Author Topic: purchase of John Deere 440B and need advice on everything  (Read 863 times)
Offline Frozendozer
  • Frustrated wood cutter
« on: October 05, 2018, 01:53:07 AM »
I just got a jd440B  delivered last Monday drive it 20.minutes and then shut it down.  I had to go to work and won't be at it for a couple weeks.  It has a power shift  and seems like a nice machine.
it did not come with any manuals so I am at the bottom of the learning curve and need some advice on many things before I fire it up and get to work.  Checking the engine oil is straight forward, but what about everything else such as the transmission differentials and winch?  what type of fluid does the transmission use?  what about the winch?
when I put it in gear and let out the clutch nothing happens until I pull s lever on my left side, then you can tell it engage.  is this normal operation?  should I.keep the clutch in then pull the lever?  The winch also operates when I pull the lever.
how does the winch control work? is the lever all the way forward to lock the winch, how about free spoiling?
I what type of anti freeze should I use?
I used to have a c5 tree farmer, but everything was manual and pretty much bozo proof, but with this power shift, it's got me worried that this bozo is going to break something before it earns enough to repair it.
Offline Satamax
Re: purchase of John Deere 440B and need advice on everything
« Reply #1 on: October 05, 2018, 02:55:24 AM »
Frozendozer, i'm sure there was a similar thread about the transmission few months back. I've had a quick look. But can't find it.
Check http://forestryforum.com/board/index.php?action=search2
French CD4 sawmill. Latil TL 73. Self moving hydraulic crane. Iveco daily 4x4 lwb.
Offline Frozendozer
« Reply #2 on: October 05, 2018, 03:40:13 PM »
I tired the link you sent  BUT it just looped back go the forum page
Offline Satamax
« Reply #3 on: October 05, 2018, 03:46:42 PM »
Yep, it sends you to the search page.  I can't seem to link to the actual search. But put 440 in the earch field. And check two or three pages of links, you should find a fair bit of info.
Offline dnash
« Reply #4 on: October 05, 2018, 06:45:07 PM »
I wouldnt recommend running the engine with the engine clutch disengaged unless you also destroke the hydraulic pump.
JD 440C
JD 640D
Timberjack 205HR
JD CT322 skidsteer
Offline Frozendozer
« Reply #5 on: October 07, 2018, 10:02:00 PM »
I am not certain what that means.   I should pull the lever on the left as soon as u get the beast running?
Offline dnash
« Reply #6 on: October 08, 2018, 07:15:15 AM »
The only time you should need to pull the lever (engine clutch disconnect) is when starting in real cold weather; it is easier on the starter. Once the engine is running well, push the lever back forward. There is a charge pump in the transmission that feeds oil to the main pump on the front of the engine. If you keep the engine clutch disengaged for too long, there will be no oil fed to the main pump and eventually it will burn out.
JD 440C
JD 640D
Timberjack 205HR
JD CT322 skidsteer
Offline Dan W
« Reply #7 on: October 08, 2018, 11:13:39 AM »
I owned a 440 A for 30 years with the power shift tranny.  I agree with dnashs advice.  Use clutch lever only for starting.  Use foot pedal only in emergency.  There is a hydraulic oil filler and level stick in front of the seat. It is the only reservoir and also feeds the front differential. The rear diff is not included.  The winch has its own hydraulic reservoir.  Dont let the oil get milky, change the filter often to prevent freezing and breaking the cover.  Just a few small things I learned!
Offline Frozendozer
« Reply #8 on: October 08, 2018, 01:30:09 PM »
Thanks Dan W and dnash I could use all the help and advice I can get.  talking with a heavy duty mechanic, who only worked on cat products, that the power shift transmission would use hydraulic oil. Is this true also for the diff's? Does the engine use a specific type of anti freeze?   It sure would be nice to keep this beast operational long enough to earn it's next repair cost first.
Offline jd540b
« Reply #9 on: October 08, 2018, 08:01:19 PM »
Antifreeze isnt as critical as is John deere coolant additive.  It keeps bubbles from forming in the coolant.  When those bubbles hit the sleeves, they pop and chew away at them.  It will look like someone shot them will bird shot.  Eventually it will work through and the sleeves will start leaking coolant.
Offline Maine logger88
  • Don't force it get a bigger hammer
« Reply #10 on: October 08, 2018, 08:35:14 PM »
 303 hydraulic oil for the diffs and trans
John Deere 440b
Started by pabarhunter on Forestry and Logging
Last post December 25, 2014, 12:41:12 AM
by pabarhunter
john deere 440b
Started by pigpen on Forestry and Logging
Last post October 01, 2012, 08:38:33 PM
by Kodiakmac
john deere 440B winch control
Started by 350 cummins on Forestry and Logging
Last post February 03, 2017, 09:48:54 PM
by 350 cummins
John Deere 440B fair skidder price
Started by nhkierst on Forestry and Logging
Last post April 09, 2013, 01:30:02 PM
by clww
