Council Tool
Baltic Abrasives Technologies
Author Topic: JD 440a info  (Read 1035 times)
Offline Bucksaw
JD 440a info
« on: September 14, 2018, 03:25:18 PM »
I bought a old JD 440. A series I think. When I cold start, she fires right up and the battery/ starter spin over fast. When I shut off and then go to restart it will barely turn over. Let it sit for a 1/2 hour and it spins over fine and fires up. Did some reading and found the suggestion that hydraulic pressure build up makes it turn over slow and to wiggle the steering wheel while starting will help.
I am going to replace the battery anyway, but havenít had the chance to try the wheel wiggle trick yet.
Anyone have this issue?
Pics of the old girl to follow. Serial number indicates a early 1967 440 Series A made in Welland Ontario.
Offline Grandpa
Re: JD 440a info
« Reply #1 on: September 14, 2018, 07:29:06 PM »
Wiggling the wheel is a pretty common trick.
A better way to isolate the problem is to take the grill off, on top of the pump you should find a screw with a T handle. Turn the screw in until you feel resistance, then turn it one more turn, that will destroke the pump so it wont pump at all.
Offline Bucksaw
Re: JD 440a info
« Reply #2 on: September 14, 2018, 08:44:01 PM »
Thanks. I am aware of the front pump screw. I anticipated doing this in cold conditions. I was wondering if the battery was on itís way out and the wheel wiggling was just to make starting with a bad battery easier.
Offline Maine logger88
  • Don't force it get a bigger hammer
Re: JD 440a info
« Reply #3 on: September 14, 2018, 09:21:33 PM »
A lot of times the roosa master fuel pump will wear out and the wonít start when hot but it usually doesnít make it turn over slow like you say. I would look into the starter I wonder if itís dragging when hot
79 TJ 225 81 JD 540B Husky and Jonsered saws
Offline Bucksaw
Re: JD 440a info
« Reply #4 on: September 14, 2018, 09:29:11 PM »
Thanks for the info. I only started and shut it off less than a minute later, so it wouldnít have had a chance to heat up.
Re: JD 440a info
« Reply #5 on: September 14, 2018, 09:31:45 PM »
Ok then disregard what I said. Probably your on the right track with the hydraulics
Offline Grandpa
Re: JD 440a info
« Reply #6 on: September 15, 2018, 07:07:48 AM »
I think that engine should have a stanadyne (spelling?)pump.
Offline snowstorm
Re: JD 440a info
« Reply #7 on: September 15, 2018, 07:25:59 AM »
shaking the wheel to start is normal with an old 440. when it was built they had a small sorta round injection pump. rosoa master. they were troublesome. in the early 80's deere had a update kit. a new standadyne pump and fuel lines. i dont recall what i paid for the kit. around 1k
Offline Bucksaw
Re: JD 440a info
« Reply #8 on: September 15, 2018, 07:48:13 AM »
Thanks for the info. Apparently this one didnít get the update.
Offline teakwood
  • Switzerland
Re: JD 440a info
« Reply #9 on: September 15, 2018, 08:48:27 AM »
My 540A does the same. hit the key when cold and she starts right up, when warm i have to wriggle the steering wheel hard just to get her started. so i tend to not shut her off to often
Offline Bucksaw
Re: JD 440a info
« Reply #10 on: September 15, 2018, 08:58:59 AM »
Good to know. I guess the old iron is temperamental. Lots to learn. Any additional info would be much appreciated.
Offline Jack Lilley
Re: JD 440a info
« Reply #11 on: September 15, 2018, 08:19:30 PM »
I had forgotten all about wiggling the wheel thing, it works, can see my father wiggling the wheel  every time he started the old JD.
Offline Bucksaw
Re: JD 440a info
« Reply #12 on: October 13, 2018, 07:10:48 AM »
Pics added
John Deere 440A info
Started by mjeselskis on Forestry and Logging
Last post February 09, 2018, 08:00:22 AM
by tacks Y
440a
Started by stoneeaglefarm on Forestry and Logging
Last post March 07, 2017, 06:09:25 AM
by David-L
JD 440a tires
Started by thumper on Forestry and Logging
Last post February 08, 2010, 09:01:43 PM
by Bobus2003
jd 440a engine
Last post June 21, 2011, 12:47:32 AM
by John Woodworth
