Author Topic: Woodmizer LT35 vs Timber King 1600  (Read 1927 times)
Offline Poplarpete
« on: October 09, 2018, 06:37:21 PM »
I've narrowed it down to these 2. I've seen the WM up close and personal, TK only by video. WM is a little less $. 1 specific concern is the single rail cantilever with the WM. Does it bounce? Any other thoughts about the mills greatly appreciated. BTW, I this will be my 1st sawmill.
Offline Busysawyer
Re: Woodmizer LT35 vs Timber King 1600
« Reply #1 on: October 09, 2018, 06:57:42 PM »
My super 70 bounces but not in the cut. It cuts very accurately.  The cantilever head allows you to cut much bigger than the same size twin rail mill will.
Even a blind squirrel finds a nut every once in awhile
Offline WV Sawmiller
    • Green's Sawmill Services
« Reply #2 on: October 09, 2018, 07:05:02 PM »
    If you have that as a worry i suggest you watch the LT35 in action some more to set your mind at ease. TK makes a very good machine and my only beef with them is they spend too much time downplaying the cantilever design. I love my LT35 and have nothing but good things to say about it. I wish it had a wider cut and more horsepower but for the price I paid I am well satisfied. I like the extra options as to off bearing from more places (Either end, either side). Also it has held its value well and I always have the option of upgrading. My machine already far exceeds my material handling capabilities which need to be examined in conjunction with your mills capabilities IMHO. Good luck and I am sure you will be happy whichever way you go.
   BTW - I have never had a bounce problem IRT your specific question.
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #3 on: October 09, 2018, 08:07:39 PM »
The Woodmizer cantilever design is decades proven.  Decades.
Offline PAmizerman
  • Just Another Day In Paradise!!
« Reply #4 on: October 09, 2018, 08:15:49 PM »
If the cantilever head was a problem WM
Wouldn't be selling thousands of mills.
I think other companies are just sore that WM pantented it and they can't use it.
Hydraulics everywhere
Traverse 6035 telehandler
WM bms250 sharpener
WM bmt250 setter
Offline Bruno of NH
« Reply #5 on: October 09, 2018, 08:24:24 PM »
I seen a 1987 lt 40 with the original owner cutting some nice pine at my benefit sawing project.
And 3 other lt 40's going hard and not one bad piece of lumber.
I'm a believer
thomas 8013 mill ,Mahindra 3540 cab tractor loader  Dump trailer  and lot of contracting tools
Offline Outlaw
« Reply #6 on: October 09, 2018, 08:55:38 PM »
If you let everyone know where you live, there might be some kind owners let you take a look at their mill.
Offline Chaser357
« Reply #7 on: October 09, 2018, 09:38:29 PM »
I have a TK1600.  The company has been great to deal with. Wood Mizer is too because I have had an orange mill too.
What I like about my mill that the WM doesn’t have (standard).
Chain log turner
Fine adjust outriggers
Very simple hydraulics and very little electronics
36” log capacity with about 32” between the guides
A little more horsepower
I can buy parts pretty much anywhere
What I don’t like about my mill that WM has.
Hydraulic toe boards
Hydraulic back stops
Hydraulic clamp (up and down)
If the TK had these three things I would say no question get the TK but it doesn’t so you will have to decide what is most important to you.  I will say both are great companies and you will be happy with either one.  I wouldn’t worry about the head design so much.   If it was a problem you would have heard about it by now.
Offline Southside logger
« Reply #8 on: October 09, 2018, 10:18:17 PM »
I have a 35 and run it hard, it is a critical component of my primary income.  There is zero issue with the single mast and no bounce at all when cutting.  In addition to lumber and beams I produce flooring, shiplap, v-match, and other finished profiles, inconsistent lumber would be a serious problem for me.  I think TK is a great company as I have some of their sister company equipment that is used in down stream processing, great customer service and great products.
Yesterday I had to profile a shipment of shiplap, and the customer wanted a skip plane finish - it was a royal pain to make it come out right because my rough sawn material was so consistent that trying to get the perfect skip look was all but impossible.
