Author Topic: God watched over another fool  (Read 830 times)
Offline mad murdock
« on: September 26, 2018, 10:06:10 AM »
Well, the fact I am typing this is a miracle.  Last Saturday, in an effort to help my neighbor who is paraplegic since 19-20 years old (now in early 60’s) remove a large WRC that had fallen across the creek, I took a tumble of sorts.  The scenario was thus, 35’ of 4’ + dia wrc spanned his creek, he was worrried with winter coming on, that it could plug the creek, near where they have a hydro power plant and earthen dam. Plan was to clean up the remaining portion (35’ long) that bridged from bank to bank, and remove.  Problem was it was too large for his Takaheuchi tracked skid steer with logging grapple/arch/winch to move. I went out on the “bridge”, limbed all remaining limbs so we could size up what we were up against, that all went well.  Decided to cut from the small end 19’ which put me about 12-15’ over the ground. Plan all went well, I carefully cut vertically, leaving “leave wood” in the center of the cut, whereby he could tug on the small end and break it off, after I had safely gotten off the log, obviously.  Made the initial cut until it “popped” and dropped an inch or so, got off and he tried to move it, too big, heavy for his machine to twitch, so I felt good about going back out and relieving a bit more, did so, it popped and moved a little more, I got off the log, he still couldn’t move it.  I began to tell him, I thought we needed a larger machine. He felt he could move the pieces if we could just separate the 2, so I talked myself into going out one more time(that was my mistake), and was going to relieve a bit more leave wood, well I no sooner touched the chain to the cut, and pow! It let loose, luckily I was on the piece that dropped horizontally, but as it dropped it rolled a bit, kicking my legs out from under me, I went down about 10-12’ on my back landing on branches, but the surprise was that there was a branch sticking straight up like a stobb, about 2-2 1/2” in dia, broken off that poked me in the back, very fortunate, did not puncture skin, hit me to the right of spinal column, and below ribs, no broken bones, no kidney damage, just real sore muscles and back.  Had help there who was able to help me up, and after gaining composure for a few min, I was able to “line” myself up the cable line about 20’ to get up out of the creek bottom. Long story short, if you don’t think something is a good idea, don’t let yourself get talked into doing something risky! Not even by yourself!  I am grateful to still be amongst the living, and share my story here so that maybe it will cause someone(even myself) to really think twice before hitting the stupid lever!  God is Great, and miracles do happen, this fool was watched over by Divine providence last Saturday!
JD AMT 626, Turbosawmill M6 Warrior Ultra liteweight, Granberg Alaskan III, lots of saws-gas powered and human powered :D
Offline ljohnsaw
Re: God watched over another fool
« Reply #1 on: September 26, 2018, 10:34:39 AM »
 :o
Wow, a very close one!  You were lucky that day.  Glad you injuries were limited and you weren't skewered!
John Sawicky
Online WV Sawmiller
    • Green's Sawmill Services
« Reply #2 on: September 26, 2018, 10:41:46 AM »
    Glad you are okay.  How come we never learn not to do dumb things until after we have already done them? ;)
Offline Southside
« Reply #3 on: September 26, 2018, 10:50:23 AM »
Because we don't consider the implications of what will happen if things don't go the way we expect them to.  At least that has been the lesson I have learned after doing such things.
Glad to hear you are OK - obviously that could have turned out very differently.
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #4 on: September 26, 2018, 11:07:46 AM »
Whew...……. You were very lucky!  ;)  :)
Thank God!
~Chuck~
1995 Wood-Mizer LT40HDG2425 Kohler - Shingle & LapSider, Cooks Cat Claw Sharpener and single-tooth setter, 4-foot Logrite cant hook.
Offline Stephen1
  • Where there is a will, there is a way!
    • muskoka Sawmill
« Reply #5 on: September 26, 2018, 11:19:36 AM »
Thank you to above for keeping green side up another day!
Offline sawguy21
« Reply #6 on: September 26, 2018, 11:44:01 AM »
 :o You are very fortunate, that could have resulted in a broken back or worse! Thanks for the reminder, occasionally we need them.
Offline petefrom bearswamp
  • made 70-11 and still feelin pretty darned good!
« Reply #7 on: September 26, 2018, 02:17:17 PM »
Wow Glad you are OK.
I have certainly had my share of stupid careless mistakes.
LT40SHDD51
Kubota 900 RTV
Polaris 550 Sportsman ATV
1 Husky 1 gas Echo 1 cordless Echo vintage Homelite super xl12
241 acres of woodland
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #8 on: September 26, 2018, 02:19:29 PM »
First and most important I am glad to read where you are/will be OK.
Now, what about the log?
Offline SawyerTed
  • Summey Lumber Services, LLC
« Reply #9 on: September 26, 2018, 06:24:34 PM »
Thankful it wasn't any worse than it was!  Things can occur so quickly and in unexpected ways.  You are right, be very suspicious of sketchy situations.  If it feels dangerous, more than likely it is.
Where's the log now?
Woodmizer LT35HD25, Kubota MX5100, IH McCormick Farmall 140, Granberg Alaskan Chainsaw Mill, Husqvarna 372XP, Husqvarna 455 Rancher, Ram 3500 6.7 Cummins
Offline mad murdock
« Reply #10 on: September 26, 2018, 10:01:20 PM »
I am doing pretty well considering, I did stop by the neighbors place on the way back from working on helicopters today, to size up what they were able to bring up to the top of the dam. They were able to load an 8 and a 10 with trim, and the butt log is 8 with trim. There is a nice clear piece about 5’ long that will make some nice shakes , just have to drag it up. Will get some pics over the next few days. Thanks for the thoughts on my behalf too!  Just want to share things so others can learn from my mistakes without having to learn themselves first hand.
Offline thecfarm
« Reply #11 on: September 27, 2018, 07:03:45 AM »
He's watches over me a few times.
Offline Hilltop366
« Reply #12 on: September 27, 2018, 08:47:01 AM »
Sounds like you had a Wile E. Coyote kind of day!
Offline Ed_K
« Reply #13 on: September 27, 2018, 10:05:46 AM »
 What a day, happy your ok.
Ed K
Offline YellowHammer
  • Take Steps to Save Steps
    • Hobby Hardwood Alabama
« Reply #14 on: September 27, 2018, 12:39:18 PM »
I’m glad you are OK, could have been a lot worse.
I for one, would grudge saw that log with extreme prejudice. ;D
HobbyHardwoodAlabama.com
Offline Southside
« Reply #15 on: September 27, 2018, 04:17:55 PM »
Terminate with extreme prejudice.... Never thought of you as the spook type there Hammer.   :D
Fool Bird
Started by Peter Drouin on The Outdoor Board
Last post May 07, 2015, 06:52:49 PM
by Peter Drouin
I'm a sharpening fool now..
Started by Joanie on Sawmills and Milling
Last post August 21, 2012, 09:38:46 AM
by terrifictimbersllc
A fool and his Lucas
Started by JohnM on Sawmills and Milling
Last post March 03, 2014, 03:18:57 PM
by sigidi
Fool answering machine
Last post April 28, 2006, 08:22:40 PM
by Tom
