Author Topic: timberjack 230 or john deere 440  (Read 2574 times)
Offline Maine logger88
  • Don't force it get a bigger hammer
Re: timberjack 230 or john deere 440
« Reply #20 on: October 15, 2018, 03:19:09 PM »
I will also say there is nothing wrong with a Deere skidder I still have 1 and itís been good to me but I mostly run my timberjacks now. Just given a choice between the two I would go with the tj!
Offline redneck
  • timberjack 208
« Reply #21 on: October 15, 2018, 07:09:38 PM »
Timberjack  easy to get on and off if working alone
208 timberjack 353 detroit, case 580 super K backhoe, homemade bandmill, 357xp, 372xpg
Offline mike_belben
  • Pulp Friction
« Reply #22 on: October 18, 2018, 09:29:53 AM »
Thetes a pretty decent looking 440 on nashville CL for $6k
Revelation 3:20
Offline Satamax
« Reply #23 on: October 18, 2018, 09:50:13 AM »
And one in a far sorryer state in France. Well, actually, there's two for parts at the moment. :D
French CD4 sawmill. Latil TL 73. Self moving hydraulic crane. Iveco daily 4x4 lwb.
Offline mike_belben
  • Pulp Friction
« Reply #24 on: October 18, 2018, 09:56:43 AM »
You dont think that'll buff out? Hmm.
Revelation 3:20
Offline Satamax
« Reply #25 on: October 18, 2018, 12:25:33 PM »
Nope.
Offline curved-wood
« Reply #26 on: October 18, 2018, 02:15:28 PM »
That John Deere looks awfull ! Satamax :  if you dont like John Deere that is a shure way to show it :)
I am still on the hunt but mainly for a Timberjack. I've got what seems to be a good prospect for a 230.
Offline Southside
« Reply #27 on: October 18, 2018, 02:36:56 PM »
Around here since you can still read the lettering the owner would still ask top dollar....
Offline Satamax
« Reply #28 on: October 18, 2018, 03:44:22 PM »
I love the looks of old 440's. But here, it would be risked to have one.  This one has rolled over, and is for sale on leboncoin.fr and this isn't the worst picture.
Offline teakwood
  • Switzerland
« Reply #29 on: October 19, 2018, 08:01:57 AM »
but what did they do with that skidder?? trow it from a concrete dam?
Offline Satamax
« Reply #30 on: October 19, 2018, 08:33:42 AM »
Rolled it on a hill i guess. Mind you, where this is, it's "la charente" where it's flat flat flat!
Offline OntarioAl
« Reply #31 on: October 19, 2018, 08:38:07 AM »
Looks like it may have rolled over and over and over down the side of a mountain.
Definitely not the result of a simple rollover.
Al
Al Raman
« Reply #32 on: October 19, 2018, 04:49:37 PM »
The only time I ever saw a cage that bad is when a guy dropped a very large pine on his skidder. But I suppose rolling off a mountain would do the same thing. I hope nobody was in it when it happened
Offline snowstorm
« Reply #33 on: October 19, 2018, 05:00:10 PM »
big tree really big tree. i have seen 2 that looked like that. looks like it broke the rear axle housing
Offline WWright
« Reply #34 on: October 20, 2018, 06:33:46 AM »
 Back in the late 70s my father had a 208 we did some custom skidding for a local excavation contractor who had a john deere 440 same vintage 78-80. We felt the timberjack got around better and was built better for the woods and was more stable. We did like the way the John Deere looked and it was much quieter. Dad eventually sold the Timberjack and switched to Clarks and over the years bought new 664s 665s and 666s. All with detroits except the last 666 had a cummings. He loved the Clarks and never had a problem with the detroits
 Having said all that he still always talked about his little 208 and how stable it was and how it would climb hills other machines wouldn't and easy in and out.Hope this helps good luck!
Offline curved-wood
« Reply #35 on: October 26, 2018, 06:39:03 AM »
I was looking at a nice Timberjack 230 but could not find the Id metal plate with the serial number. Where it is normaly located ? I've seen some stripped pop rivet inside the cabin between  the pedal and the seat, is there where it is normally ?
Offline Oliver05262
« Reply #36 on: October 26, 2018, 09:56:38 PM »
Claude, older Timberjacks like 240A I have worked on, the serial number plate was on the metal which is next to your right ankle. You could read it from the ground. If you you look closely, you may see where the rivets were that held the plate on. Wire brush that area and you should find the number stamped into the metal there where it was underneath the plate.
"You can't do wrong by doing good"
It's OK to cry.
Offline curved-wood
« Reply #37 on: October 27, 2018, 05:57:01 AM »
Oliver , thank you for that very important info. The owner has registration papers but there is no plate on the machine, so I at least I could check if the numbers match. Beside a stolen skidder, is there any reason why somebody would remove the ID plate ?
Offline celliott
« Reply #38 on: October 27, 2018, 07:28:41 AM »
These machines are getting into 40+ years old, and have been through countless rebuilds and owners and hours. There is no telling whatís happened to the machine over the years. It could have fell off years ago. Someone wanted a souvenir. I wish my skidder could talk, Iím sure itís got lots of stories, I can only imagine the wood itís pulled over the years.
Chris Elliott
Clark 666C cable skidder
265rx clearing saw
Offline Frozendozer
  • Frustrated wood cutter
« Reply #39 on: October 28, 2018, 12:56:05 PM »
got a half day on my 440, I was happy with just a few issues to deal with, one of them being operator learning curve.  I can share I am impressed with the power and responsiveness in comparison with my old c5 tree farmer.   I was ready for a tippy machine as warned by users on this site, however I found it stable  and nimble.
TIMBERJACK vs John Deere
Started by timberjack240 on Forestry and Logging
Last post April 26, 2005, 08:59:26 PM
by OLD_ JD
Timberjack 460 or John Deere 648 grapple skidder
Started by logger444 on Wanted
Last post July 09, 2009, 10:52:56 PM
by RalphV
FRANKLIN VS. CLARK VS. JOHN DEERE VS. TIMBERJACK
Started by captainelvi on Forestry and Logging
Last post October 23, 2018, 06:07:00 PM
by Mountain_d
timberjack or john deere 1010 or 1110
Last post June 27, 2009, 10:11:40 AM
by logger444
