Author Topic: Building an Edger/Resaw  (Read 573 times)
Offline CKWoodCutter
« on: October 11, 2018, 04:56:01 PM »
I'm having the wild idea to try and build a sort of edger/resaw. I was thinking about putting multiple blades on it and having them be adjustable so I could cut different size boards.
I want to make sure I'll have plenty of hp because I've read the more blades and thicker the cut, the more hp you'll need. So I thought, can I use an old car engine for a power source. I didn't know if anyone had any experience with setting up the engine to drive my pulley.
The other thing I'm slightly held up on is how I can design it to adjust the blades individually to cut different widths.
Thanks in advance!
Offline moodnacreek
  • Sawin by the notches
Re: Building an Edger/Resaw
« Reply #1 on: October 11, 2018, 07:07:50 PM »
Sounds like you want a gang edger.  This would be a double bay, heavy mandrel to support board edger blades on one side and a gang bank on the other. Although it would need lots of power, that is the only simple part.  I suggest that you go to whatever means necessary to find and inspect one of these machines.
« Reply #2 on: October 11, 2018, 09:01:26 PM »
Thanks for the lead. Definitely think I have something in mind that is a little bit outside the box but I figured if anyone would know anything, it would be here!
Offline jimparamedic
« Reply #3 on: October 13, 2018, 09:05:56 PM »
Ive been thinking along the lines of logosol frame saw. Which is basically a small sash mill so power need would be less
Offline JB Griffin
« Reply #4 on: October 13, 2018, 09:10:38 PM »
Like moodnacreek said your lookin for a double bay gang saw.
Rule of thumb is 5hp per inch of wood sawn per saw. So if your using 4 saws cuttin 4" stock at 100+- fpm you need about 80hp, 80 electric hp or 120dieselhp.
2000 LT40hyd remote 33hp Kubota, 160 Prentice, Frick 2 saw gang edger, Wright W-37 ABG, Suffolk dual tooth setter, Cat claw single tooth setter,'96 F-250 7.3 PSD 4x4, CS-590 Echo, MF 20c, M681 Memo.
Over 2.5 million bdft sawn with a Baker Dominator and counting.
Edger & resaw ?s
Started by valley on Sawmills and Milling
Last post October 21, 2012, 11:56:29 PM
by LorenB
Bandsaw Edger/vertical resaw??
Started by etroup10 on Sawmills and Milling
Last post April 20, 2017, 12:26:37 PM
by etroup10
Cutting Edge resaw/edger advice needed...
Started by Traditional Toolworks on Sawmills and Milling
Last post December 12, 2009, 07:20:57 PM
by Cutting Edge
Help building a horizontal resaw jig for my bandmill
Started by Wrangler55 on Sawmills and Milling
Last post March 24, 2011, 12:31:30 PM
by woodZwayz
