Author Topic: 640D winch-how to secure cable in it?  (Read 408 times)
Offline Oliver05262
« on: September 15, 2018, 09:36:47 PM »
  I know this has been covered before, but I couldn't find the thread; how do you secure a mainline cable in the winch drum ? The other JD's I've worked on had an eye you ran the cable through, you either had a swaged knob or tied a knot to hold the cable in. This drum just has a pocket to drop the swaged end in.
  He had me weld a strap across to hold the cable in place, but that blew right off. 7018 never held to the drum - cast iron? They fooled around today and got it secure. Is this how you're supposed to do it?
"You can't do wrong by doing good"
It's OK to cry.
Offline Firewoodjoe
  • Im getting old
Re: 640D winch-how to secure cable in it?
« Reply #1 on: September 15, 2018, 09:59:19 PM »
It needs to keep a few wraps on it and it holds it in. Those bolt on straps on our 648s donít really hold much just in case u unspool to much.
Offline Huntaholic
« Reply #2 on: September 25, 2018, 10:09:44 AM »
As Im sure you know, its supposed to have a plate and a bolt that holds the plate over the head. Yours is actually in better shape than any of mine. What I did was have my welder fix it with a heavier piece of plate across that hole, and run the cable under the plate, insert a horseshoe wedge type wedge for another winch type setup, then loop the cable back through the hole and drive the horseshoe down under the plate to hold the cable in place. The way you did it will work but its impossible to spool your cable on perfectly that way. Its always going to have a cross up in it and anytime a cable jumps over itself it weakens the cable. Plus if its not evenly on the drum you cant spool as much cable! BTW, that drum CAN be welded, your welder just didn't use the right rods, current, or something.
Offline dnash
« Reply #3 on: September 25, 2018, 04:43:15 PM »
I do it almost the exact same way. The only difference is our cable dont come with the knob on the end so we use a 5/8 cable clamp.
JD 440C
JD 640D
Timberjack 205HR
JD CT322 skidsteer
Winch cable for Farmi351 winch
Started by fireman05 on Forestry and Logging
Last post April 23, 2007, 08:04:17 PM
by thecfarm
Winch cable
Started by David s Forest on Forestry and Logging
Last post January 24, 2019, 11:19:03 AM
by David s Forest
Winch cable
Started by Upnorth on Forestry and Logging
Last post August 09, 2014, 11:26:12 AM
by BargeMonkey
I need a new winch cable
Started by moosehunter on Forestry and Logging
Last post February 06, 2013, 10:00:10 PM
by clww
