Author Topic: 3 way zone valve  (Read 539 times)
Offline xlogger
3 way zone valve
« on: October 04, 2018, 08:56:01 AM »
I have my hot tub connected to my CB. We started it back up last week after being off all summer. Having problems with keeping temp correct. I can open manual lever on valve and get it hot too hot if left open. Not sure if its the head or spring in the valve. Sometimes it hot with head connected and will not cool down unplugged and then next time will not get hot all hook up. I'm thinking just ordering the complete valve and taking the four screws off top of valve and replace spring assembly and head also. Any ideas before I do this?
Offline LittleJohn
  • I am not a professional, I just pretend I am...
Re: 3 way zone valve
« Reply #1 on: October 04, 2018, 12:24:37 PM »
Remember, you need a pump between the mixing valve and the application/appliance.
Is it a powered mixing valve, or a thermostatic (Mechanical) mixing valve.  just trying to get an idea of how  the system is plumbed and what may be going wrong
Offline xlogger
« Reply #2 on: October 04, 2018, 05:49:13 PM »
A thermostatic controls opening and closing the flow of water thru the valve coming from the OWB
Offline E Yoder
  • Heating with a HeatMaster GS100
« Reply #3 on: October 05, 2018, 05:06:21 AM »
I've found those 3 way zone valves are bad about seizing up. Grit or mineral buildup? I dunno.
HeatMaster dealer support in VA.
GS100.
Offline xlogger
« Reply #4 on: October 05, 2018, 06:04:45 AM »
Where do you find the best price on parts to rebuilt? Or maybe I should just order a new valve and strip the parts out of it and replace into my brass one. I'm trying not to cut out my valve out of line and sweat a new one in.
Offline mike_belben
  • Pulp Friction
« Reply #5 on: October 05, 2018, 08:25:53 AM »
STC valve has been good to me, cheap.
Revelation 3:20
Offline hedgerow
« Reply #6 on: October 05, 2018, 10:02:11 AM »
You may not be able to do this if the body of the valve is bad. Usually with valves I just bit the bullet and sweat in a new completed valve. I am assuming it is a mechanical valve.
Offline boilerman101
« Reply #7 on: October 05, 2018, 11:44:59 PM »
Not much to go wrong with the soldered in brass base body. The Central Boiler parts book shows a Taco 3 way zone valve repair kit. Looks like all the lower guts of the valve - Valve body, spring, plate and screws. Suggested retail $62.00 I would think you should be able to purchase from your local CB dealer or online. Might be your easiest fix and not have to resolder. They also have replacement valve heads, but probably cheaper to buy a new valve complete than buy both the guts and a new head.
Offline xlogger
« Reply #8 on: October 06, 2018, 07:00:58 AM »
That's what I was thinking about buying the total valve and then I would have to head for a spare later if needed. I have two of this valves one in hot tub and other in my wood kiln both supply by my OWB. But before I buy the valve I need to make sure its not my thermostat.
taco zone valve problem
Started by xlogger on Firewood and Wood Heating
Last post November 14, 2015, 07:12:04 AM
by AsaG
How to convert from Taco zone valves to zone pumps?
Started by Zach Hoyt on Firewood and Wood Heating
Last post September 13, 2012, 10:05:48 PM
by Zach Hoyt
The Twilight Zone
Started by iain on General Board
Last post February 07, 2006, 05:48:27 PM
by iain
Plant out of zone with windbreak?
Started by Mongo on Forestry and Logging
Last post September 01, 2004, 03:21:06 PM
by Ron Wenrich
