Baltic Abrasives Technologies
Author Topic: 2006 Dodge Cummins Heater Quit.  (Read 480 times)
Offline LeeB
« on: October 26, 2018, 12:10:17 PM »
Blower works but not heat. Any ideas?
Offline Southside logger
Re: 2006 Dodge Cummins Heater Quit.
« Reply #1 on: October 26, 2018, 12:29:18 PM »
Stuck thermostat in the engine? Other possibilities are your heater core is plugged with goop or your blend door is not moving in the plenum. Thermostat is the easiest and cheapest to try first.
Offline LeeB
« Reply #2 on: October 26, 2018, 01:03:17 PM »
Hard for me to check any of it right now. Me and the truck are a llloooongggg ways apart. I suspect heater core but could just as easily be the door. It definitely groans when shifting.
Offline thecfarm
« Reply #3 on: October 26, 2018, 02:58:45 PM »
I suppose the radiator is full?
Offline sawguy21
« Reply #4 on: October 26, 2018, 03:57:42 PM »
You should not hear the doors open and close. They can be checked by feeling the air flow from the vents as the control knob is moved. If that is ok and the engine comes up to proper temperature the core is plugged.
I had it replaced in my 05 last fall, the part wasn't expensive but the labor sure was, 5 hours for an experienced tech. The dash had to come out, the manual stated this is not a job for the diy mechanic and seeing it apart I have to agree.
Offline Dave Shepard
  • Geometrically proportional
    • My homepage
« Reply #5 on: October 26, 2018, 06:34:32 PM »
If you figure out it, let me know. Our 2005 doesn't have any heat, either.  :D
Offline KirkD
« Reply #6 on: October 27, 2018, 12:03:28 PM »
The Blend door is a common problem in Dodge's and all the time it takes to rip out the dash and change them can be saved by replacing them with a metal one instead of the factory plastic one. There are videos on how and where to cut in to replace them.
Google "Heater treater dodge blend door replace YouTube"
Wood-mizer LT40HD-G24 Year 1989
Offline LeeB
« Reply #7 on: October 27, 2018, 12:11:09 PM »
I'll do that when I get home. Can't watch youtube over here.
2002 Dodge Ram Cummins 4x4
Started by Corley5 on For Sale
Last post May 31, 2018, 11:04:01 AM
by Corley5
Has any built a generator using a Dodge Cummins diesel?
Started by WoodenHead on Alternative methods and solutions
Last post September 18, 2013, 08:25:14 PM
by snowstorm
Any comments on the Dodge 3/4 ton trucks with cummins 5.9l engine?
Started by oakiemac on General Board
Last post August 13, 2005, 10:29:44 AM
by Dakota
Dodge- Cummins 98- 01 Watch out for weak block
Started by Banjo picker on General Board
Last post June 28, 2017, 12:29:11 AM
by Chop Shop