Ironically, I am right now in the process of buying a second mill and this one will be orange due to the benefits of the cantilever design and WM's powerful, yet simple to operate advanced set works.  Woodmizer does have an unfair advantage with the cantilever design, but they came up with it and made it work, Ad Victorem Spolias.
Offline Doug Wis
« Reply #9 on: October 09, 2018, 10:30:51 PM »
   I chose the 1600 over wm  basicly  because of all hyd controls , nothing electrical. Mine sits outside, and  that's tough on elect stuff. Had to add a remote throttle to make it more usable. Don't know if that is a factory option now. If not it should be. Previous to that a neighbor sawed thousands of feet for me with an lt30 I believe. very accurate sawing job.  I agree with  the   post that said the other companies spend too much time running down WM design. Either will do a good job for you
A man who says he can do everything at 65 that he did at 25 sure wasn't doing much at 25.
Offline ladylake
« Reply #10 on: October 10, 2018, 04:21:59 AM »
 There has been a lot of misinformation put out about 4 post mills also, I don't know where that came from.  Steve
Offline ladylake
« Reply #11 on: October 10, 2018, 05:51:48 AM »
 Looks to me the TK 1600 can handle a way bigger log plus its not a walk along.  These new TK mills have 16" above the blade clearance which takes away the cantilevered big log advantage.  Just turn that hump or knot up with that nice chain turner.  As mentioned more hydraulics and less electric is not going to break down near as much.  My B20 has over 14000 hours and I've spent less than $200 on the hyd head drive. Steve
Offline Poplarpete
« Reply #12 on: October 10, 2018, 06:58:44 AM »
Thanks for all the response. I found similar posts with replies but they were all old and wanted current info. Sounds as if I couldn't go wrong either way... I live in the piedmont section of NC if there's a Timberking owner near who'd be willing to let me come by and see the mill in action... Thanks again. Great website!
Offline John S
« Reply #13 on: October 10, 2018, 07:51:04 AM »
Check out "Out of the Woods" on YouTube.  LT35 without a debarker!
2018 LT40HDG38 Wide
Offline alan gage
« Reply #14 on: October 10, 2018, 11:09:05 AM »
I bought a used and neglected Timberking B16 last year. I enjoyed resurrecting it and it was great to buy parts off the shelf from the local hardware store or surplus center. If I ever bought a new mill that would be a strong selling point for me to go with Timberking.
On the other hand there have been times with a big log were I would have liked the cantilevered head to keep me from having to trim with a chainsaw so the 4 post carriage would fit.
I really like the chain turner of the Timberking but others get by fine with Woodmizer's claw.
I like not having to walk along with the carriage, especially when the wind is blowing the sawdust the wrong direction.
I wish I had hydraulic log stops. When nearly everything else is hydraulic it really seems like a slow down to have to manually adjust them, especially when squaring up a log since you need to raise them before you turn and then lower them to cut.
My carriage is manual up/down as well but I assume the newer 1600 is powered.
I wish I had woodmizer's two plane clamp. My Timberking is an early one and they probably improved the clamp over the years but that two plane clamp sure looks handy.
Good news is that you probably can't go too far wrong either way you decide.
Alan
Timberking B-16
Offline SawyerTed
  • Summey Lumber Services, LLC
« Reply #15 on: October 10, 2018, 12:32:51 PM »
Pete, you'd be welcome to come see my LT35 in operation sometime. It appears we aren't too far apart.
I shopped several brands before purchasing.  The bounce issue was one thing that was pushed by some manufacturers, but has turned out to be of no consequence.
Nearly every sales rep compared their mills to Wood-mizer.  After hearing the comparisons over and over, I went to Albemarle to see the Wood-mizers.  I put a deposit on my mill during that visit.  I don't know anything about support from Timber King but I do know support from Wood-mizer is excellent.  Parts often arrive the next day and ordering is quick and easy by phone or on the website.
Periodically I saw at a site where the customer has a Timber King.  I've looked it over very closely.  I have two observations.  One TK has a different design philosophy from Wood-mizer.  Two is the one feature the TK has I wish the Wood-mizer has is the chain turner.
