Author Topic: Wood master boiler repair  (Read 416 times)
Offline Rob30
« on: October 03, 2018, 12:22:54 AM »
Hello All;
I have  WOOD MASTER boiler that developed some leaks. All of the leaks are around the rectangular heat exchange tubes. The first leak is right on the edge of the tube, looks like one edge of the tube is disintegrated. I am in the process of welding the edge now. However I am debating on welding a piece of stainless angle iron along the edge.
The other leaks are right at the top corner of the heat exchange tube, there they meet the tank wall. It is very hard to weld, even harder to clean before welding.
Has anyone cut these tubes right out? I am thinking the easiest solution is to cut them out and weld plates over the holes. The other option is to make news cross tubes out of some stainless exhaust pipe and weld them in.
Any suggestions?
Offline jerry sundberg
  • not new here more seasonal
Re: Wood master boiler repair
« Reply #1 on: October 03, 2018, 05:56:32 AM »
It will most likely be a constant problem with welds due to corrosion and constant expansion and contraction. Using two dissimilar metals can cause problems too.
Farmall  man
Offline E Yoder
  • Heating with a HeatMaster GS100
« Reply #2 on: October 03, 2018, 06:21:49 AM »
You could cut the cross tubes completely out and weld a plate across.
Sometimes you have to cut a hole in the top and come in from the water jacket side to weld the ends of the tubes.
But as was mentioned you'll likely be chasing holes again.
HeatMaster dealer support in VA.
GS100.
wood master outdoor boiler question
Started by simonmeridew on Firewood and Wood Heating
Last post January 11, 2011, 11:01:44 PM
by PC-Urban-Sawyer
moved
MOVED: wood master outdoor boiler question
Started by chet on General Board
Last post December 15, 2010, 12:43:41 AM
by chet
Heat master repair
Started by Rob30 on Firewood and Wood Heating
Last post December 22, 2017, 08:59:21 AM
by E Yoder
Pasific Western Boiler Repair
Last post August 03, 2017, 07:05:51 AM
by E Yoder
