Author Topic: Kiln Help  (Read 993 times)
Offline ehewitt05
Kiln Help
« on: September 27, 2018, 10:18:20 AM »
Does anyone on here have any experience with kiln drying their lumber? I've been reading a decent amount recently about people using Nyle Dehumidifying units with a shipping container and I'm thinking it would work for what I would need it for.
However, I would l love to find something that was an indirect hot air system using natural gas as we have free natural gas off the old wells on our farm. Too dangerous maybe? Not enough humidity control? Not sure just looking for some insight here.
Thanks!
Offline YellowHammer
  • Aerospace Engineer Owner Full Time Lumber Business
    • Hobby Hardwood Alabama
Re: Kiln Help
« Reply #1 on: September 28, 2018, 07:05:13 AM »
There are kiln manuafacturers that sell gas fired kilns, some designed specifically to run off natuaral has.  Kiln Direct is one.
Some people also use a heat source to force hot water through a radiator or Modine style heater in the kiln chamber.  Typically the heat is produced from a wood fired boiler but gas could also be used.
HobbyHardwoodAlabama.com
Offline No_Dude
Re: Kiln Help
« Reply #2 on: September 28, 2018, 11:20:28 PM »
Brother thats a goldmine for a kiln with that free gas. I have only read up on Dehumidification kilns, but I can tell you that there are gas fired kilns, and you will knock a lot off your bottom dollar with that free fuel
Offline GeneWengert-WoodDoc
Re: Kiln Help
« Reply #3 on: September 29, 2018, 08:58:48 AM »
Kilns can use just about any practical energy system to provide the desired temperature and humidity.  However, direct fired kilns do not control humidity very well...usually much too dry...so a gas unit will have to a plenum chamber to transfer the heat, like a furnace does in a home.
Offline scsmith42
    • Whispering Pines Farm
Re: Kiln Help
« Reply #4 on: September 29, 2018, 01:52:52 PM »
Gene, what about a DH kiln that uses gas to operate the DH unit (similar to the way that a propane powered refridgerator works in an RV)?
Tom's 3638D Baker band mill
Offline K-Guy
    • http://www.nyle.com/
Re: Kiln Help
« Reply #5 on: October 01, 2018, 08:37:05 AM »
scsmih42
I work at Nyle a DH kiln supplier. You could do that but I don't know of anyone making equipment for it. The easiest and probably cheapest way to do that would be with a gas powered generator to supply power. It would also be easier to get parts for maintenance down the road.
Nyle Kiln Sales & Service
Offline Don P
    • Calculator Index
Re: Kiln Help
« Reply #6 on: October 02, 2018, 06:02:44 AM »
Along that thought, you could also grid tie the generator to sell the excess electricity and put the radiator in the kiln, using the engine coolant water to run a conventional kiln.
That is an interesting thought Scott, our old Dometic would run about 40 degrees cooler than ambient, I'd think you would be condensing. It was a happy day when I pulled that thing out of the camper though.
Offline No_Dude
Re: Kiln Help
« Reply #7 on: October 03, 2018, 03:47:38 PM »
I wonder how much heat you could pull from that generator? I wouldn't think it would be enough to run a conventional, but maybe in a pre-dryer? I'm thinking something along the lines of the same principle of a solar kiln, pump the heat in, and leave some vents cracked and let natural air currents go to work sucking air in and out. Fans would be on inside to clarify, just natural air pull for venting.
Offline scsmith42
Re: Kiln Help
« Reply #8 on: October 03, 2018, 10:17:09 PM »
scsmih42
Good idea re the Generator (and I own two L200ís).
Offline dougan2469
  • In over my head
Re: Kiln Help
« Reply #9 on: October 15, 2018, 06:58:55 AM »
I would recommend looking for a "small" used class 2 hot water boiler.They are basically super fast recovering water heaters...Stay away from the high pressure steam boilers unless you know how to service them yourself.
Boiler technicians are expensive... ;-)
Pre-build solar kiln questions(Photos of kiln building progress)
Started by caveman on Drying and Processing
Last post April 17, 2016, 06:35:35 PM
by caveman
converting a bulk tobacco kiln into a lumber kiln
Started by Bryce on Drying and Processing
Last post February 18, 2010, 11:09:27 PM
by scsmith42
All the experienced kiln driers. Solar kiln or power?
Started by woodjunky on Drying and Processing
Last post December 13, 2014, 09:52:31 PM
by GeneWengert-WoodDoc
Newbee question: Solar Kiln or DH Kiln?
Started by WoodenHead on Drying and Processing
Last post April 28, 2012, 09:31:17 PM
by jdonovan
