Author Topic: another 640D skidder question--parking brake  (Read 266 times)
Offline Oliver05262
« on: September 26, 2018, 10:09:31 PM »
  We'll just wait to see what breaks next. Well, the rear u-joint came loose and the shaft flailing around broke off the fitting where the release hose attaches to the park brake housing. How do I get that brake off and apart?
  We took the rear driveshaft out completely so we can drag the machine out of the hole it's in with help from another skidder (TJ to the rescue). When the machine is out on the level, can I just drain the oil out of the rear axle and remove the yoke; then unbolt the brake assembly and slide it forward and off the pinion shaft? It's been out before for a previous owner, as the fitting and boss had already been welded on.
  I'd kinda like to hear from someone who has done this job before I tackle it. Thansk
p.s. Pictures will be posted as I get into the job.
"You can't do wrong by doing good"
It's OK to cry.
Offline Maine logger88
  • Don't force it get a bigger hammer
Re: another 640D skidder question--parking brake
« Reply #1 on: September 26, 2018, 10:36:55 PM »
I have never worked on one before so I dont know what you need for a bolt or exactly where to put it but I do know there is a place to put a bolt in to release the brake similar to a caging bolt on a maxi.
640D parking brake
Started by Oliver05262 on Forestry and Logging
Last post May 18, 2016, 10:31:32 PM
by thumper
parking brake cable for franklin skidder
Started by lynde37avery on Forestry and Logging
Last post April 25, 2014, 08:02:51 PM
by lynde37avery
1985 548d parking brake pressure switch question
Started by CuddleBugFirewood on Forestry and Logging
Last post August 29, 2012, 10:20:29 PM
440d parking brake
Started by Nemologger on Forestry and Logging
Last post August 16, 2015, 10:01:28 PM
by Nemologger
