Author Topic: Drive belt tension. 2018 LT 40. 300HRS  (Read 1076 times)
Offline Lawg Dawg
  • True South Sawmill Lumber
Re: Drive belt tension. 2018 LT 40. 300HRS
« Reply #20 on: October 13, 2018, 07:33:24 AM »
But, Did you actually figure it out?
You changed 3 things there.
- Was it feed rate?
- or the tracking bolt head?
- or was it the drive belt?
I'm not sure because I pretty much did all 3 things at the same time...but I did figure out, the first time I adjusted the drive belt, I just loosened it up because I was looking at the wrong manual.  I have auto clutch, and that's the one I should have been looking at.  Maybe Woodmizer should address this issue since it's such a critical adjustment.
Good thing is, I think she's sawing like she supposed to now!
2018  LT 40 Wide 999cc, 2019 t595 Bobcat track loader,
 John Deere 4000, 2016 F150, Husky 268, 394xp, Shindiawa 591, 2 Railroad jacks, and a comealong. Woodmaster Planer, and a Skilsaw, bunch of Phillips head screwdrivers, and a pair of pliers!
100,000 bf club member
Pro Sawyer Network
Offline tawilson
« Reply #21 on: October 13, 2018, 10:43:34 AM »
Marty probably told you to get the jam nut good and tight. I have a feeling if you slow your feed rate back down the marks would come back.
Woodmizer has a pile of maintenance videos available, including a LT40 drive belt one.
2017 LT40HDG35 WIDE
Drive belt tension
Started by Grower on Sawmills and Milling
Last post July 12, 2008, 09:16:42 PM
by Grower
question
WM LT40 Drive Belt Tension
Started by DR_Buck on Sawmills and Milling
Last post February 01, 2005, 07:55:28 AM
by Bibbyman
Drive belt tension tester
Started by SAnVA on Sawmills and Milling
Last post April 07, 2013, 07:33:04 PM
by MartyParsons
Lt10 drive belt tension setting
Started by SeanG on Sawmills and Milling
Last post May 03, 2019, 09:47:39 AM
by SeanG
