Author Topic: Truckload of cull logs  (Read 1068 times)
Offline labradorguy
  • I stand for our Anthem
« on: September 28, 2018, 09:17:07 AM »
I am needing to supplement my log supply and was thinking about buying a truckload (big truck pulling a pup) of culls from one of the local mills and giving that a try. They have quite a few small diameter culls that have been down awhile and they would not mind getting them out of their way. I am thinking if I processed them, I would be able to sell them in a month or two since they are small diameter and already greyed out.
My question is, does anyone have a good estimate of how many cords a person could expect out of a load like this? Just a rough idea... And secondly, what are people paying for a truckload of culled hardwoods?? I know prices change in different areas, but I just wanted an idea. If someone has some Ozark prices, that would be great.
Thanks guys.
Offline armechanic
Re: Truckload of cull logs
« Reply #1 on: September 28, 2018, 09:44:00 AM »
transportation will likely be the big cost.  If you can move them yourself would help. I don't know what the cost would be, but, Tie logs are about $250 mbf at the mill. (what the mill pays) If you can find a landowner that has some cull logs and tops
 it might be cheaper.
1989 Lt 40, D6C CAT, Home made wood processer in progress.
Offline Mapleman
« Reply #2 on: September 28, 2018, 12:41:06 PM »
I figure a tri axle log truck load of long length (20 feet) or so) firewood at 7 cords and the pup at 5 cords, so 12 cords total. Several times I've run a truck and pup load of firewood through the processor, keeping it separate from wood already on the landing, and its come out pretty close to those figures.  Of course this can vary a lot, depending on the wood itself, who's doing the loading, the truck, etc.
"The older I get, the better I used to be."
Offline Corley5
  • Wolverine, Michigan
    • Whittaker Farms
« Reply #3 on: September 28, 2018, 02:41:21 PM »
A 20 cord load of hardwood pulp is $1,600.00 delivered to me in Northern Lower Michigan.
Offline realzed
  • Old Fart but - I'm new!
« Reply #4 on: September 28, 2018, 09:20:07 PM »
I recently had a double load - tri axle truck with two piles of 10 foot all maple logs 6" - 14" in diameter and a pup with a double load of 10 footers as well all piled up right to the top of the metal bed stringers or better ;D.
At this point I haven't got it much of it bucked up and stacked - but it supposed to be 40 - 44 face cords when done..
Smaller diameter logs should make for a tighter load and more cords per load due to less air spaces between logs, thus a better return for your dollar!
Prices up here are a lot higher than most in the USA and I had to get mine trucked from close to 150 miles away. Cost varies from the quotes I had from $2200 - $2600 per double load like mine..
The logs I got had been cut the previous Summer and piled and somewhat dried in log lengths over last Winter and this past Spring and early Summer as a bonus - so the bark was loose and off or falling off and the wood already semi dried from what I can see from what I have cut and tried to burn - so a BONUS.. :)
Offline barbender
« Reply #5 on: September 28, 2018, 09:26:06 PM »
I think you'll get a better yield from larger diameter logs than small. I have nothing to back this up scientifically 😁
Offline mike_belben
  • Pulp Friction
« Reply #6 on: September 28, 2018, 11:15:39 PM »
So says doyle scale.
Revelation 3:20
Offline labradorguy
« Reply #7 on: October 01, 2018, 08:37:37 PM »
Thanks for the feedback guys!
When buying tie logs do you cull
Started by just_sawing on Sawmills and Milling
Last post May 08, 2012, 09:05:48 AM
by NWP
a truckload of black locust logs
Started by Okrafarmer on Wanted
Last post March 27, 2013, 11:08:52 PM
by Okrafarmer
Learning to Buy Pine Logs by the Truckload
Started by nunya001 on Ask The Forester
Last post December 18, 2015, 09:53:10 AM
by nunya001
Truckload a sumpthun.
Started by Jeff on Tree, Plant and Wood I.D.
Last post December 11, 2005, 08:13:49 PM
by Jeff
