Tally-I/O
Author Topic: Heating air to lower RH and EMC  (Read 262 times)
Offline GeneWengert-WoodDoc
« on: October 17, 2018, 08:02:54 PM »
When heating air, itís relative humidity drops.  Here is a table showing the outside air low temperature, and the RH and EMC when heated to 70 F.
Morningís Low (F)   Humidity at 70 F (%)    EMC at 70 F (%)
0.                               5                                   2
20                             14                                  4
40                             34                                  7
60                             67                                 12
Another way to look at this heating effect is to figure out the amount of heat above the morningís low temperature required to achieve 7% EMC.
Morningís.   Heating (F)     Building Temp (F)
Low (F)
0                   21                         21
20                25                         45
40                27                         67
60                28                         88
Offline curved-wood
Re: Heating air to lower RH and EMC
« Reply #1 on: October 18, 2018, 08:26:41 AM »
Very usefull info
Where to buy logs in NW lower MI
Started by timheger on Timber Framing/Log construction
Last post May 01, 2005, 09:57:28 PM
by timheger
Lower Gasoline Prices
Started by shopteacher on General Board
Last post February 28, 2004, 01:27:08 PM
by Jeff
New in Northeren Lower Michigan
Started by 6610 on Sawmills and Milling
Last post November 22, 2014, 10:48:08 AM
by Busy Beaver Lumber
Lower left Corner
Started by Fla._Deadheader on General Board
Last post April 17, 2007, 08:56:46 AM
by Fla._Deadheader
