Author Topic: Wedding cookies - secondary ops?  (Read 900 times)
Offline Downstream
« on: October 07, 2018, 12:38:12 PM »
Did not want to hijack the what are you saying thread with this question from recent post by Resonator.  He talked about putting some cookies through the planer before giving to customer for wedding cookies to give nice smooth finish.  My assumption was always that most people sell wedding cookies as rough sawn without sanding, planing, or other secondary ops.  I did a quick search of cookie threads and don't really see any specific comments.  Do most use/sell as rough sawn?
EZ Boardwalk Jr,  Granberg Alaskan Chainsaw Mill, Stihl 660 and 211, Logrite 60" cant hook, Dixie 32 Tongs
Offline kelLOGg
Re: Wedding cookies - secondary ops?
« Reply #1 on: October 07, 2018, 01:49:13 PM »
You surely can't plane end grain and sanding it green is a slow-go proposition. Leave it rough. A well set band can saw it pretty Dang smooth.
Bob
Cook's MP-32, 16HP, 20' (modified w/ power feed, up/down, loader/turner)
DH kiln, CatClaw, setter, tandem trailer, log arches, tractor, thumb tacks
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #2 on: October 07, 2018, 02:40:34 PM »
I would be terrified to put cookies in my planer but it is just a lunch-box unit.
I loan my stash of Walnut cookies for parties, etc.  Some are still rough sawn and some are sanded and oiled.  They were sawn from a very dead/dry limb so there is no white sapwood.
Offline Resonator
  • Board Footage and Cord Woodage
« Reply #3 on: October 07, 2018, 03:39:33 PM »
Maybe I was just lucky my cookies didn't explode, the planer did growl at me when I ran them through!  I was however only taking LIGHT passes, (1/64" - 1/32") at a time. Most of what I've seen on here they are just rough sawn. I was just trying to get rid of purple sawdust spots by planing. (I didn't think the cookies looked good enough to serve to my customer.)
Offline Downstream
« Reply #4 on: October 07, 2018, 07:03:46 PM »
Thanks for the comments.  I have ros sanded some I use for coasters but only after they have dried.  I agree with resonator that exceeding customer expectations is the way to go.  I would probably sand a few select cookies that are being used for main cake or show piece, but not on bulk place-setting pieces.  When customer asks for quote I tell them price is for rough sawn pcs only and tell them they will probably crack long term so I usually saw them week of the wedding if possible.
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #5 on: October 07, 2018, 07:29:05 PM »
With my spiral head planer with 96 carbide inserts, I can plane green cookies no problem.  If they are not green , there is too much damage on the back edge of the cookie.  Tears it out.  With a knife planer, it would not be feasible.
Offline opticsguy
« Reply #6 on: October 10, 2018, 02:03:23 AM »
Sanding end grain - belt sander is the only way.  ROS would take way too long, at least in my experience.
Another option if you really want flat and parallel surfaces is with a drum sander.
TK 1220 band mill,  1952 Ford F-2, 1925 Dodge touring, too many telescopes.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #7 on: October 10, 2018, 08:16:55 AM »
Just know that if you add a finish most likely the cookie will turn much darker.
Offline Resonator
« Reply #8 on: October 10, 2018, 08:26:07 AM »
If I wanted to sand smooth a large batch of cookies to rent out for weddings, I would look at using an abrasive planer. A couple places I worked at years ago used a large industrial machine that could sand up to 36" wide, maybe find a cabinet shop that would let you use there's for an hour.
Offline tule peak timber
  • roborob
    • tule peak timber
« Reply #9 on: October 10, 2018, 09:21:38 AM »
We use a wide belt sander on 80 grit initially to smooth , then a big random orbit to fine sand. Cookie table sets, cookie tables, cookie doors, cookie walls, cookie counters, cookie furniture , cheese boards, book covers, and on and on..... It takes two men a long time to fine sand cookies and this time is by far the most expensive part of the process with vast amounts of epoxy the next biggest expense. Rob
Sawing wedding cookies
Started by CX3 on Sawmills and Milling
Last post September 09, 2018, 12:53:49 PM
by POSTON WIDEHEAD
Secondary elbow blocked again....why?
Started by DeerMeadowFarm on Firewood and Wood Heating
Last post March 03, 2014, 11:35:28 AM
by Logging logginglogging
Nice walnut tree with secondary trunk
Started by IL80 on Ask The Forester
Last post November 25, 2014, 08:52:57 AM
by Magicman
Secondary heat loop for CB6048 question
Started by DR_Buck on Firewood and Wood Heating
Last post November 27, 2009, 12:07:42 AM
by DouginUtah
