Baltic Abrasives Technologies
Author Topic: Why? Concrete in stump  (Read 1513 times)
Offline 20ozjolt
« on: September 12, 2018, 08:13:48 PM »
I was trying to cut a stump down after falling a clump of trees leaning over my barn and my chain (brand new to boot) stops cutting I pull out of the stump and the chain is damaged... no sparks.. so I get my other saw to solve the puzzle and its a fist size chunk of concrete. what I cant figure out is why its there.
At first I thought it was a rock hard ball of pitch tell i started smacking it with a hammer.
Offline Southside logger
Re: Why? Concrete in stump
« Reply #1 on: September 12, 2018, 08:15:34 PM »
Back in the day that was the solution to healing trees with rot or other hollows.
Offline 20ozjolt
« Reply #2 on: September 12, 2018, 08:25:40 PM »
huh heard of paper tar and twine... not this before ... but good to know.
Offline DelawhereJoe
  • Trapped in Delawhere
« Reply #3 on: September 12, 2018, 09:13:38 PM »
I've found super compressed clay/dirt, gravel and bark in hollow pockets of an at-grade stump/root ball of a pin oak where the roots had grown together to form one root. It would dull a chain in a matter of seconds, only way was to take a stump grinder to it to remove the bottom of the stump, I called it tree coal.
Offline Ron Scott
« Reply #4 on: September 13, 2018, 06:25:10 PM »
As stated, an old time tree repair still used today. Always be aware of yard trees and those around buildings.
~Ron
Offline lxskllr
  • dummy with saw
« Reply #5 on: September 13, 2018, 07:57:51 PM »
Does that work? Seems like it could trap moisture and bugs/microbes.
Offline esteadle
    • Steadwood Forest Products
« Reply #6 on: September 14, 2018, 04:40:24 PM »
I can't find any forestry folks recommending concrete to repair tree holes anywhere these days. Concrete / cement is alkaline and porous and rigid, and is mostly incompatible with wood. Some places say expanding foam. I hate that stuff personally.
Trees rot from the inside when water enters the trunk thru cracks, holes and insect damage.
So best bet is to prevent water from entering.
I would try to cover the open hole to prevent water sitting in the cavity.
Fasten a white oak board over the hole and let the tree fill in around it.
Remove it and re-fasten every couple of years to let the growth build up and close the whole.
Timber Harvester 30HT26 (setworks, hydraulic) Stihl 880 (36" bar).
Offline DR_Buck
  • Nuff said.....
    • Got Logs?
« Reply #7 on: September 15, 2018, 10:06:48 AM »
Here's one of several chunks of concrete we ran into milling a very large historic tree.    All told I think we took out 1 36" chain, 1 24" chain, 1 Peterson swing blade and several Wood-Mizer LT40 bands.
In the end it was worth is as the white oak was marketed as being recovered from "historic tree".  Some of it sold for $10-$12 a board foot.      ;D
Hidden Acres Farm
Been there, done that.   Never got caught
Wood-Mizer LT40HDG38
Lucas Dedicated 60" Slabber
Offline warren46
  • Been involved in sawing most of my life.
« Reply #8 on: September 15, 2018, 09:38:13 PM »
My father worked for Davey Tree Service in the 1930's.  Davey trained their tree surgeons to fill cavities with concrete.  An example is shown in the attached picture.
The concrete in this picture was textured to look like blocks.
Davey Tree Service is still in business but no longer recommends filling cavities with concrete.
Warren E. Johnson
Timber Harvester 36HTE25, John Deere 300b backhoe/loader.
Offline Ed
« Reply #9 on: September 18, 2018, 11:04:25 PM »
Dealt with it before, no fun.
Spent more time knocking out the concrete with an electric hammer than I did running the saw.
Started with a chain on it's last legs, think my buddy ran home and ground it 3 times before we finished. The tree was in his parents yard, his dad did the concrete job.
Ed
Offline baronthered
« Reply #10 on: September 19, 2018, 02:39:14 AM »
Old school fix for trees. Check out the YouTube channel arborist Blair glenn. Him and his crew.deal with lots of it.
Life's short make fun of it!
Offline PA_Walnut
« Reply #11 on: September 19, 2018, 06:02:02 AM »
Very cool heirloom pic!
I own my own small piece of the world on an 8 acre plot on the side of a mountain with walnut, hickory, ash and spruce.
LT40HD Wide 35HP Diesel
Baker Portable Edger with Kubota Diesel
Kubota M62 Tractor/Backhoe
WoodMizer KD250 Kiln
Online bandmiller2
« Reply #12 on: October 17, 2018, 08:35:13 PM »
I sware  dumb squirrels mistake small stones for acorns and hide them in trees. Ether that or their pist off for being shot at. Frank C.
Offline HolmenTree
« Reply #13 on: October 18, 2018, 09:55:47 AM »
I removed a old American elm like the one in above photo years ago that died from Dutch elm disease.
It was a grand old tree that the well to do owners spent a lot of money to save it over the years before it died from the disease.
Wish I had a smart phone back then when I removed it as it would have made a great picture. It looked alot like the above photo of the codominant elm tree with the bolt brace and etched concrete to look like cinder block.
The owners hired a Portuguese stone mason who etched the concrete to look like the surrounding bark. Quite impressive.
I had to hire a loader operator to haul it away to the landfill.
Stump Not tree stump remover?
Started by gspren on Ask The Forester
Last post April 29, 2013, 12:56:50 PM
by gspren
stump removal - best way to rot a stump
Started by PB Logging on General Board
Last post October 18, 2018, 09:54:04 AM
by Al_Smith
Concrete will not set.
Started by DR_Buck on General Board
Last post February 01, 2018, 07:09:05 AM
by barbender
concrete
Started by coxy on Firewood and Wood Heating
Last post July 18, 2016, 06:59:53 PM
by stumper
