts for it might be getting harder to find now thou
Started by Qweaver on Timber Framing/Log construction
Last post December 05, 2006, 06:59:03 PM
by Qweaver
Building a small cabin for a customer...
Started by ChrisGermany on Timber Framing/Log construction
Last post April 10, 2012, 10:11:24 AM
by ChrisGermany
Small TF Cabin Plan?
Started by wkheathjr on Timber Framing/Log construction
Last post July 05, 2009, 09:14:20 PM
by krusty
I want to build a small cabin....
Started by Papa on Timber Framing/Log construction
Last post February 25, 2012, 09:16:05 PM
by Sprucegum
