Author Topic: First picture  (Read 855 times)
Offline Lko67
  • Think positive every day
First picture
« on: October 08, 2018, 09:52:14 AM »
Dead pine
Offline Lko67
Re: First picture
« Reply #1 on: October 08, 2018, 09:53:25 AM »
It worked lol :D
Offline 47sawdust
Re: First picture
« Reply #2 on: October 08, 2018, 12:13:11 PM »
Congratulations,the hard part is done. ;D
Mick
Offline crowhill
Re: First picture
« Reply #3 on: October 08, 2018, 12:28:33 PM »
Pretty darn nice!
TimberKing B-20, Kubota M-4900 w/FEL with tooth bar, hyd thumb and forks, Farmi winch, 4 chain saws.
Offline petefrom bearswamp
  • made 70-11 and still feelin pretty darned good!
Re: First picture
« Reply #4 on: October 08, 2018, 12:52:04 PM »
Way to go.
Nice log too
LT40SHDD51
Kubota 900 RTV
Polaris 550 Sportsman ATV
1 Husky 1 gas Echo 1 cordless Echo
241 acres of woodland
Offline Revival Sawmill
  • making sawdust.
Re: First picture
« Reply #5 on: October 08, 2018, 05:10:59 PM »
Looks good! 😅.
So you are of the ‘hump-first’ school as opposed to the ‘horns-first’?
Online Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: First picture
« Reply #6 on: October 08, 2018, 05:46:55 PM »
I am neither hump nor horn first.  :)
Offline Sixacresand
  • John and Nancy
Re: First picture
« Reply #7 on: October 08, 2018, 07:38:19 PM »
There are some that love the live edge oval slabs that come off the hump of a crooked log.  I kinda like them myself.
Offline Lko67
Re: First picture
« Reply #8 on: October 08, 2018, 07:41:32 PM »
Was making framing lumber and had grub holes pretty deep. I'm still learning will be sawing my first hard wood tomorrow
Online Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: First picture
« Reply #9 on: October 08, 2018, 09:02:50 PM »
With framing lumber your final saw through needs to be from either the hump or horn face.  That way your lumber will tend to bow rather than crook.
Offline Gagnon Mountain
Re: First picture
« Reply #10 on: October 09, 2018, 08:41:58 AM »
Lk067, nice mill!  I just set mine up this past weekend.
When building it, I found that the directions called for using the supplied 6 and a half inch bolts to mount the axle and forward frame stiffeners.  They were way too long.  I wound up going to Lowes and buying 4 and a half bolts.  Did you have this issue as well?
Tony
Offline Lko67
Re: First picture
« Reply #11 on: October 09, 2018, 03:37:19 PM »
Thanks for the advice mm . Gagnon my bolts are 6 inch with only 1/8 to 1/4 threads past nut when tight bought mine already assembled
Offline OffGrid973
  • Off Grid
Re: First picture
« Reply #12 on: October 09, 2018, 04:19:54 PM »
This is not another crook thread I hope. Congrats on the first pic, now “Center That Pith” and get after it :)
Your Fellow Woodworker,
- Off Grid
Offline Carpenter
    • Niobrara Timber and Woodworks
Re: First picture
« Reply #13 on: October 09, 2018, 09:16:36 PM »
I like to saw the hump off first.  It gives me a little leeway.  I'm mostly sawing boxed heart timbers and get a little side lumber during the process.  Once I saw the hump off I can really see where I stand, and where the log stands, I can see if it is even possible to make a boxed heart timber out of the log at that point.  I look at the hump as a crown, I know it will crown that way eventually during the drying process.  So, if I am making 6x8s for example, I will make the 8" cut with the hump up, then cut the sides down to 6.
     I know this really isn't a hump up, horns up thread, but this seems to have come up.  I don't know if I'm doing it right by the way, it's just the way that I've been doing it and approaching the situation.
Online Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: First picture
« Reply #14 on: October 09, 2018, 09:27:16 PM »
I was addressing only one instance.  Your cut list will always determine your opening face and sawing pattern.
Started by Wade on Sawmills and Milling
Last post May 07, 2003, 09:26:30 PM
by biziedizie
picture of the day.
Started by lynde37avery on Forestry and Logging
Last post February 09, 2014, 08:13:15 PM
by POC
A Picture For You
Started by submarinesailor on General Board
Last post January 27, 2012, 02:47:53 PM
by thecfarm
Started by tosmall on Chainsaws
Last post August 08, 2015, 05:08:23 AM
by LeeB
