AVAILABLE
Author Topic: New EZ Boardwalk Jr not cutting straight  (Read 3008 times)
Offline Darren
« on: October 07, 2018, 07:35:06 AM »
Hey guys, new here Ive followed the forum for a while looking for sawmills and finally made the decision on the EZ Boardwalk Jr that I received Friday. The mill is very well constructed and the Honda motor sure is nice and quiet. I didnt mess with changing anything from how they have it setup only thing ive done is put a blade on it and tensioned it. It says to adjust the leading nut to the indicator which ive done. At first my boards had a dive to them and they had a 1/4 inch slope on one side. After a few adjustments to how I have the mill set, now I just have the dive in the boards. Any ideas as to what I should be doing here. I'm new to sawmilling altogether so I have plenty to learn. Ive enjoyed the firewood that ive milled so far but would really like to make some real boards lol.
Offline Bruno of NH
Re: New EZ Boardwalk Jr not cutting straight
« Reply #1 on: October 07, 2018, 08:07:44 AM »
Sounds like a blade tensioning issue
To me
Adding more tension might help
thomas 8013 mill ,Mahindra 3540 cab tractor loader  Dump trailer  and lot of contracting tools
Offline Darren
« Reply #2 on: October 07, 2018, 08:13:35 AM »
Will give it a try, thanks for the fast reply.
Offline Bruno of NH
« Reply #3 on: October 07, 2018, 08:48:10 AM »
I run more than what the manufacturer of my mill reconmends.
It cuts better
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #4 on: October 07, 2018, 09:17:37 AM »
Don't overlook the drive belt.   If it slips slowing down the blade speed, bad things happen.  Proper engine speed is also critical.
Offline Crossroads
  • letís make some sawdust
    • Kevin Bales faith family farm and portable sawmill
« Reply #5 on: October 07, 2018, 10:13:47 AM »
Welcome to the designer firewood club...
2017 LT40 wide, Kubota l185dt, 2-036 stihl, 2001 Dodge 3500 5.9 Cummins
Offline Downstream
« Reply #6 on: October 07, 2018, 10:36:46 AM »
I run mine a little tighter than flush to the tension nuts also, but not too far past and have not seen issues.  Only problems I see with wavy cut at all are associated with dull blades.  I run at full throttle and adjust feed speed to keep rpm's as constant as I can.  I would increase tension first and watch feed speed.
EZ Boardwalk Jr,  Granberg Alaskan Chainsaw Mill, Stihl 660 and 211, Logrite 60" cant hook, Dixie 32 Tongs
Offline Darren
« Reply #7 on: October 07, 2018, 10:55:21 AM »
Do you do anything with the black nuts or do you just tension with T handle?
Offline Darren
« Reply #8 on: October 07, 2018, 10:56:23 AM »
I just put a different blade on it and tensioned a little past flush so we will see
Offline Downstream
« Reply #9 on: October 07, 2018, 12:03:32 PM »
I have only tension using the t-handle.  Im using the 10 degree timberwolfs blades that I ordered with the mill.
Offline Darren
« Reply #10 on: October 07, 2018, 12:10:04 PM »
Made another bad cant and a terrible board. After further inspection it looks like maybe I clamp it to tight and my be is off level for sure. The cant doesnt touch in the 2 center beams but makes contact on the beginning and end beam. As far as the clamping goes I noticed that when I released them from my cant that it drops the cant flush on the end beam. I guess I'm just rushing myself to much and not paying attention to all the little things
Offline Darren
« Reply #11 on: October 07, 2018, 12:10:36 PM »
Ok thank you, thats what I'm doing and using as well.
Offline Downstream
« Reply #12 on: October 07, 2018, 12:31:37 PM »
Your clamp comment also is spot on.  I have found that with the ez clamps there is a sweet spot where they are just tight enough to hold but not distort the cant/log.  when I really clamped them tight I usually was putting too much pressure and the wood sprung back to normal position after unclamping.
Offline Darren
« Reply #13 on: October 07, 2018, 12:36:33 PM »
Thanks for all the help, looks like more leveling needs to be done and I need to use less clamp before I go any farther
Offline Skipper11A
« Reply #14 on: October 07, 2018, 08:37:52 PM »
Don't be afraid to over tension your EZ Boardwalk, especially if you are making wide cuts in extremely hard wood.  I add one extra rotation of the T handle when I'm milling Post Oak and Pecan and the blade still dives when it hits the big knots.
I'd like to know what type of wood you are milling and whether it was a standing dead tree or was still alive.  Some woods are much harder to saw than others and dead trees are harder than living trees.
Offline Darren
« Reply #15 on: October 07, 2018, 08:44:43 PM »
I tried mostly ash, which most of that around here is dead, black cherry and poplar. All had the same results, but my track is definitely the biggest issue its not level enough. Will work on that next weekend, I'll have to get some beams or something to put under it
Offline barbender
« Reply #16 on: October 07, 2018, 10:54:04 PM »
Ash that was standing dead can be a bit of a bear to saw anyhow.
Offline Darren
« Reply #17 on: October 08, 2018, 04:30:45 AM »
Would probably help to open the actual ball valve for the water as well. All the little things I failed to notice😔. To much excitement I suppose, waited weeks so was really itching to try it out
Offline Bruno of NH
« Reply #18 on: October 08, 2018, 07:22:55 AM »
Ash can be hard to saw sometimes
Offline Darren
« Reply #19 on: October 08, 2018, 10:50:03 AM »
I have heard that but the poplar and black cherry I did came out the exact same. Its definitely on me, will have to get it figured out I'm new to this, just impatient as well lol.
Swingarm mill not cutting straight???
Started by BarryD on Sawmills and Milling
Last post November 08, 2005, 12:34:45 AM
by NZJake
Cutting big ugly spruce straight.
Started by ladylake on Sawmills and Milling
Last post October 15, 2013, 01:08:24 AM
by barbender
bigger logs, not cutting straight
Started by lyle niemi on Sawmills and Milling
Last post March 13, 2012, 08:24:03 AM
by bandmiller2
Alaskan Mill: 066: Saw not cutting straight?
Started by bandyfro on Chainsaws
Last post August 04, 2018, 07:52:47 AM
by maple flats
