Author Topic: WM Drag sharpener (sold)  (Read 8704 times)
Offline Stephen1
  • Where there is a will, there is a way!
    • muskoka Sawmill
« on: September 23, 2018, 10:15:18 AM »
I have a an older Wood Mizer drag sharpener for sale. It has a 4-9-and 10 degree cams, newer drive motor, newer water pump and 2 new grind stones, plus the grind stones i am using now.
$450 or best offer, I am in Ontario
PS for the right price I might throw in the setter
I have read and understood all the terms and conditions and agree to pay the commission to  the FF
Offline Revival Sawmill
  • making sawdust.
Re: WM Drag sharpener
« Reply #1 on: September 23, 2018, 10:44:38 AM »
How old of a model is it?  Pictures?
Thanks,
Offline Stephen1
    • muskoka Sawmill
« Reply #2 on: September 24, 2018, 02:08:08 PM »
I would think it is from the early 90's
Offline jmur1
  • Wood is King
« Reply #3 on: October 18, 2018, 11:43:59 AM »
I am interested - can you pm me contact info?
Easy does it
Offline LeeB
« Reply #4 on: October 20, 2018, 12:47:59 PM »
Just as a tidbit of info, The motor in the picture will also work on the adjustable blade guide arm on a '98 super. I robbed the one off of my old WM drag sharpener.
WM Drag sharpener.
Started by tacks Y on Sawmills and Milling
Last post June 19, 2016, 03:45:14 PM
by woodmills1
drag sharpener fix
Started by pineywoods on Sawmills and Milling
Last post January 13, 2019, 04:33:47 PM
by pineywoods
Old WM Drag Sharpener /Resurrection
Started by Mt406 on Sawmills and Milling
Last post January 29, 2018, 08:29:02 AM
by Mt406
Rebuilt drag type sharpener
Last post December 31, 2014, 10:18:44 AM
by LeeB
