Author Topic: info about allison in GM 2005 and up  (Read 253 times)
Offline woodmills1
  • the truth shall set you free
« on: October 01, 2018, 09:20:26 PM »
Learned a new thing.  My Allison duramax combo has been almost bullet proof till a few weeks ago, then trans feels lika hunt and peck and motor black smoke once in a while.  Turns out recommended fluid dexron 3 had suspended titanium particles causing mini shorts inside the electric trans.  My bail out guy got me a low budget tow and only charged 2 hours to take down the pan and take out the valve body, then drive to Allison near Boston and buy the parts and repair.  Truck is back on perfect track but the new dexron 5 is like 11 bucks a quart
Offline Southside
Re: info about allison in GM 2005 and up
« Reply #1 on: October 01, 2018, 09:28:45 PM »
Go with Transynd - it's not cheap but the stuff is simply amazing.  I have over 400K on my '06 D-max and almost every one of those miles is with her hooked to a goose neck.
Offline woodmills1
« Reply #2 on: October 01, 2018, 09:31:52 PM »
Is that a fluid brand?
Offline Southside
« Reply #3 on: October 01, 2018, 09:44:32 PM »
Allison approved synthetic fluid.
TranSynd
Offline SawyerTed
  • Summey Lumber Services, LLC
« Reply #4 on: October 01, 2018, 10:43:51 PM »
Take care of that transmission!  Don't scrimp on maintenance!  I did and it bit me HARD!
Do you know what those things cost?  I had the transfer case not disengage from 4WD.  It locked up and took out my Allision 6 speed.  It was a very expensive repair!
Woodmizer LT35HD25, Kubota MX5100, IH McCormick Farmall 140, Granberg Alaskan Chainsaw Mill, Husqvarna 372XP, Husqvarna 455 Rancher, Ram 3500 6.7 Cummins
allison automatic
Started by Nemologger on Forestry and Logging
Last post October 12, 2014, 11:25:35 PM
by barbender
allison woes
Started by woodmills1 on General Board
Last post June 10, 2010, 07:50:43 AM
by Meadows Miller
allison transmissions / timberjack 330
Started by miketclew on Forestry and Logging
Last post June 17, 2017, 05:48:12 AM
by Neilo
c5 Treefarmer Allison Power Shift
Started by overtime on Forestry and Logging
Last post August 16, 2011, 01:32:21 PM
by lumberjack48
