Author Topic: Debarker  (Read 1473 times)
Online moosehunter
  • Every once in a while
    • Saw it Coming
Re: Debarker
« Reply #20 on: October 08, 2018, 08:23:37 PM »
The first used LT40 super I went to look at had the beeper wires cut. I asked why and the owner said he didn't like the noise. Then he showed me a nasty scar on the back of his left arm and admitted that cutting the wires to the debarker beeper was a very bad idea. Your dog will get used to it.
mh
If it is true that we learn from our mistakes, I must be Brilliant!
Online GAB
Re: Debarker
« Reply #21 on: October 08, 2018, 08:34:29 PM »
Bruno:
You said something about having "Orange Envy", but I never, never imagined it was that serious.
Gerald
Offline beav
  • got any logs?
Re: Debarker
« Reply #22 on: October 08, 2018, 09:11:11 PM »
I always wanted a debarker, over the years my customers learned to keep their logs clean. Debarker never happened.
I  quickly learned to figure the next cut before finishing the last one. Don't have..
I lost no time trading in my first manual lt40 for the hydraulic version as soon as it came out.
Just my 2 cents
Offline Revival Sawmill
  • making sawdust.
Re: Debarker
« Reply #23 on: October 08, 2018, 10:53:19 PM »
Yes! Although the debarker really takes some getting used to...
The debarker is literally one button.  You could pick your nose as easily as using the WM debarker  :D
One more thing to keep up with... is it making contact? Is it spinning? Did it snag on something? Did you get the head high enough for the blade to clear the cant but not the debarker on your way back to the front of the mill, and it torqued the alignment??? Not all of us were born with an innate ability to pick our noses either! 😋
Offline Dave Shepard
  • Geometrically proportional
    • My homepage
Re: Debarker
« Reply #24 on: October 08, 2018, 11:58:10 PM »
One of my debarker alarm wires got ripped off, possibly by an offbearer, and I caught the running blade under my left arm. Shredded my shirt and left a heck of a nasty cut on my rib cage, and that was just a glancing blow.
Online Peter Drouin
    • A&P Saw mill LLC
Re: Debarker
« Reply #25 on: October 09, 2018, 06:29:36 AM »
Why would one put there hand in front of a running blade?????????????
I cut mine 2 min after I got the mill. It only runs when you have the mill cutting wood. Why would one want to walk around while cutting to move something?
I stop the mill to move or cut something in the way.
A&P saw Mill LLC.
License NH softwood grader.
Online Chuck White
  • Sawing Mobile since 2005
Re: Debarker
« Reply #26 on: October 09, 2018, 07:07:30 AM »
I think that Wood-Mizer has been installing a flashing light instead of a beeper on the debarkers!  My friends LT35HD has a flashing light!
On my mill, I cut the red wire and installed a micro toggle switch there, when I have anyone new around the mill I, unknown to the offbearer turn the switch ON!  Once anyone has had a few days working the mill, I turn the switch OFF if they complain!  Very few people know the switch is there!
~Chuck~
    • My homepage
Re: Debarker
« Reply #27 on: October 09, 2018, 09:28:32 AM »
In my case my wireless remote needed a new speed pot, so I was running the mill from the console. When sawing with the wireless, there is a big red e stop button that kills everything but the engine. I would normally hit that button anytime I went near the mill. I was sawing 47' logs, so I had little room to work, and I had to trim the butt of the log. The debarker runs whenever the feed lever is in forward, so the blade was not running when this happened. You cannot hear the debarker running, or see the blade spinning easily in bright sunlight. The wire was fixed immediately.
Offline John S
Re: Debarker
« Reply #28 on: October 09, 2018, 09:54:23 AM »
Yes, the new debarkers use a flasher instead of the beeper.  I only had one client who objected to the beeper.  I guess WM engineers decided that the flashing light was more effective.
Simple Set with the sliding scale was very effective.  My new WideHead with Accuset2 is getting more impressive each time I use it.  It has taken me a while to adjust to it, but it has proven to be very accurate and a great time saver.
2018 LT40HDG38 Wide
Offline Percy
  • Resident trouble maker
Re: Debarker
« Reply #29 on: October 09, 2018, 09:59:19 AM »
I do too But in this case as with Dave, I used the rehostat to stop the head movement.
Offline Skipper11A
Re: Debarker
« Reply #30 on: October 09, 2018, 01:59:01 PM »
Bruno, what's wrong with your Thomas mill?  Doesn't that handle 36" wide trees?  I just called WoodMizer and they told me the LX150 uses 1 inch blades which means you'd probably have trouble getting flat cuts in wide slabs.  I wouldn't want to run a slabbing business with 1 blades, or tracks that bolt together.
