Author Topic: Woodmizer LT35 vs Timber King 1600  (Read 1926 times)
Online YellowHammer
  • Aerospace Engineer and Full Time Lumber Business
    • Hobby Hardwood Alabama
Re: Woodmizer LT35 vs Timber King 1600
« Reply #20 on: October 11, 2018, 09:15:46 AM »
I've owned a couple Woodmizers, their service is what can be expected to operate our business.  I call them, they know what I need if break something, its shipped next day, I'm back up and running.  You will break stuff.  You will have questions, and having a person on the other end of the phone who knows things is important.  I have talked to TK about edgers and I give them credit as they are honest and always answered the phone, also.
Woodmizer has a Resharp program, thats huge, buy bands, use them, box them up and mail them.  They come back in a week or so, sharpened and ready to go.  I don't know it TK has a sharpening program.  For a new sawyer, having a convenient and high quality sharpening program would be critical.  One less thing to worry about.  About $10 a band including shipping costs.  I know there are local aftermarket sharpening companies, but I have seen more than one mill that was having sawing issues tracked back down to incorrectly sharpened bands by "local" sharpening companies.  If TK has a sharpening program, then this is not an issue.
As far as the mills themselves:
WM has hydraulic backstops.  This is important as I use my backstops for many things, including reverse rolling logs and cants, shifting logs and cants forward and backward, etc.  These movements take force, more so than could be done with manual backstop system as on the TK1600.  Backstops can be used for much more than backstops.
The first thing I noticed was the guy on the TK video having to walk around and manually set a height pin in the log clamp.  That put me off immediately, thats just one more trip around the mill, twice for every log, for the life of the mill.  The WM has a hydraulic two plane where the height of the clamp is set from the control station.
As said, chains turners and claw turners will scar up high dollar cants.  The WM two plane will not damage cants.  Once I have a cant, I only use the two plane because its fast and won't cause divots.
The WM has hydraulic toe boards, a necessity for grade sawing.  I use my hydraulic toe boards almost every log, whereas on my old manual mill I almost never used them.  Why?  Because manual toe boards are a pain and inconvenient.  So with hydraulic toe boards, I can cut parallel to the bark, easier, which results in higher quality wood, easier.  I didn't see that the TK had hydraulic toe boards.
TK has engine driven hydraulics.  That is nice and reliable.  The WM has an electric pump.  Both work, just different systems.  I would prefer if WM had an engine driven pump.
Forget about the cantilever head being an issue.  Its not.  We sell dried, grade hardwood, about 20 different species that are skip planed to 15/16".  We mill to 1-1/8", dry and shrink to about 1-1/16" and then skip plane to 15/16" only taking a 1/16", give or take, off each face.  Most boards will clean up 100% on one face 90% on the other.  Only a very accurate mill can do that.  In contrast, when we occasionally buy wood from mega mills, using circular saws, we have much worse results with the skip planing, with many more blade marks still on the board, and less clean faces.  So a cantilever head will cut more accurately than the wood coming off industrial grade mega mills.  I have no doubt the TK cuts very accurately, also.  Dull, or poorly set and sharpened bands as well as not reading log stress will cause the majority of inaccuracies, day in and day out, and that is why a quality resharpening program is so important.
Model for Model, for me, the LT35 wins over the 1600 due to more hydraulic features, i.e. hydraulic toeboards, hydraulic backstops, hydraulic two plane clamp, if I was going to choose.
HobbyHardwoodAlabama.com
Offline ladylake
« Reply #21 on: October 11, 2018, 11:54:03 AM »
 Some of the TK advantages
 Way more capacity, not even close
 Stationary command post, you are certainly walking way more with a WM than you ever will with the TK
Twin rail, easy to keep adjusted and not necessary to spray down with atf to keep working (Seems like WM is switching over to twin rail on their new mills)
 Engine driven hyd, real reliable compared to troublesome WM electric driven pumps
 Hyd feed, WAY less trouble than the WM electric system
 If you do any amount of sawing get a sharpener and setter, WAY less cost than sending them in.  I think TK does sharpening, but to me I can sharpen blades just about as fast as boxing them up and sending them in.
 I understand TK swing up stops on the 1600 are not the strongest but I'd have them breakproof in a couple of days.
 Almost all of the parts are off the shelf
 Most likely forgot a couple.    Steve
Offline Hilltop366
« Reply #22 on: October 11, 2018, 01:14:14 PM »
Question, does one need to be a Woodmizer owner to use their re-sharp service?
Offline WV Sawmiller
    • Green's Sawmill Services
« Reply #23 on: October 11, 2018, 01:58:13 PM »
   Call and ask. You will know immediately.
Offline Tom the Sawyer
  • Converting your logs to lumber at my home or yours
    • Tom the Sawyer Portable Sawmill Service
« Reply #24 on: October 11, 2018, 02:15:40 PM »
Timberking does have a resharpening service.  Used it many years before buying my sharpener and setter.  For someone starting out, use a sharpening service, you'll have a steep enough learning curve without adding blade complexities into the mix.  As mentioned earlier, the hydraulic items mentioned as missing on the 1600 are available on the next model up and may be available on the 1600 as options.
07 Timberking B-20, Custom-made log arch, 20' trailer w/ log loading arch, F350 SD flatbed dump.  Princeton piggy-back forklift.  Bobcat S250, Stihl 025C 16" and a Husqvarna 372XP 24/30" bars, Grizzly 20" planer, Nyle L200M DH kiln.
If you call and my wife says "He's sawin logs", I ain't snorin'.
Offline PAmizerman
  • Just Another Day In Paradise!!
« Reply #25 on: October 11, 2018, 08:45:09 PM »
@ladylake
Have you ever run a woodmizer?
