Author Topic: Cutting hung up heavy leaning trees UPDATED 1/7/19  (Read 2970 times)
Offline Al_Smith
Re: Cutting hung up heavy leaning trees
« Reply #40 on: October 07, 2018, 07:54:13 AM »
I use my pole saw attachment pretty often on tangled messes, just start where the branches are 4-5" and work my way bigger. I like the extra distance and reaching over some to get at others is nice.
Actually last year I did the very same thing .Wind blown top of a huge bitternut ,around 24 inch where a straight line wind broke it 40 feet up in a 100 footer .The spar is still standing ,3.5 feet at the base .
After I "fence posted" the top until it was nearly straight up I broke it loose using snatch blocks with a 4 part line and a tractor .Could not  get to it with a bucket truck and it was too dangerous to climb .Around two cords of firewood with maybe 1500 bd ft of saw log still standing which may end up as firewood depending on what mood I'm in at the time .
Offline Tramp Bushler
  • I am blessed
« Reply #41 on: October 14, 2018, 02:56:29 PM »
 If I was in your area I'de come by and get it all bucked down for you. As I'm not all I can do is hope and pray for you. If you can move the logs as you cut them off that will help.
You don't have to worry about brown bear when your power saw is running . But you better have something big with you if it's not .
 If your not wearing your hard hat when you need it. Well.
moved
MOVED: Cutting hung up heavy leaning trees
Started by chet on Ask The Forester
Last post September 25, 2018, 07:30:05 AM
by chet
Trying hard not to swear - guy cutting great trees for posts :( (photo heavy)
Started by asy on General Board
Last post October 10, 2005, 12:28:17 PM
by Gilman
Leaning trees
Started by luvmexfood on Forestry and Logging
Last post September 29, 2013, 05:58:23 PM
by Ed_K
cut used to remove hung trees
Started by murphy4trees on Urban and Community Forestry
Last post March 04, 2014, 12:52:52 PM
by LittleJohn
