Author Topic: Grease guns  (Read 1917 times)
Offline btulloh
Grease guns
« on: September 26, 2018, 09:06:30 AM »
Seems I'm always fighting a losing battle with grease guns.  The only dependable one I've got was purchased in the sixties.  All the recent ones seem to have issues.  I doubt there's any reason to bore y'all with the details.  The question really is: Where are the good grease guns?  What kind of grease gun have you bought that you like?
Ideally I like to have a few with different kinds of grease for different requirements.  Three is about right.  Maybe a fourth so I can have both a flexible hose and a rigid snout for regular grease.  Then you get into the pistol vs. lever question.
Where are you finding dependable grease guns?
(My favorite malfunction is the plunger that comes unlocked when you're putting in a new cartridge.  The plunger releases itself just after you've inserted a new cartridge and ejects most of the grease.  Fun.)
Online Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: Grease guns
« Reply #1 on: September 26, 2018, 09:25:43 AM »
Here is a topic that ran a couple of years ago:
Equipment... Grease Gun Recommendation in Forestry and Logging
Offline btulloh
Re: Grease guns
« Reply #2 on: September 26, 2018, 09:32:03 AM »
That's a good discussion on powered grease guns.  I haven't felt the need to go powered, but maybe I should re-think that.  For the most part, hand-powered works for my needs if I just had dependable guns.
Offline Southside logger
Re: Grease guns
« Reply #3 on: September 26, 2018, 10:43:27 AM »
The Dewalt 20V with a Lock-N-Lube on the end is some hard to beat.  Frozen zerks are not a problem, hard to reach spots you don't need two hands on the gun itself, the hose does not fall off.  Worth the money.  You get more grease into the zerk and less on you, more than I can say for all the old fashioned ones I have had.
Offline SawyerTed
  • Summey Lumber Services, LLC
Re: Grease guns
« Reply #4 on: September 26, 2018, 12:57:59 PM »
btulloh, I feel your pain.  I have four grease guns, only one of which I purchased.  None work especially well.
Woodmizer LT35HD25, Kubota MX5100, IH McCormick Farmall 140, Granberg Alaskan Chainsaw Mill, Husqvarna 372XP, Husqvarna 455 Rancher, Ram 3500 6.7 Cummins
Offline scsmith42
    • Whispering Pines Farm
Re: Grease guns
« Reply #5 on: September 26, 2018, 01:58:49 PM »
I got 30 years out of my first Alemite, and replaced it with a 2 speed Alemite earlier this year.  It has a lock and lube coupler on it and a pistol grip.  Works great.
I've had a 12V Lincoln for about 10 years and also like it.  No issues with it whatsoever.  Only had to replace the battery once.
Tom's 3638D Baker band mill
Offline petefrom bearswamp
  • made 70-11 and still feelin pretty darned good!
Re: Grease guns
« Reply #6 on: September 26, 2018, 02:09:58 PM »
Southside  have had 2 zerks that my dewalt 20v wont overcome so far.
Otherwise it is great.
Locknlube on it too.
LT40SHDD51
Kubota 900 RTV
Polaris 550 Sportsman ATV
1 Husky 1 gas Echo 1 cordless Echo
241 acres of woodland
Online Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: Grease guns
« Reply #7 on: September 26, 2018, 02:12:02 PM »
I have not either.  I have a regular sized pistol grip at the farm but I do not remember what brand it is.  I use a small Lucas pistol grip on the sawmill.
Offline YellowHammer
  • Always taking steps to save steps
    • Hobby Hardwood Alabama
Re: Grease guns
« Reply #8 on: September 26, 2018, 02:53:12 PM »
I used use a pneumatic gun for years but it would occasionally do more damage than good, blowing seals out. I dont use it anymore.  I use maybe three or four cases of grease a year, so I use a decent amount of grease, but not overly so.
I also highly recommend the LockNLube tip already mentioned.  I now have a favorite, with a cam lock plunger, and its been refitted with a flex hose and also the spring lever locking tip that opens like a clam, then locks on the zerk.  It will reach most any place, and wont pop off.  To release, just press the lever, and no more pulled out fittings.  No more wasting grease where the tip wont seal, and no more having to adjust tips for worn down zerks.  I got the thing at our local farmers COOP and when I questioned if it was any good, the guy said Youll like it.  I do.  Its a LockNLube and cost more than my grease gun, $30.  Teamed with a flex hose, its the only gun I reach for now.  No more bending over and pumping a gun.  Its that good.
https://locknlube.com/products/locknlube-grease-coupler
HobbyHardwoodAlabama.com
Offline barbender
Re: Grease guns
« Reply #9 on: September 26, 2018, 04:10:01 PM »
One of the main problems I've had with grease guns is that they won't prime. That's very frustrating. I've been using a Milwaukee 18v for the last 2 years, it's been a great gun and always primes quickly after putting in a fresh tube. However, it quit working a few weeks ago (power issue of some sort, could be as simple as the battery). I'll know when I getit back from the repair shop.