Just curious if you have any experience to back up you're complaints/ theiries?
I've never run a timberking but my woodmizer does everything I ask it to
And is a joy to run
As for off the shelf parts. I'd rather call up the manufacturer and get what is supposed to be on the mill.
When I need a part I call WM and get the part next day. And I know it is right. No guessing if it will work and lots of time saved not researching parts. WM prices on parts are more than fair. Time is money. Down time is even more money.
No matter what mill you get things will break and need repaired.
Hydraulics everywhere
Traverse 6035 telehandler
WM bms250 sharpener
WM bmt250 setter
Offline terrifictimbersllc
    • Terrific Timbers LLC
« Reply #26 on: October 11, 2018, 09:11:08 PM »
You dont have to be a Woodmizer mill owner to use their resharp service. But they only sharpen Woodmizer blades, so you pretty much need to be a Woodmizer blade owner.
DJ Hoover, Terrific Timbers LLC,  Mystic CT  2001 WM LT40SHDD (42HP Kubota, Accuset2, FAO's, Lubemizer, debarker), Peterson WPF 10-30 with chain slabber. Logrite fetching arch, WM BMS250 sharpener/BMT250 setter.  2001 F350 7.3L PSD 6 spd manual ZF 4x4 Crew Cab Long Bed
« Reply #27 on: October 11, 2018, 09:17:00 PM »
   TT may well be spot on but I'd double check with your local WM dealer. I thought I read somewhere that some dealers might do other brands too. I think the re-sharpening is almost a separate business with different offices doing some things that other WM shops do not.
Offline DPatton
« Reply #28 on: October 11, 2018, 09:21:52 PM »
I run a variety of blade manufacturers on my TK1600 including WM blades.
TimberKing 1600, 30' gooseneck trailer, Chevy HD2500, Echo Chainsaw, 60" Logrite.
Work isn't so bad when you enjoy what your doing.
Offline farmfromkansas
« Reply #29 on: October 11, 2018, 10:23:22 PM »
First guy I took logs to, had a wm 30.  He just ran his mill and let maintenance and adjusting go.  Still made decent boards, except he cut my boards on his inch scale, instead of the 4/4 scale.
Offline ladylake
« Reply #30 on: October 12, 2018, 04:51:59 AM »
@ladylake
And is a joy to run
Your right downtime is money and my mill has never been down more than 3 hours in 14000 hour, maybe that why I like it.  I have never run a WM but have had a couple saw for  me before I got mine.   When I can get the exact replacement part online like Goodyear  3 grove drive belt for $11,  up-down solenoid same brand same part number for $7.95 vs  $50 . I keep some spares on hand which results in very little down time.  My mill doesn't eat solenoid either, 2 so far in 14000 hours.  About the only thing I have to buy from TK is the computer and sensor .  Steve
 I'm just listing the advantages of a TK mill , same as you WM owners do. Should be fair either way
Online alan gage
« Reply #31 on: October 12, 2018, 09:50:10 AM »
As for off the shelf parts. I'd rather call up the manufacturer and get what is supposed to be on the mill. When I need a part I call WM and get the part next day. And I know it is right. No guessing if it will work and lots of time saved not researching parts. WM prices on parts are more than fair. Time is money. Down time is even more money.
Not picking sides but just wanted to point out that TK is more than happy to sell you the parts that go on your mill and are quick to ship them out. When I was rebuilding my mill I called them up and ordered quite a few parts. They were all here next day. They were very helpful figuring out what I needed and have been friendly every time I called. As I learned more about working on the machine I realized many of the parts I could get at our very good local hardware store one block down the street or I could order them from Surplus Center. It was more work to figure out what I needed but it saved me money and helped me learn some things. At the time I was fixing up the mill over the winter so down-time wasn't important.
Alan
Timberking B-16
Offline DPatton
« Reply #32 on: October 12, 2018, 03:27:38 PM »
Alan
Your right Alan, when my mill was new if I had a problem TK always replaced parts under warrant shipped next day at no cost and no questions asked. TK's service technician's have been amazing at answering questions and troubleshooting for me as well. Now that my mill is past its warranty period the TK reps and service techs are still as helpful as ever and they still ship me parts and or blades next day on my door step. You just cant beat that kind of service.
Offline dean herring
« Reply #33 on: October 12, 2018, 05:24:43 PM »
I know it possible to add up/down backstops, two plane clamp and toe boards to a TK 1600 jus what would it cost
That the only con I have with mine.
Can I get the hardware and install myself?
Failure is not an option  3D Lumber
Offline Poplarpete
« Reply #34 on: October 27, 2018, 12:18:21 PM »
Thanks for all the great feedback! Honestly, ended up feeling there was no wrong decision between the 2. My partner and I put a deposit down on a WM LT35... I feel like a kid waiting for Christmas!
Offline Southside logger
« Reply #35 on: October 27, 2018, 12:38:01 PM »
You will be very happy with your mill. I see the latest version has the same design debarker as the 40 does now, that is a nice upgrade over mine.
alternative to retrofitting set-works on Timber King 1600
Started by TractorBoy78 on Sawmills and Milling
Last post November 06, 2014, 11:51:18 PM
by fstedy
Woodmizer or Timber King
Started by TNhobbyfarmer on Sawmills and Milling
Last post March 30, 2007, 07:36:44 PM
by LeeB
Wood-mizer LT35 v/s timberking 1600
Started by red pine on Sawmills and Milling
Last post March 22, 2011, 09:17:19 AM
by red pine
Timber king b20
Started by CX3 on Sawmills and Milling
Last post May 20, 2018, 05:23:13 AM
by ladylake