If you need to upgrade, why not the Thomas 4420?  That monster is 44" wide, uses 2" wide blades and is only $11,500 with their No-Flex track.  If I'm reading their website correctly, it has a 44" wide cut!  And they are right next door to you.
Offline terrifictimbersllc
    • Terrific Timbers LLC
Re: Debarker
« Reply #31 on: October 09, 2018, 03:07:32 PM »
Haven't got bit yet.  My debarker horn stopped working I should probably inquire about the flashing light.  I almost always eye that debarker blade with suspicion when walking around to check the lubemizer flow or for something else.  :-\ :-\ :-\
DJ Hoover, Terrific Timbers LLC,  Mystic CT  2001 WM LT40SHDD (42HP Kubota, Accuset2, FAO's, Lubemizer, debarker), Peterson WPF 10-30 with chain slabber. Logrite fetching arch, WM BMS250 sharpener/BMT250 setter.  2001 F350 7.3L PSD 6 spd manual ZF 4x4 Crew Cab Long Bed
Offline Bruno of NH
Re: Debarker
« Reply #32 on: October 09, 2018, 03:40:51 PM »
Skipper11a
The Thomas is a great mill
It will handle 36" logs but only cuts around 30"
The lx150 cuts 35.5"
The power up/down on the Thomas has no set works
I would like set works and a debarker.
And power feed and return
I like the noflex track
I don't think Woodmizer would put out a track that would bend
The lt 15 wide has been out a while
The lx150 bunks are set up to load with forks.
Anyone had any issues with the bolt together woodmizer tracks ?
I think my lumber would be more accurate with the Woodmizer.
I cut 75% of my slabs now with 1"1/4 bands
Ripper 37 in a 7
thomas 8013 mill ,Mahindra 3540 cab tractor loader  Dump trailer  and lot of contracting tools
Offline Lawg Dawg
  • True South Sawmill Lumber
Re: Debarker
« Reply #33 on: October 09, 2018, 04:08:00 PM »
I seen all that orange at the sawing project
I can't get it out of my head😁
I feel your pain! You will be on the orange side soon! I can see it in my crystal ball!  thumbs-up
2018  LT 40 Wide 999cc
John Deere 5020, John Deere 4000, 2016 F150, Husky 268, 394xp, Shindiawa 591, 2 Railroad jacks, and a comealong. Woodmaster Planer, and a Skilsaw, bunch of Phillips head screwdrivers, and a pair of pliers!
100,000 bf club member
Pro Sawyer Network
Offline Skipper11A
Re: Debarker
« Reply #34 on: October 09, 2018, 06:58:20 PM »
Bruno, If the 1 bands work in slabbing your wood, then stick with them.  I brought it up because they're not the best for slabbing the extremely hard woods that I have here, many of which are standing dead.
It sounds like the LX150 is the perfect saw for you, especially with your knee problems. And it would satisfy that Orange bug that bit you last week!
Offline k and g
Re: Debarker
« Reply #35 on: October 11, 2018, 09:39:16 PM »
Can the simple set be applied to an older model mill?  How much does it cost?
Offline YellowHammer
  • Take Steps to Save Steps
    • Hobby Hardwood Alabama
Re: Debarker
« Reply #36 on: October 11, 2018, 11:27:22 PM »
Is it worth the extra money for simple set and the debarker?
Yes on the debarker, and add a few more to get Accuset.
HobbyHardwoodAlabama.com
Offline 47sawdust
Re: Debarker
« Reply #37 on: October 12, 2018, 05:56:29 AM »
My mill is a 1997 LT30.That is as an old a mill the SS can be installed on.I just finished the install on my mill.I had to install a new up/down motor as well.It was a tight fit.The new SS came wired backwards so up/down was reversed,but a call to Indy solved the problem.
My math skills are pretty good but with the SS I can give that part of my brain a little rest and perhaps use it for something else ....memory loss,maybe.
Mick
Log Debarker
Started by simplicityguy92 on Drying and Processing
Last post December 11, 2011, 12:58:58 AM
by simplicityguy92
debarker
Started by steve phillips on Sawmills and Milling
Last post November 28, 2015, 02:08:30 PM
by Chuck White
LT 15 debarker
Started by Slab Slicer on Sawmills and Milling
Last post January 02, 2013, 08:51:32 PM
by Magicman
Po boy debarker
Started by bandmiller2 on Sawmills and Milling
Last post November 11, 2011, 11:50:38 PM
by Grower