Offline LAZERDAN
Re: Grease guns
« Reply #10 on: September 26, 2018, 08:00:58 PM »
Hello.   I have been in your shoes, most grease guns are crap.  Until i found the alemite with the lock and lube tip.  You don't need to look further.  Here's the link. Hope it works
       well that did'nt work
Offline btulloh
Re: Grease guns
« Reply #11 on: September 26, 2018, 09:01:02 PM »
Great info. Thanks .
Looks like the alemite plus the locknlube tip is what i need .  If i add that to what i have on hand i should be in good shape . I really like the idea of that locknlube tip .It should work in 90% of the situations and i have plenty of tips to cover the rest.
If a zerk gets plugged, i usually just replace it. Zerk assortment is my best friend .Thought about getting one of those little zerk buster things you tap with a hammer, but I've been getting along ok without it.
Good info .Thanks for the replies.
HM126
Offline blackfoot griz
Re: Grease guns
« Reply #12 on: September 26, 2018, 10:37:43 PM »
Years ago, I actually dumped an assortment of sae and metric grease zerks on the floor... simultaneously. They mixed up nicely. That was brilliant!
Offline scsmith42
Re: Grease guns
« Reply #13 on: September 27, 2018, 11:54:40 PM »
One nice thing about the cordless grease guns is that your hands dont hurt as much if you have the onset of arthritis.
Offline Al_Smith
Re: Grease guns
« Reply #14 on: September 28, 2018, 06:00:33 AM »
I probably have at least a half dozen all lever action .Most have zert fittings and two have button head Alemite oil fittings for track rollers on bulldozers ,3/8" and 1/2" .
Offline 62oliver
Re: Grease guns
« Reply #15 on: September 28, 2018, 07:26:37 AM »
After I saw this video I had to apologize to my son for failing him as a parent, as it solves the most common issue I have ever had with grease guns.
Husqvarna 266, Case 90xt, JD310C, TJ240E, 02 Duramax
Re: Grease guns
« Reply #16 on: September 28, 2018, 09:00:26 AM »
And here I was hoping for some magic formula for doing this.
Informative tho for those great unwashed who do not have a clue.
Like him I sure dont know everything just like batman.
He made an observation to Robin about something and Robin responded gee batman is ther anything you dont know?
Batman replied why yes robin as a matter of fact several things.
LT40SHDD51
Kubota 900 RTV
Offline scsmith42
Re: Grease guns
« Reply #17 on: September 28, 2018, 01:24:34 PM »
An old timer showed me that tip about 12 years back.  Sure solved a lot of frustrations and works great.
Offline maple flats
  • Life is what you make it!
Re: Grease guns
« Reply #18 on: September 29, 2018, 08:11:05 AM »
After years of greasing old farm equipment, and some newer using the old design type grease guns (I have 6 or more), most lever handle and one pistol grip handle I recently bought a Lube Shuttle. It is a new design, but requires their grease cartridges. So far I love it. There is no plunger. The tube is threaded on the business end and you just push on a sliding follower to bring some grease up out of the top slightly, then screw the cartridge on. Then a steel tube screws on to protect the plastic grease cartridge. No bleeding needed and so far I've only used 4 or 5 tubes but all emptied completely, then changing was neat and painless, no bleeding and I was back at greasing again. I have a lock n lube coupler, but the threads are slightly different and I just ordered a locking coupler for the grease Shuttle (metric threads). The Lube Shuttle is made in Germany, Best grease gun ever.
Offline Novascotiamill
  • I walked the Thin Blue Line for 20 years
Re: Grease guns
« Reply #19 on: September 30, 2018, 12:57:27 PM »
My favoritebgrease gun was a blue lincoln with a rigid tube,worked everytime and always primed on a new tube.lent it to a friend with backhoe and he returned a new in box grease gun,said he ran over mine by accident.,new one was piece of junk.never lent that guy another tool.
I use a 18 volt now which I find much easier to grease the tractor and backhoe with arthritis and no wind anymore. Only thing I dont like about it is the rubber hose thats seems to strike you like a cobra if its full of grease,everytime especially if your not wearing coveralls :( :( :( :(
2017 HM130
Stihl 261
2010 F150 xtr
Lots of rigid genx5 tools
1 long haired german shepherd
2017 kioti ck2610HST with FEL and forks
Grindlux band sharpener
Wicked 55 root rake grapple
O
Rechargeable battery powered grease guns
Started by NWP on General Board
Last post January 04, 2015, 08:45:57 AM
by CTL logger
Men with guns
Started by Peter Drouin on Sawmills and Milling
Last post January 08, 2016, 12:48:39 PM
by Sixacresand
Water Guns
Started by Autocar on Forestry and Logging
Last post July 16, 2012, 12:07:19 PM
by Al_Smith
Young Guns
Started by timberfaller390 on Forestry and Logging
Last post April 17, 2008, 08:30:24 PM
by timberfaller390
