Author Topic: Handy little machine  (Read 1354 times)
Offline alanh
« on: October 06, 2018, 08:49:29 AM »
Brought this home from the day job to use around the mill and OMG, what a joy...I just have forks and a bucket but sooo much easier than my Kubota fel... does a 180 in the length of itself, can move pallets in and out of the tightest spots and can lift suprisingly big logs,,
Offline newoodguy78
Re: Handy little machine
« Reply #1 on: October 06, 2018, 09:26:45 AM »
Nice!! Pretty tough to beat a skidsteer in tight places
Online thecfarm
« Reply #2 on: October 06, 2018, 01:32:40 PM »
Are they hiring? :D
Offline Bruno of NH
« Reply #3 on: October 06, 2018, 01:44:00 PM »
Looks like it can lift a good amount
thomas 8013 mill ,Mahindra 3540 cab tractor loader  Dump trailer  and lot of contracting tools
Offline D6c
« Reply #4 on: October 06, 2018, 08:22:00 PM »
Just be very careful not to raise too high and tilt too far back.... don't want to roll a log back on yourself.
Offline terrifictimbersllc
    • Terrific Timbers LLC
« Reply #5 on: October 06, 2018, 08:29:41 PM »
If that thing can load itself in the back of my F350 maybe I'll get one.
DJ Hoover, Terrific Timbers LLC,  Mystic CT  2001 WM LT40SHDD (42HP Kubota, Accuset2, FAO's, Lubemizer, debarker), Peterson WPF 10-30 with chain slabber. Logrite fetching arch, WM BMS250 sharpener/BMT250 setter.  2001 F350 7.3L PSD 6 spd manual ZF 4x4 Crew Cab Long Bed
Online mike_belben
  • Pulp Friction
« Reply #6 on: October 06, 2018, 10:48:41 PM »
Id bet itd back up a set of heavy ramps into a pickup.
I checked over a bobcat brand mini skidsteer for a buddy that he did end up buying, $10k used.  Hes a mason and it lifts some impressive boulders, goes through a backyard gate easy, no climbing over the bucket.
Theyre pretty robust yet fairly simple.  It reminded me a lesco zero turn that someone put a loader and tracks on.  Same components really.
Revelation 3:20
Offline chep
« Reply #7 on: October 06, 2018, 10:58:43 PM »
I have a boxer 320. Similar idea. Amazing buggy around the mill. Weighs 2000 lbs. And it's on the small end of mini skids. Yes you can def load it in the back of a truck. Good ramps secured to the truck are a must. And take the tail gate off...
Offline DbltreeBelgians
« Reply #8 on: October 07, 2018, 12:38:50 PM »
I saw several different makes of them Friday at the Paul Bunyan Show in Cambridge. One had a grapple with a hydraulic chainsaw. The operator cut a cookie off one end close to the grapple while the other 8 was hanging out the other side of the grapple. That set up could be handy at times.
Brent
Offline alanh
« Reply #9 on: October 11, 2018, 04:25:14 PM »
It surely could get into a pickup, like mentioned above take off the tailgate, this one weighs a little over 3k, the work setup it goes in a 7ft x 14 ft 7k dump trailer with 4 tons of sand towed behind a 12k diesel service truck, keeps it under cdl (cuz you can`t hire a guy with a cdl these days!) It does a 180 in the trailer, goes thru gates, under tree branches, pretty much took the words "shovel" abd "wheelbarrow" out of the vocabulary, digs impressively also... have I mentioned I really like this thing?
Handy machine around the mill
Started by lyle niemi on Sawmills and Milling
Last post November 03, 2013, 06:13:36 PM
by Chuck White
wow log tongs sure are handy
Started by markct on Urban and Community Forestry
Last post September 15, 2008, 09:20:18 PM
by markct
handy helpers
Started by rdbrumfield on Forestry and Logging
Last post February 14, 2009, 02:24:32 PM
by Tom
Handy tow cable
Started by WV Sawmiller on General Board
Last post February 04, 2017, 07:47:02 AM
by LeeB