Woodmizer LT35HD25, Kubota MX5100, IH McCormick Farmall 140, Granberg Alaskan Chainsaw Mill, Husqvarna 372XP, Husqvarna 455 Rancher, Ram 3500 6.7 Cummins
Offline Haleiwa
  • Clinton county, New York
« Reply #16 on: October 10, 2018, 01:05:50 PM »
I've heard of running a band with one tooth deliberately set too wide to produce a rougher surface.
Socialism is people pretending to work while the government pretends to pay them.  Mike Huckabee
« Reply #17 on: October 10, 2018, 02:14:06 PM »
   I was like Sawyerted. I had never watched a mill in operation but had written the major mill makers a few years before then lost interest. They were not pushy but WM was persistent sending me post card invites anytime there was a show near by. My situation changed and I got interested in a mill again so I diverted over to Albermarle and talked to Tyler on a trip to Charlotte to see my daughter. He showed me the features and put my mind at ease as to ease of operation and maintenance. I put down my deposit that day too and scheduled delivery for early January. I went ahead and got my business license, insurance, found the FF and read everything in this category between then and January. Tyler delivered my mill and did a demo for me and my son. It was 0 degrees when he left and had warmed up to 5 degrees and 6" of snow by the time he got here with my mill. The lube tank was a solid block of ice.
   I sawed in practice a while till I was comfortable to saw for the public. My practice lumber went into building a big pole barn to store my lumber. My experience with WM for operator questions and a couple of warranty parts was first rate. When I bought belts and other parts from WM I found their prices were very competitive and delivery was always very prompt. I have since used there semi annual service loop and found the reps to be wonderful people and very professional in their servicing. It is worth the fee just to watch and learn.
   One of the other sponsors here (I will not names) then started sending me e-mails and flyers pushing me to buy their mill until I finally told them to cease and desist and finally got them turned off.
    The only time I saw a TK in operation was on a job where the sawyer set up then delayed so long the customer. my feed supplier, asked me to come too as he needed his lumber by a set date when he had help to build. I milled a couple days then on the last day the TK operator was back. The customers helper fed both of us logs. The TK lumber looked good. There was one big 17 hemlock log there and the TK sawyer told the driver to send that one to me as my hydraulics could lift it better than his. My hydraulics had no problem handling it. I don't know if his was working normally or not.
Offline reswire
« Reply #18 on: October 10, 2018, 10:20:16 PM »
I currently own a Woodmizer LT40, used to own a TK 1600.  To me, It's all about the bed design and the rock solid hydraulics on the Woodmizer bed.  The Woodmizer backstops are incredible.  TK 1600 backstops not so much.  I had to weld manual backstops on my 1600, when the factory stops continued to bend and flop.  I did like the chain turner, but when turning cants or moving logs around, the hydraulic toe boards and the solid bi-directional clamp make all the difference. Chain turners will leave cuts and scars on the finished board, but a bi-directional clamp will easily move cants without scarring.  Both companies are great to work with, TK sent me replacement items for free, long after the sale, and I was the second owner!  Not so much with Woodmizer.  You will pay for replacement parts and shipping there.  It is worth seeing in person, if you want to make an informed choice.  Having a sawmill dealer in your home state, is worth a lot as well.  Both great mills, I'd see both in person and then make a choice!
LT 40HDG 35, JD 5205, some Stihl saws, 15 goats, 10 chickens, 3 Chessies and a Weiner dog...
Offline ladylake
« Reply #19 on: October 11, 2018, 06:26:44 AM »
 If you want some real backstops get a TK2000.   Steve
alternative to retrofitting set-works on Timber King 1600
Started by TractorBoy78 on Sawmills and Milling
Last post November 06, 2014, 11:51:18 PM
by fstedy
Woodmizer or Timber King
Started by TNhobbyfarmer on Sawmills and Milling
Last post March 30, 2007, 07:36:44 PM
by LeeB
Wood-mizer LT35 v/s timberking 1600
Started by red pine on Sawmills and Milling
Last post March 22, 2011, 09:17:19 AM
by red pine
Timber king b20
Started by CX3 on Sawmills and Milling
Last post May 20, 2018, 05:23:13 AM
by ladylake
